Post new topic Reply to topic  [ 76 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Best Road Crankset
PostPosted: Thu Aug 05, 2010 8:54 pm
I like to try and be totally honest with people, even if it upsets some of the manufacturers. We sell a fair amount of lightning cranks, but no more than we do of any other crank, and we've had more Lightning cranks returned than any other. On the plus side, the guys at lightning are usually really good at taking care of problems with their cranks. We do not see an unacceptably high number of them returned, and they aren't returned because of catastrophic failure(it's usually qc issues like pedal inserts being a little crooked.) The think about lightning is that they are good cranks if you get a good one. But you have a higher chance that your first one may not be.
As for the Clavicula being overpriced: I showed a clavicula to a friend who is a carbon engineer for Trek. Typically when he sees things it's the usual response in that it's nothing special. Most companies do the same things, with the same techniques and same materials. However when I showed him the Clavicula his response was, "wow, they've really done something amazing." He went on to explain about all the different things he could see that made the crank special, and that was without even cutting it up and looking at the rest of it. Of course that doesn't mean it's a perfect crank either, it's still a little delicate and still a little wide. However it may not be so overpriced if one knew what actually went into making one.
Still as I see it, every crank has pros and cons and you just have to decide the characteristics that are most important to you. Make a list and rank those criteria and then put the 3 cranks the fill each criteria in order of how they fill the need. When you're done average out your answers and see which crank fits your needs best.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Thu Aug 05, 2010 9:15 pm
to be honest
if the clavicula had interchangebel spiders i would have it
also i need to have 30mm axle crank that fit in all type of frames
i have a carbon spider in 130mm and a black alu 110mm
add the same weight and much lower price and you cant go wrong
naturly for that you get less technology then the crank almost 1,5 x more in price
but for a mortal like me it works
i always had fibre lyte chainrings on my DA7800 and record crank, also new ones on my current lightning crank :wink:
edit: changed fibre lyte into lightning :oops:
Join the light side
a light bike does make you go faster unless you are slow
PostPosted: Thu Aug 05, 2010 9:53 pm
tochnics wrote:
i always had fibre lyte chainrings on my DA7800 and record crank, also new ones on my current fibre lyte crank :wink:
Fiber-lyte makes a crank?
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Fri Aug 06, 2010 10:24 am
Nope, it was a mis-type (see above) :wink:
I doubt that we could do any better than what is already available and the market is fairly swamped. I'm always impressed with smaller manufacturers coming out with new cranks (whether I like the crank or not) as it's a seriously competitive market.
PostPosted: Fri Aug 06, 2010 10:49 am
Anyone have a bit more info on the Powerarms SL. They're a bit hard to come by in the UK. The only guys I've seen who might sell them are poshbikes and I'm still waiting for them to get back to me.
As well, does anybody have any real experience with them. Any problems, support issues etc. At the moment, I'm down to either the Powerarms or the Vuma Quad, they're the only ones that seem to tick all the relevant boxes.
It's been mentioned in madcow's crankset shootout that the Clavicula has reliability issues so I'm a bit iffy about them, any thoughts on this?
K2
Do you suffer more when you train, or cannot train?
viewtopic.php?f=10&t=83160&p=727610#p727610" onclick="window.open(this.href);return false;
PostPosted: Fri Aug 06, 2010 7:35 pm
I don't mean to be rude but if you couldn't actually see it, I reckon you couldn't tell if you were riding a real cheapo chainset or a helium filled carbo-titanium jobbie. If you just want expensive bling then buy it. I don't think it's going to make you faster; bigger legs & lungs will do that!
PostPosted: Fri Aug 06, 2010 7:49 pm
To me, it always comes down to the best bang for the buck. Recently, I was putting together a bike for a personal project, and I wanted to keep costs as low as possible. I needed a few SRAM Red parts, lower than cost. I can get the whole group for not that much money, but I didn't want to be stuck with extra parts in stock.
I ended up buying them on WW and they were a good deal. I paid $250 for a new SRAM Red crank (this is quite lower than cost). In my mind, this was a great deal because of the price.
This being said, of the cranks mentioned here, I'd probably want to try the Zipp VumaQuad next. Actually, I'll probably order one when I decide on my next frame. They have some new chainrings, or so I was told, which will make shifting that much smoother.
So in essence, if someone is trying to get a deal on parts, they should check out the for sale section on different forums and buy some stuff from other roadies. That saves a lot of money.
Range || range.wordpress.com
Asterisk*Cycles
'10 Velocite Millennium Elite SRAM Red
'11 Velocite Geos w SRAM Red || '08 Giant Anthem X0 w SRAM X0 || '93 Pinarello w Shimano 105
PostPosted: Fri Aug 06, 2010 7:55 pm
7900 is the best.
Mass Weenie
PostPosted: Fri Aug 06, 2010 8:04 pm
I run Campy Super Record cranks and Rotor 3D cranks. Both are very nice, but the Rotor cranks simply look awesome and are just as stiff.
PostPosted: Fri Aug 06, 2010 11:11 pm
sgray wrote:
I switched to the Easton EC90 crankset and love it, shifts better than my old DA 7800 crankset and around 100g lighter. And you can pick one up in the $400's.
Scratch the EC90 recommendation, mine failed too yesterday. Same problem as everyone else, the spindle has come loose from the drivetrain side. The day after I posted a recommendation for these they failed, go figure :roll:
...and now they're discontinued.
PostPosted: Fri Aug 06, 2010 11:31 pm
I sure love my Campagnolo Chorus carbon crankset.
PostPosted: Sat Aug 07, 2010 12:08 am
This is not Cyclingnews forum, but Weight Weenies. Please make up if you want to actually contribute to anything here except from making blanket statements... :roll:
FWIW, The gram to dollar/euro/pound/etc ratio is very good on lightweight cranks compared to frames and wheels.
PostPosted: Sat Aug 07, 2010 11:30 am
From what I gather they're a bit in short supply. Poshbikes are the UK distributor so if they don't have any chances are that no one else in the UK will.
PostPosted: Sat Aug 07, 2010 11:02 pm
im looking at upgradeing my crankset but i just dont know which one to get i like the dura ace carbon but id like either the clavicula or the ax i think it will boil down to which i can get when the time comes.
PostPosted: Mon Aug 09, 2010 7:58 pm
7900.... or if you want to show your friends that you know something about engineering stiffness then go 6600... that crank is known for its AWESOME absolute rigidity. This is a FACT.
Mass Weenie
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: addictR1, Bing [Bot], mdeth1313, nickel, ninjanoir78, Yahoo [Bot] and 51 guests
There are no new unread posts for this topic. s works crankset
cymans
9
1071
Thu Apr 04, 2013 3:25 am
Gearhead65 View the latest post
This topic is locked, you cannot edit posts or make further replies. New RED crankset is ordered, which bb should I get ?
Wadl
Sun Sep 09, 2012 9:38 pm
Frankie - B View the latest post
There are no new unread posts for this topic. Crankset or wheelset?
Bianchi10
11
858
Sat Jan 26, 2013 8:04 pm
kgt View the latest post
This topic is locked, you cannot edit posts or make further replies. Crankset recommendation
deepakvrao
Fri Apr 19, 2013 9:16 am
deepakvrao View the latest post
There are no new unread posts for this topic. BB386 BH ultralight, what crankset will fit?
Fred72
Fri Feb 08, 2013 5:49 pm
Fred72 View the latest post
It is currently Sat May 25, 2013 11:58 pm
