It is currently Thu Mar 23, 2017 5:41 pm
PostPosted: Fri Jan 07, 2011 9:39 am
Does anyone know what the difference is between the 7850 C24 and the new 7900 C24 wheelset is? Besides price and graphics.
Cheers
Don't let the truth get in the way of a good story......
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Fri Jan 07, 2011 10:22 am
The spoke nipples are black instead of red, and the bearing preload adjustment is different (more user friendly) on the 7900's. FYI I have the 7900's. Haven't poked around inside the hubs yet to see if there are any differences there.
PostPosted: Sun Feb 05, 2012 12:29 pm
I heard seals are different and faster engagement on 7900, not sure anyone can confirm? Also physically the 7900 hub shell is larger
PostPosted: Sun Feb 05, 2012 4:21 pm
i have had both..
newer seals on the 7900, new graphics, black spoke nipples, black skewers. (black skewers only come on non OEM wheels)
proper retail ones will come with black skewers and wheel bags.
best place I have found to buy them is where I got mine.. Hargroves cycles
another good shop, Planet X..they also do C35's and C50's :)
"Heroes do not die, they re-load"
PostPosted: Mon Feb 06, 2012 2:54 am
Confirmed:
-New Seals
-Rim Cosmetics
-Nipple Color
-Hub Axles Larger
-Digital Click System (for the bearing preload)
Maybe?
-Faster Engagement with 7900 freehub?
PostPosted: Thu May 24, 2012 9:31 pm
I will pick up my new new 7900 tomorrrow and sell my 7850.
PostPosted: Fri May 25, 2012 3:02 am
also,
7850's are 20mm wide,
7900's 22mm
PostPosted: Fri May 25, 2012 4:54 am
blantonator wrote:
also,
7900's 22mm
That is incorrect, both rims are 20.8mm wide.
WH7900C24 tech doc
WH7850C24 tech doc
You can alos compare part #s by looking up the exploded views: 7900 exploded view and 7850 exploded view.
To the OP, I'm currently riding the 7900 C24 clinchers and they're fantastic. Go for it!
Turn down the suck knob.
There are no new unread posts for this topic. Dura ace 7900 shifters with 9100 breaks ?? Compatibility
Allen254
10
633
Thu Feb 16, 2017 10:40 pm
VforVonnegut View the latest post
There are no new unread posts for this topic. Replace Dura Ace 7900 Cage Rear Mech
anicell
Thu Jan 05, 2017 5:11 pm
ooo View the latest post
There are no new unread posts for this topic. Is 11 speed Dura Ace chain compatible with Dura Ace 7900 gruppo?
wootenlakeguy
Thu Oct 13, 2016 7:07 pm
pdlpsher1 View the latest post
Users browsing this forum: Bing [Bot], glepore, huddini, jamin, lovemyway, mile2424, nestornnk, shadowman, zulu695 and 31 guests
