I links pics. Regular and Mini. [Test report on page 3]
BmanX
by BmanX
Thank you for the post. If I can ask, what brake cable housings are you running with this set up using the I-Ling Mini's for shifting?
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
prendrefeu
by prendrefeu
Can someone point me to a source/purchase point for these iLink mini?
All I'm seeing on the net are the iLink regular.
Frankie - B
Administrator
by Frankie - B
PM sent to Prendrefeu.
BmanX: I'm using the regular I links for the brakes and the Minis for shifting ;)
BmanX
by BmanX
Still lighter than Nokon's I would assume.
I might have to contact my source and get that person to order me the standard for brakes and mini's for shifting.
At least that will keep the look the same.
BIG DADDY B FLOW
ms6073
by ms6073
Frankie - B wrote:I'm using the regular I links for the brakes and the Minis for shifting ;)
So does this mean that the iLink mini's came with a different/smaller diameter teflon liner? I have iLinks brake and shift cables on my bikes and during installation, I do not recall observing any difference in the diameter of the liners between the brake and shift cable sets. In fact, the left over ilinks and unused liner have all been put in the parts bins and both the links and the liner are indestinguishable - black links and off-white teflon liner.
Juanmoretime
Administrator
by Juanmoretime
The one US distributor that I know, procyclingworld, only has silver in stock although they will have all colors in stock within the next couple of weeks.
Yes, the mini I-Links do use a smaller liner and the links and housing are not compatible with the brake if you use the mini.
RESIDENT GRUMPY OLD MAN.
Frankie - B
Administrator
by Frankie - B
Yes, the liners are definitely another diameter. The mini I links are noticeably smaller in size then the regular ones. The regular I-Links use a black liner now and the mini's use a transparent liner.
BmanX
by BmanX
Just a FYI on 1 Meter of Nokon's VS 1 Meter of I-Links
1 Meter of I-Links with 1.2M of liner = 24g
1 Meter of Nokons with 1.2M of liner = 39g
And with I-Link Mini's being lighter, I will be switching over to I-Links on both of my new builds.
BIG DADDY B FLOW
Frankie - B
Administrator
by Frankie - B
1 meter Mini i-link liner and housing 15,5 grams.
BmanX
by BmanX
You are the best. That 15.5g makes me very happy.
BIG DADDY B FLOW
bomber
by bomber
Any online retailer for these as they aren't available in Australia. Looking for black preferably.
Friends don't let friends ride Mavic... or Pinarellos!
My ex ride
My old rides
bcheung
by bcheung
What makes the iLinks so much more of a hassle to install?
Frankie - B
Administrator
by Frankie - B
I'm trying to approach this in laymen's terms as I'm not a native speaker.
Nokons are affixed to the liner as beads to a piece of thread. They don't move around. I-Links on the other hand are already connected and they can somewhat caterpillar like shorten and expand. you need to install it all when everything is compressed, but the strand of I links still can get longer by simply going slack.
I hope this helps a bit, but I think that a native speaker can help a bit better.
wezep
by wezep
I see different colours of the liners.
Black by the normale Ilinks and 'white' by the mini ilinks.
Are there also black liners fo the mini ilinks?
ms6073
by ms6073
bcheung wrote:What makes the iLinks so much more of a hassle to install?
I think this is a matter of preference as personally, I find the Nokon's more time consuming since you have to thread each individual 'pearl' (link) onto the liner. Alterantely iLinks are already 'snapped' together and to install, the user has to first insert the teflon liner into the links which due to the nature of the design allows the ilinks to elongate about .5-1mm per ilink. What happens is when you insert the liner, the ilinks elongate or the end of the liner can snag an inner 'lip' which means you have to pull the liner out a bit then proceed which makes inserting the line more time consuming.
