Post new topic Reply to topic  [ 12 posts ]
PostPosted: Tue Nov 30, 2010 1:25 pm
I have searched, but found no matches. Is it possible?
PostPosted: Tue Nov 30, 2010 1:55 pm
zipp bb cups from a vumaquad crank and it should slip right in.
same deal with the far cheaper cups from the hive.
PostPosted: Tue Nov 30, 2010 2:06 pm
Possible if you run a wider axle - ie MTB axle with mods for a hollowgram crank, or a MTB version of a Specialized crank for example - but you will suffer from wider Q-factor and chainline changes. The mentioned cups are external so the axle needs to be wider to accomodate them.
PostPosted: Tue Nov 30, 2010 2:37 pm
you also probebly hase to machine the axle :D
you can se some of the parts you need in this http://www.cannondale-parts.de/epages/6 ... ucts/KP094
as already has been said, the q-factor will be higher
PostPosted: Tue Nov 30, 2010 4:07 pm
Thanks, Guys!
The "problem" is that i have Hollogram SRM on my two SuperSIX, and I have another Hollowgram SRM in my hand. It would be nice to put it on the TT rig.
What more parts do i need, except the parts in the link, JensW?
PostPosted: Tue Nov 30, 2010 4:36 pm
As many others have, I've come to the conclusion that this just wont work very well. A little OT, but does anybody know if a lightning crank will fit in a specialized S-works spider, such as the S-works srm.
PostPosted: Tue Nov 30, 2010 5:14 pm
Formerly known as CAADHEAD
thue wrote:
Thanks, Guys!
You need to be speaking to 'Starnut', he is the world authority on fitting Hologram cranks to 68mm shells, I believe he was selling a kit at somepoint.
Ti or dye!
PostPosted: Tue Nov 30, 2010 6:48 pm
someone needs to sticky this thread or one of the other ones.
So here's the deal; it's not just plug and play with off the shelf parts. At a minimum the process requires a modified spindle and machined spacer to take up slack.
In the above photo you can see the stock cannondale spindle on the top and the modified one below. The bearing surfaces have to be moved and the coller needs to be machined off for the thing to work. Additionally, you will need a spacer has been machined to fill the gap on the excess spindle length. The above spindles are longer than a standard BB30 104 or 103 mm from cannondale or anyone else. They were orginally designed for the Rush 2x9s which were wider for a year.
Knowing that the arms are built around a 104 spindle the stance width does increase a little with the above spindles. Also, the road spiders for the SISLs are machined with a drivetrain offset for the 104 spindle also. Because of that, the chainline on some bikes (particularly those with short chain stays) is not ideal and is spaced a little far to the DS and can become an issue.
What we're currently working on it a few things. First, we're working on machining a custom spider to correct the offset so the drivetrain works. There is obviously no work around for the SRM. Second, we're working on a carbon spider with the offset also and a spider with the BB30 offset (should be light :twisted: ). Third, I'm looking at making a new spindle from the ground up to fix the stance width. The deal is the Cannondale spindle is about 3-4 mm longer than we need. I'm trying to find a way to make one that is the cirrect length and make sure it's going to be as light as the cannodnale one and be made at a price where it is feasible to sale at retail. If I can fix it but the cost is $100 a spindle, it's not likely a viable option for retail and I wouldn't be able to sell enough to make it worth my time.
On top of all this...... I've started my own shop and we own BB30.com as well. So........ you'll have to forgive me if it seems a bit slow coming to market with this. Also, it looks like a lot of the industry is moving to BB30 anyway that or they are moving to standard where the comversion or BB30 woulnd't work anyway..... so.......
Starnut
"Don't pedal harder, pedal faster!"
Q-FACTOR IS A RED HERRING
BB30.COM
PostPosted: Tue Nov 30, 2010 7:13 pm
I rest my case 8)
Ti or dye!
PostPosted: Tue Nov 30, 2010 11:22 pm
Hi Starnut - ~18mm wider Q-factor right? 104mm vs 122mm axle IIRC
PostPosted: Wed Dec 01, 2010 4:01 am
something like that. What ever it was on the Rush a few years back. I REALLY think we can knock 3-4mm out of each side and bring it down to 1cm or 4mm on the DS and 6 mm on the NDS with a custom made spindle..
Starnut
BB30.COM
PostPosted: Sun Jan 02, 2011 10:38 pm
Sooo, when can I buy one from you? :thumbup:
Users browsing this forum: budgetweenie and 36 guests
There are no new unread posts for this topic. Hollowgram on BB386 frame
Ainsy
Mon Jun 11, 2012 5:58 pm
ms6073 View the latest post
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
848
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Attachment(s) BB30 threaded cups for BSA frame---I've searched
go4custom
20
1908
Sun Jan 13, 2013 10:20 pm
skinnywellfed View the latest post
There are no new unread posts for this topic. Best value carbon crankset for 68mm threaded BB?
Porschenut
10
887
Fri Jun 15, 2012 1:33 am
Porschenut View the latest post
There are no new unread posts for this topic. 68mm campag ultra torque in 72 mm shell?
SupaSubi
Fri Aug 10, 2012 8:45 pm
SupaSubi View the latest post
It is currently Sun May 26, 2013 5:51 am
