road schmolke tlo oversize handlebar
elfuinha wrote:Check mcfk handlebar, it's cheaper, the same stiffess (check Fairwheels.com handlebar test), and can choose the finish.
It's also heavier! My TLO (size 42) came in at 146g.
Speedplay is the devil!
To my surprise, OS version is lighter than 26mm version. Last year I bought 26mm version 42cm c-c and they were something like 155g. I can not complain about the stiffness, but stem is what determines stiffness of front end in my oponion. I used them with Extralite and Tune stems. Tune is definitely better choice. Heavier, but much stiffer. Unfortunately, my bike and bars were destroyed and I bought new OS version this year.
I really like this new combination with MCFK stem. Bars were 145g 42cm c-c. Jure Berk joined them together for me and I really like this combination. Much stiffer than what I had. But I do not think that bars itself are stiffer. MCFK stem is great.
But those OS bars are really thick. I do not want to say, that it is good or bad, but when You hold them between shifters for example during climbing, they feel completely different. It is up to You, what You prefer.
But now, I prefer OS version. Much wider choice of stems (with 26m version, only 2 stems are recommended by Schmolke) and they feel great.
Just compare them from my Picture. OS version is nearly twice bigger at middle part than 26mm version.
Martin
Martin
My Wilier Zero7: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=116053
And Ridley X-Fire Disc http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=124026&p=1056055#p1056055
mdeth1313 wrote:elfuinha wrote:Check mcfk handlebar, it's cheaper, the same stiffess (check Fairwheels.com handlebar test), and can choose the finish.
We are talking about less than 15g, depending on the size.
Those this differences really matter for the difference in price.
On a personal matter, I prefer the shape of the MCFK, regarding reach and drops.
About the stiffess on the front end, I've to concord with the answer above, it's about the stem. I've mine bounded by Jure with a Ritchey Surpelogic stem, and it's night and day diference in stiffess, regarding the bolt connection.
