Chain wear measurement
Sorry to bring this up again, I tried searching unsuccesfully for the thread that talked about chain wear and measuring with a vernier caliper, if I remember correctly there was an image showing the scale measurement.
does anyone have the link
Thanks
Edit--
found the link
http://weightweenies.starbike.com/forum ... in&start=0
Thanks
Edit--
found the link
- jersievers
The best of the best:
To elaborate, the Park Tool meter measures 0.75% - 1% wear. Both of which is already too far. On modern drive trains chains should be replaced at about 0.5% wear.
The Caliber 2 measures 0.075mm - 0.1mm wear per link or respectively 0.3% - 0.4%.
Campy says that at 132.6 mm between a certain number of rollers is the max - I don't recall what percent wear (remember chains don't stretch they wear away on the bushings/pins which then gives slopier joints that show up as a longer chain) but when I've done it this way it was real close to the same as 1/32" lenghtening in 12" - a very conservative and good "safe" point toward saving your cassettes.
The Campy tolerance corresponds to 0.45% wear.
[quote="divve"]The best of the best:
To elaborate, the Park Tool meter measures 0.75% - 1% wear. Both of which is already too far. On modern drive trains chains should be replaced at about 0.5% wear. [quote]
I use http://www.parktool.com/tools/CC_2.shtml
It measures from 0-1%
Vorsprung Durch Tortë http://www.costablancacycling.com/
