It is currently Wed Feb 22, 2017 8:04 am
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: Frame stiffness numbers
PostPosted: Tue Nov 09, 2010 4:30 am
I apologize if these have been posted before but a search failed to pull any up. SO here it goes: has anyone posted frame stiffness numbers of major brands/models, i.e., how much deflection of various parts of a frame under XXX kg load?
Thanks!
PostPosted: Tue Nov 09, 2010 8:15 am
A lot of data here.
http://marcogarzi.blogspot.com/
My 6696gr Cipollini Bond
My 9733gr Colnago Master X-light
PostPosted: Tue Nov 09, 2010 8:42 pm
I was able to translate just several simple words and as i do not speak Italian, could anyone explain me what is the difference in between test protokol of this italian magazine and for exemple german Tour? In Tour, for example Cervelo R3sl and Scott were always one of the best frames in stiffness data, but here it seems, that Cervelo and Scott are not any better than other frames. In fact, it seems, that they are more (just little) flexy in BB than others.
translating it word by word in translator would be too much time consuming for me.
Martin
My Wilier Zero7: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=116053
And Ridley X-Fire Disc http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=124026&p=1056055#p1056055
PostPosted: Tue Nov 09, 2010 11:17 pm
That's also the results "Tour" finds. Medium to good BB stiffness, but not at all test winning. They excel in STW values, as they are quite light.
PostPosted: Wed Nov 10, 2010 8:59 pm
There are two graphs referring to tests with a 80kg cyclist.
The top one is for when the bike is in motion while pedaling. Y axis is deformation in mm. X axis has 5 sections: constant speed, accelerating, climbing, sprinting. The red line is for the bottom bracket laterally, blue line is the seat post, and the green line (not sure) angle of head tube in gradients?
The second graph is while braking. Y axis is deformation in mm. X axis: normal braking, abrupt stop, impact. The blue line is the seat post, purple bottom bracket vertically, and black the fork.
PostPosted: Wed Nov 10, 2010 9:18 pm
Martin
The article rates both those frames as very stiff. It mentions that the slope of the red line is near constant while sprinting.
PostPosted: Mon Apr 09, 2012 6:54 pm
Awesome link and translation, thanks!
There are no new unread posts for this topic. Strava Fitness/Fatigue/Form numbers
Shrike
Mon Nov 21, 2016 10:09 am
maquisard View the latest post
There are no new unread posts for this topic. Rotor 3d+ crank stiffness?
xntrickly
Wed Aug 24, 2016 11:36 am
Marin View the latest post
There are no new unread posts for this topic. Quantifiable Cannondale Synapse BB Stiffness
TheKaiser
Fri Apr 01, 2016 7:03 am
stormur View the latest post
There are no new unread posts for this topic. Frame questions + best frame you ever rode
[ Go to page: 1 2 3 4 5 ]
iliedanila
69
9091
Sun Jul 17, 2016 5:01 pm
jerrybrabus View the latest post
There are no new unread posts for this topic. Hi-Mod frame vs non-himod ? Different frame quality ?
destinationwarmth
Fri Feb 03, 2017 8:00 am
destinationwarmth View the latest post
Users browsing this forum: benzebub, Google [Bot], sussexhills and 22 guests
