It is currently Wed Jan 17, 2018 4:24 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 465 posts ]  Go to page Previous 124 25 26 27 2831 Next
PostPosted: Sat Feb 26, 2011 11:59 pm
jwilliams wrote:
Madfibers claim a 2nd in the PRO race in San Diego this weekend, the guy who took first was 17 years younger !!! and on a Time RXR.
ahh, the Pista Palace Team. The guy who won has a twin brother on the same team who I used to go to school with. Good to see him doing well. :beerchug: and cool to see a relatively new wheel doing well in real-world race situations.
also, here's a video of Madfiber that roadbikereview put up for NAHBS:
http://www.youtube.com/watch?v=g9pjSP97PNc
bike / strava / instagram
PostPosted: Sun Feb 27, 2011 12:34 am
bluhorizan wrote:
Still wonder why they went with a full 60 mm/ 66 mm wheel profile rather than a more all around 45 mm profile. Could the structure be inherently stronger with the shorter, flat spokes.
Pez already addressed this. Spokes are glued to the rim so the angle for attachment is better with deeper rims, he says. Unclear to me from this photo:
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sun Feb 27, 2011 1:29 am
Yep, I'm not really seeing the angle being an issue... seems like gluing the spoke to the opposite side of the rim would be best if that was case.
PostPosted: Sun Feb 27, 2011 2:11 am
Spokes are glued to the opposite side of the rim, and the rim depth was chosen so that the spoke interfaces at the same angle as the rim. This results in a joint that is loaded in pure shear, as adhesive is strongest in shear. You want to avoid tensile stress, and more importantly, peel stress, in adhesive joints.
PostPosted: Sun Feb 27, 2011 2:12 am
The spokes and rim are bonded in a very wide contact patch to the opposite side of the rim to the hub. They pull directly in line and the angle is an important part of the structure...
It's not really accurate to describe it as glued to the rim... There is a lot of material at the transition from rim to spoke spreading the load to a very large portion of the rim.
charles@pezcyclingnews.com
PostPosted: Fri Apr 15, 2011 7:42 pm
I think it's great that Madfiber is giving LW, Reynolds, and Mavic a run for their money because in the end, riders are going reap the benefits. $2,600 is a steal (relative of course) and will hopefully drive carbon wheel prices down. :P
PostPosted: Sat Apr 16, 2011 3:17 am
Should add a 1k or 3k fiber range to complete with LW Or Bora. The stickers are crap as well. They will get this right someday and move up the ladder of high end wheel
PostPosted: Sat Apr 16, 2011 3:21 am
Why'd they use a 90 degree weave pattern for the spokes? Tension is only being applied in one direction so it would be lighter to use unidirectional carbon for the spokes.
PostPosted: Wed Apr 27, 2011 4:56 pm
Interesting review...not sure if it was posted or not...
http://www.bikeradar.com/gear/category/ ... lset-44586
Thing 1 & Thing 2 & Thing 3
PostPosted: Wed Apr 27, 2011 5:46 pm
Some observations:
Spokes seem to be under-tensioned if they are becoming unloaded during typical riding conditions. This will adversely effect stiffness.
Oscillations at 35-40 mph... caused by imbalance... and all light rims do this?
The WI hub design with the set screw and collar isn't inherently problematic, but I don't know about this application.
PostPosted: Fri Apr 29, 2011 3:07 pm
Are you asking this or stating this?
PostPosted: Fri Apr 29, 2011 4:59 pm
Did you read the review? That's where I got it.
PostPosted: Fri Apr 29, 2011 8:59 pm
I wasn't sure if you were agreeing with them or not.
PostPosted: Sat Apr 30, 2011 4:50 am
Cosmetic layer?
Custom English Cycles CX Bike
BMC SLC01
PostPosted: Sun May 01, 2011 12:53 am
So what happens when a spoke or two gets mangled? Is is repairable like a regular tubular with spokes where a rebuild is just done and away you go? Or is it an expensive conversation piece now of what once was?
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1960
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. If I buy new wheels
in Everything wheels
Bostonbull
Wed Aug 30, 2017 7:45 pm
Bostonbull View the latest post
There are no new unread posts for this topic. FSE wheels?
[ Go to page: 15 6 7 8 9 ]
CrankAddictsRich
128
18453
Sat Dec 09, 2017 8:11 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Wheels for a fat lad
merser
26
1611
Tue Jun 27, 2017 1:16 pm
WinterRider View the latest post
There are no new unread posts for this topic. Big man wheels
merser
Sun Jun 25, 2017 9:51 pm
spud View the latest post
Users browsing this forum: Bing [Bot], jfranci3, prebsy and 7 guests
cron
