Juan
I use a twister bb but that's on normal pulsion, not the CT-2 cranks...
Hope that helps
Cheers
Stronglight crank users question.
can't tell you off hand, will have to go home and double check...sorry
The stronglight bolt is 15mm. American classic 144gram bb uses a 15mm.
Or you can just get some 14mm bolts if you want to keep your current bb. Using the stock al FSA bolts will save you a few grams too.
The internal threading is standard. Any ISIS puller will work on it.
Also remember you will have to modify a shimano tool to get the crank bolts out. The holes are just a little too far apart
The FSA BB with the standard 14mm bolts works fine with the Stronglight.
That's what I use.
Just struggle to remove the Stronglight bolts, and put the FSA in place.
I used a needle nose narrow tip plier in the holes to get the Stronglight bolts out of the crank.
What a pain!!!
Standard extractor works fine.
That's what I use.
What a pain!!!
