It is currently Sat Nov 25, 2017 9:11 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Oct 11, 2010 12:54 pm
Hello,
I was looking at the Rotor Q-Ring website. I am looking to put Q-Rings on a BB30 Sram red compact. Does anyone know what the difference is between the normal compact Rotor q-ring vs the compact rotor q-ring ocp3 ? I would really like to use the different positions that come with the normal compact q-rings rather than being stuck in position 3 that comes with the OCP3 q-rings.
I have tried a search, but didn't find anything on the topic.
PostPosted: Mon Oct 11, 2010 3:37 pm
The difference is, as you say, that the OCP3 ring is fixed in what's equvalent to position 3 on the normal Q-rings.
The OCP3 ring is also a bit lighter and can be used on Shimano Compact cranks where the crank arm is thicker so a normal Q-ring won't fit.
PostPosted: Mon Oct 11, 2010 9:12 pm
The difference is that a standard outer Q-ring won't fit a SRAM BB30 crank. The inner portion of the ring with all the holes in it hits the back side of the crank arm. The OCP3 ring cuts away that inner ring to make clearance for the crank arm. That is why it only works in position 3- all the other holes are gone. However, I found out the hard way that the OCP3 ring is also much less stiff than the standard ring because that inner portion is gone. I had problems with the chain rubbing on the front D cage. So, I called Rotor and they admitted that the OCP3 ring was more flexible and recommended using either the standard Q-ring or the TT Q-ring and just cutting away the little bit that interferes behind the crank arm. It will still only work in position 3 but it is much stiffer. So, I bought the TT ring and cut out an approximately 1/2" deep by 1-1/4" wide notch behind the crank arm. It now fits and works fine and is much stiffer than the OCP3. I could also make it work with the positions on either side of 3 as well.
PostPosted: Sun Jul 21, 2013 2:06 pm
I'd also like to add that the standard Rotor Q ring can be persuaded to go onto a Shimano Ultegra compact 110 bcd 2011/12/13 crank. The outer ring initially won't fit onto the crank as it won't go past the oversize spiders that Shimano puts on to make the chainring look pretty with their proprietary chainrings but, with a little bit of grinding they will go on then you get all 5 OCP options.
Essentially you'll need a Dremel or similar and about ten minutes. You have to grind away a little of the ring around OCP positions 2 & 4 and when you offer up the ring to go on you'll see it doesn't want to pass over the spiders at the 3.30 & 8.30 o'clock positions, if the crank arm is 12 o'clock (difficult to describe without a drawing!). With some work you can cut two little notches in this position and after a while you'll find it then slides over the spiders. It'll then get stuck on the one at the 6 o'clock position but, if you put the whole lot in a vice and give it a squeeze, it'll pass over. To make the whole lot easier I ground small 'ramps' onto the crank spiders so I didn't have to take as much out of the ring and this helped it to slide over but some may not want to do this as they don't want to mark their original crank. As mine was the charcoal version I used a marker pen to hide the metal colour on the parts I'd ground and the whole lot now works a treat..!
I really don't know why Rotor don't do this themselves as it would save them making two different rings (the OCP 3 and the Standard one) and it'd be a lot less work with their CNC milling machine than it was for me with my ten-quid Dremel and some grinding bits... The metal removed is mere millimetres and has no effect at all on the function or stiffness of the ring.
As the poster above implies, the standard ring is much stiffer than the OCP 3 one and you get all OCP positions although, in honesty, I can't tell the difference between any of them so the point is moot as to whether this really matters.
Finally I'll add my two-penn'orth to the debate as to whether they actually do anything. I can tell no difference at all pedalling or, if I can, it's as likely to be my brain persuading me my 160 euros was well spent as to any real difference in feel or efficiency. I don't climb any quicker nor go faster on my rides. Everything is exactly the same but 'perhaps' they feel a little smoother to pedal. I'm using 50/34 rings, weigh 85kg and live in the Alpes so I climb a lot. I'm a spinner, not a grinder, as many big lads tend to be... The only benefit, and it's a massive one, is my knee has stopped hurting after 500km of riding. I'm an ex-pro snowboarder and have the usual injuries to show for it which include no ACL in my right knee and grade 4 (to the bone) cartilage damage on the back of my kneecap. I partially cycle to keep this strong and to help the arthritis but also to keep weight down. The pain is related to the missing cartilage, not any sort of muscular or tendon injury. Whatever the rings are doing is working as, like a lot of pain, I only noticed it had stopped when I said on my last ride - 'wow, my knee's not hurt me for about a week'. We can't remember pain so you're only aware it stops when one day you notice you're not feeling it any more. Anyway, they seem to have helped this out but I'll only really know if this remains the same with another 1000km or so on the rings. My knee has more-or-less hurt ever since I started cycling again 3 years ago after being a good MTB racer in my youth (I'm now 45). It's never not hurt, only varied between 'really annoying' and 'slightly annoying'. It's now 'non-detectable' but whether this is the rings or, like a lot of chronic pain it's going through a quiet phase, I can't be sure...
Regards, Mark
PostPosted: Sun Jul 21, 2013 9:01 pm
There are spiders like Quarq, for instance, where the OCP3 is basically the only Q-Ring which works, dremeling doesn't unfortunately help in those cases.
PostPosted: Mon Jul 22, 2013 11:14 pm
Agreed about other cranks I just thought that as Shimano Ultegra are such hugely popular cranks (as they are fitted to so many bikes as standard) and likely to be owned by many people wanting to try Rotor rings it seems odd that Rotor would not machine some small notches into the standard ring to make it fit this crank, as it doesn't affect their functionality at all. The OCP 3 ring could then be used for cranks that have other protrusions on them, not just outsize spiders. It might help them sell a few more if Ultegra (and probably 105) owners knew they could try out the rings with full functionality without needing to shell out on new cranks if they later want to try the different positions.
Just a thought, or use the Dremel, as I did...
Cheers, Mark
PostPosted: Mon Nov 21, 2016 9:24 am
Regards, Mark
Hi are you still running the Q Rings and hoe are the knees ?
There are no new unread posts for this topic. Convert Rotor QXL to single front ring
hanzypanzy
Wed Feb 08, 2017 10:50 am
hanzypanzy View the latest post
There are no new unread posts for this topic. SRAM Centerlock Rotor Lock Ring?
Samklee15
7
1528
Mon Dec 19, 2016 7:36 am
Samklee15 View the latest post
There are no new unread posts for this topic. New chain ring recommendations
bpe
Fri May 12, 2017 7:38 pm
jrobart View the latest post
There are no new unread posts for this topic. removing logo from chain ring
Timujin
Fri Mar 10, 2017 8:23 am
marynoland View the latest post
There are no new unread posts for this topic. SRAM RED GCP Cranks & Chain Ring WEight
RezaTrek2200
12
1518
Sun Dec 04, 2016 10:28 am
mythical View the latest post
Users browsing this forum: jlok, PinaF8 and 27 guests
