road bars with a short reach?
cyclemanpat
by cyclemanpat
I am looking for road bars with a very short reach.....like 75mm or less. What are some bars that have this?
to go faster....just pedal harder!
C-40
by C-40
shortest u can buy are the easton carbon bars....
ipenguinking
by ipenguinking
Salsa Poco, if they are still making them.
SFcyclist
by SFcyclist
I am using Ritchey Carbon Superlogic II bars in the 40cm version and the reach is only 72mm (Note: Ritchey measures C-C so these are equivalent to other manufacturers 42cm outside-outside).
http://www.ritcheylogic.com/dyn_prodfamily.php?k=141144
I really can't recommend them enough. The shape is perfect for me and they are just the right blend of stiff and comfortable for my 145 lbs. I just bought another Superlogic II bar to replace the perfectly good carbon bar that was on my second bike.
Good luck.
Henry G
by Henry G
Here is a compendium of road bars:
http://ruedatropical.com/2009/03/road-d ... -geometry/
you can compare the short reach bars.
Henry
bricky21
by bricky21
Nice link Henry G. Its cool to be able to compare all of the different shapes, and to see were the brake/shift mech. will be.
It would be nice to have even more bars in that chart.
Henry G
by Henry G
bricky21 wrote:Nice link Henry G. Its cool to be able to compare all of the different shapes, and to see were the brake/shift mech. will be.
Leave a comment suggesting what bars are missing. More are getting added soon.
Henry
Ypsylon
by Ypsylon
Y'all realize that a bunch of the handlebars in our own listings have the reach and drop listed?
The VCRC is listed with 70mm and the DEDA zero-100 with 75mm.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
boots2000
by boots2000
Of all the bars I have tried- Easton SLX3 are EFFECTIVELY the shortest. THey are shaped in such a way where the spot that the lever mounts allows for closeness.
Many bars do not do this- in spite of having a short reach. Often times the spot where the lever mounts actually puts them further away.
jlwdm
by jlwdm
Bontrager WSD VR 70mm
Dimension 70mm
Ritchey Classic Curve 73mm
Ritchey WCS Curve 73mm
Jeff
grid256
by grid256
+1 or 2 for Easton.
Chirobike
by Chirobike
Shimano Pro PLT Compact (Version 1 not 2, 2 had different bend). I think the reach is 65mm. I've got an extra pair but they've been painted so no logos and if you hate blue then you need to re-paint. Bars are oversized (31.8), 42cm. Very nice and comfortable. Weight is so-so but I don't want carbon bars cracking on me.
Review:
http://road.cc/content/review/26135-pro-plt-compact-drop-bars
tinman143
by tinman143
Henry G wrote:Here is a compendium of road bars:
Subscribed; great link thank you.
spinwax
by spinwax
boots2000 wrote:Of all the bars I have tried- Easton SLX3 are EFFECTIVELY the shortest. THey are shaped in such a way where the spot that the lever mounts allows for closeness.
Exactly. The Ritchey Curve has a reach of only 73. The levers are actually out a good cm farther than my 3T Rotundo that has a longer reach on paper.
89daytona
by 89daytona
Specialized has 3 short reach bars available
75mm in The "S-works" Trim for $250,
74.5 in the 30g heavier "pro" trim for $45. Also Ruby SL in
75 in the "Ruby SL" Trim $260
All available in 32/40/42cm accept the S works which is 38/40cm only.
And there is always the over the top integrated stem/bar available in the same options as well.
@racecarbrian
