It is currently Thu Jun 29, 2017 3:38 am
Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4
PostPosted: Mon Feb 06, 2012 7:31 pm
ms6073 wrote:
Seen/downloaded this - Hollowgram SL Crankset Owners Manual ? I think that typically for the Hollowgram crank, the non-drive side crankarm is installed and torqued first then once installed, for maintenance only the drive side crank arm is removed.
Thank you. I actually have checked the manual before writing here. And on the photo on page 7 where the spindle is pulled out from the non-drive side there it looks like that the pedal arm sits not completely bottomed out on the spindle .I just wanted to be sure if there is an issue with a brand new item before torquing it to the given Nm. So it looks like there is nothing wrong with our crank set .On the other hand I am curious to know why the flower splined edge of the spindle has been designed longer than needed? Or am I mistaken and the crank arm will slide fully onto the flower splined edge when torqued correctly?
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Mon Feb 06, 2012 9:11 pm
It's not longer than needed,the spline iss some sort of conical, so when you torque it will not move or slide.
PostPosted: Tue Feb 07, 2012 6:41 am
Thank you.
Kuota Kom Evo
SOLD
PostPosted: Thu Mar 01, 2012 2:58 am
So my lbs just tried to instal my hollowgram sisl on my new 2012 felt f1 and they are telling me that it will not fit. Something to do with not enough space or too much. Has anyone heard of the CH SISL not working on certain BB30 frames?
I am hoping that there is some kind of solution here, other than getting a new crank! Thanks
PostPosted: Thu Mar 01, 2012 4:03 am
it might be that the frame bulges out slightly from the 68mm width around the crank spider area. if that is the case, then something to offset the crank will help- srm specific bearing shield or srm-offset spindle. look at cannondaleexperts.com.
if it's anything else, we need pics.
PostPosted: Thu Mar 01, 2012 4:08 am
Appreciate it! I am going to head into the shop tomorrow and get the specifics. I have found numerous pics online of F1's with the CH SISL SRM, so maybe that will solve it. I will repost tomorrow. Thanks again
PostPosted: Mon May 21, 2012 10:13 pm
Anyone else with info on this? I'd like to know if the Hollowgram fits before making a potential purchase.
The troubles I've seen have come from F1 owners (I believe the spindles have been too short) - I'm wondering if this is just due to the carbon bb design on the F1 or if I should still expect to run into clearance issues on my F3 (aluminum bb sleeve)
Current:
Project C6.0
On to a better life:
Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
PostPosted: Tue May 22, 2012 11:04 am
I am currently running a Hollowgram SRM on my 2011 FC with no clearance issues. However, this is with the SRM spindle and NDS bearing shield. I tried with the standard spindle and shield and it was too tight so I swapped to the SRM specific parts and it worked perfectly.
PostPosted: Mon Jun 03, 2013 1:48 am
Seeking assistance - installing new Hollowgram (SiSL) on Supersix. The issue I have is with the DS crank, I can't get anywhere near the torque required and the wavy washer is compressed. In using only the washer (no plastic spacers) I can probably get it close to 25nm, but again the washer is pretty flat. There is no play in the cranks, and they spin well (it's not binding). I tried using multiple plastic spacers (shims) but this actually works in reverse, i.e washer compresses far earlier when tightening. I'm sure it's something basic I'm missing, but cannot find anything in the installation manual or on the boards as to the procedure when this occurs? (most people seem to have the opposite issue).
There are no new unread posts for this topic. Worth upgrading to cannondale hollowgram si ?
jobvisser
Thu Feb 16, 2017 10:44 pm
evan326 View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram SiSL on a SL4 S-Works Tarmac OSBB
Alpine318is
7
947
Sun Sep 25, 2016 12:23 am
alcatraz View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram crankset spindle lenght for PF30
LouisN
Thu Dec 15, 2016 3:23 am
LouisN View the latest post
There are no new unread posts for this topic. Di2 install help
stub
Thu Apr 13, 2017 12:37 am
stub View the latest post
There are no new unread posts for this topic. BB Install
wpccrunner
Sat Nov 19, 2016 7:48 am
kkibbler View the latest post
Users browsing this forum: Baidu [Spider], jerbax18, spytech and 32 guests
