Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat Dec 06, 2003 6:11 pm
During a cold day here with too much time on my hands I got curious where the weight came off of the 2004 Record ergo brake/shift levers.
I thought maybe they went to an alu band and bolts for the handlebar connection - but after comparing 2004 and 2003 Record to 2004 Chorus schematics I find they all use the same steel bands and bolts. 2003 Record shares same p/n as 2004 Record for carbon brake lever. Beside the surface treatment new on 2004 Record internals, the only other likely change is that 2003 Reocrd body is now same p/n as 2004 Chorus but 2004 Record body is new P/N - one might first justify that label (Ultra 10) on body justifies that new p/n but after comparing everything else I've got to conclude the 18 grams/set they took off came from the lever bodies - anyone heard the same or different??
PostPosted: Sat Dec 06, 2003 6:16 pm
I don't really know but the only real change is the shifting mech
 Post subject:
PostPosted: Sun Dec 07, 2003 7:35 pm
some holes in the indexing ratchet
 Post subject:
PostPosted: Sun Dec 07, 2003 9:03 pm
So you can do it yourself with a 2003 model?
PostPosted: Mon Dec 08, 2003 4:14 pm
Thanks for the tip on the holes in the cogs - but after applying my "guesstimate" regarding size and number of holes results in calculations of 2 grams saved per cog (x2 cogs)....so still 14 grams short of where it came from....so maybe still the lever bodies?
All this is cause I was going to buy some Centaur levers for a cross bike and now thinking of maybe taking some 3 year old record levers off my road bike and moving them to the cross bike and replacing them with 2004's on the road bike - costs a bit more but more this way but hey I get a new set on the "good" bike plus the latest/lightest gizmo.
Users browsing this forum: Bing [Bot], verycreativeusername and 55 guests
There are no new unread posts for this topic. Weight needed for Campy rings
1spd
Tue Dec 18, 2012 2:29 pm
1spd View the latest post
There are no new unread posts for this topic. Campy Hyperon and Bora rim weight
LionelB
Tue Jul 10, 2012 7:16 am
LionelB View the latest post
There are no new unread posts for this topic. Magazine weight vs real world weight:)
CBRE
16
1157
Fri Jul 13, 2012 8:58 am
madmole View the latest post
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2637
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. Campy Hub ID
xg43x
12
386
Tue Dec 18, 2012 3:02 am
Wingnut View the latest post
It is currently Fri May 24, 2013 4:30 am
