Post new topic Reply to topic  [ 260 posts ]
Go to page 1, 2, 3, 4, 5 ... 18  Next
PostPosted: Sun Dec 05, 2010 12:40 am
Instructions DELETED.
Instructions reposted by another user on page 2.
Page 3 has the complete story.
Page 8 has the letter from Speedplay word-for-word.
PostPosted: Sun Dec 05, 2010 4:14 am
Thanks for the info, it will make keeping my Speedplays going and help with an upgrade of my CrMo to Tion my 2nd bike.
Toronto cycles sells alloy and Ti bowties and bolts for Speedplay, for those wanting to lose extra weight.
Ozrider - Western Australia
Parlee Z5 XL 2011 (6055g/13.32lbs) Raleigh RC Ltd 2008 (7.6kg) Reynolds 653 Custom 1990 (9.8kg, now 8.8kg)
The accumulation of marginal gains is what makes the difference between winning and losing
PostPosted: Sun Dec 05, 2010 7:02 am
I was using induction soldering tool instead of blowtorch to unscrew the stubborn screw. It got replaced by Ti Allen head screw w/out locktite.
When I overhaul pedals I actually throw pedal body
into ultrasonic cleaner w/solvent. Cleans like a charm.
PostPosted: Sun Dec 05, 2010 11:24 pm
Glad you posted this, I'm installing the ward spindles now on my zeros. I stripped the head on one of the torx spindle bolts, what is the best way to remove it? Just drill it out?
PostPosted: Sun Dec 05, 2010 11:58 pm
I had a similar problem with my Zero Ti. Flat screwdriver slot and little heating for inside Loctite, and has unscrewed bolt removed
PostPosted: Mon Dec 06, 2010 12:36 am
Frankie-B had the same problem, he just drilled it out but that's olso the end of your spindles, on ebay jou can gat cheap (60usd?) tita spindles witch are lighter than original speedplay ti spindles, so maybe that's an good excuse...
If it's a tita one try the way avatar 78 did it, if that won't work just dril it out carefuly and only the head of the screw, you can go to a local metalworker to dril it out in a turning machine maybe try get it in the turningmachine and carefully rotate the axle clockwise so the screw wil work himself out, if that won't work just dril it out and careful and recut the treat.
Good luck
PostPosted: Mon Dec 06, 2010 3:40 am
DELETED
PostPosted: Mon Dec 27, 2010 9:49 pm
Just as an update, I bought a screw extractor called Grabit Pro which worked well. It ended up snapping the head off the screw which was fine, I could then get the axle out and junk it. Just ordered the screw kit mentioned above and we'll be good to go. The pedals are surprisingly light in your hand with the ti axles.
PostPosted: Tue Dec 28, 2010 12:18 am
Does any one know where I can get the spindle screws in the US? I think these are M4 1cm but not sure. I see pro bike kit has a speed play small parts kit that has the dust caps the spindle screws and O rings but I can not find it for sale in the US.
If I can find just the screws that would be great.
Ride Vellum Cycles
PostPosted: Tue Dec 28, 2010 2:32 am
Resident Pro
This should be a sticky post. Thanks so much.
PostPosted: Tue Dec 28, 2010 2:38 am
DELETED
PostPosted: Tue Dec 28, 2010 2:48 am
I am looking for the spindle screws not the bow tie screw's and I am not finding them on the auction site.
Ride Vellum Cycles
PostPosted: Tue Dec 28, 2010 3:06 am
DELETED
PostPosted: Wed Dec 29, 2010 8:58 pm
Any link, Steen ? I tried w/ "Speedplay", w/ "spindle" in the search tool....unsuccessfully :(
Thanks !
Pollice verso.
PostPosted: Thu Jan 13, 2011 10:29 pm
DELETED
Post new topic Reply to topic  [ 260 posts ]  Go to page 1, 2, 3, 4, 5 ... 18  Next
Users browsing this forum: BeeSeeBee, bratz, Dexton, ebb, Google [Bot], Google Adsense [Bot], Kayrehn, Lewis, rijndael, sedluk and 54 guests
There are no new unread posts for this topic. Look Keo vs Speedplay
thencameyou
21
1240
Thu Feb 07, 2013 12:44 am
shimmeD View the latest post
There are no new unread posts for this topic. Speedplay X1 and X2 pedals
tantra
Sun Sep 30, 2012 9:51 pm
ECT View the latest post
There are no new unread posts for this topic. Speedplay... play?
Valy
18
1190
Mon Sep 24, 2012 5:37 pm
Rick View the latest post
There are no new unread posts for this topic. Sidi Wire Speedplay..Or not?
jan erik
11
861
Wed Apr 24, 2013 1:25 pm
joshvoulters View the latest post
There are no new unread posts for this topic. Speedplay Zero, chromo or stainless?
Pharmstrong
10
776
Mon Jul 23, 2012 7:58 pm
Pharmstrong View the latest post
It is currently Wed Jun 19, 2013 6:58 pm
