Post new topic Reply to topic  [ 4257 posts ]
Go to page Previous  1 ... 241, 242, 243, 244, 245, 246, 247 ... 284  Next
PostPosted: Sun Dec 30, 2012 7:34 am
Zen Cyclery wrote:
@notsoswift-
There are a few options you could go with. The Kinlin TB25 may be a good first option. They are quite rigid, and they haven't had any of the brake track issues that other Kinlins did in the past. If you wanted to go with something made in the US, you could go a Velocity Major Tom. That would be a bit wider than the Kinlin which may help to enhance ride quality a bit.
Thanks Zen, I had thought of Velocity (as an Aussie!) but not really happy with the weight for the strength... Didn't think of Major Toms, only V2 aero profile which are really heavy and Escape which is a bit weak (considering weight) better with Reflex for that or little heavier for Nemesis
Will investigate Kinlin further
I will run Veloflex Extremes, so would be interested in anyone who has run Major Toms with them (or the HED wide rim)
PostPosted: Sun Dec 30, 2012 7:42 am
Oh and one more (stupid) question
Does any one know if you can get Brass nipples in, well, brass?
I have only seen silver and black, lot of Alu colours, but not brass, since these are all weather wheels I think it would be better so no corrosion issues
PostPosted: Sun Dec 30, 2012 8:11 am
Have you considered Crono F20's?
Storck Fenomalist 6.8kg
PostPosted: Sun Dec 30, 2012 9:17 am
DividedVolta wrote:
Alright, I'm trying to make my final decisions before buying all the parts for my wheel set. Goals are a light weight clincher wheel set built with climbing in mind. Original suggestions pointed me toward the Kinlin XR-200's, but thinking about a slight aero/stiffness advantage has me thinking of the XR-270's, so I wanted to ask about them. Please critique my builds below. As background, I weight right around 70kg/155lb consistently and enjoy climbing (hill sprints even more ....
I think it will be ok 24 front 28 rear for your weight. Better as with all Cx Ray back is RACE on DS and other can be CX Rays (or Lasers).
24 2xcross front, 28 DS 3x cross; NDS 2x cross and it is very solid wheelset.
Weight will be around 1350g (black rims, add around 10g for each white rim)
And try with KoolStop Solmon breakpads (Shimano black works too) - it will be pulsing but later will gone
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
PostPosted: Sun Dec 30, 2012 10:18 am
Online
Hi All, I have the ProLite Bracciano wheelset and the Rear Hub bearings have noticeable play, so I need to replace the 2 x 6901 bearings.
The issue I have is that I do not have a bearing puller to remove them ... is it easy to get hold of one of these?
If so, please let me know where can I get one ...
Or, is there another way to easily remove them without damaging the hub, axle, or even the bearings that I will be replacing ...
thanks in advance ...
PostPosted: Sun Dec 30, 2012 4:12 pm
@notsoswift: another nice box section rim is the Ambrosio Montreal. Falls right between the Chrono F20 and Nemesis in weight; same dimensions -- thicker walls than Chrono, thinner than Nemesis. It doesn't have the cool laser etching of the Nemesis, but unless someone is big (which you aren't) or riding really crappy roads the Montreal is more than enough rim.
http://dormancyclery.mybigcommerce.com/ambrosio-montreal/
@zen: I'm thinking 24/25mm tubulars (Veloflex Roubaix, Challenge Strada(, maybe even 27mm Vittoria Pave CG and looking for folks with actual experience
PostPosted: Sun Dec 30, 2012 6:11 pm
divided volta the XR-200 build I have dissucess is 1362g not 1330-1350g. At least that what my set weigh. I am 79kg and have no issue yet.
The XR-270 however will be stiffer no bad thing. I have not got a Xr-270 to measure the ERD but based on the publish ERD a 28 spoke rear laced 2x will have DS lenght of 278mm and NDS length of 282mm. The front wheel will have lengths of 287mm laced 2x and 279mm laced radialy. The XR-270 is stiff enough to build with Laser on both sides of the rear wheel but using race spokes DS certainly does not hurt. I normally do this unless the customer is of low weight.
Why not use the XR-200 on the front anf the XR270 of the rear. At 70 kg though the XR-200 should be fine unless you are a power station.
www.thecycleclinic.co.uk
PostPosted: Sun Dec 30, 2012 9:42 pm
bm0, I was just going off of published weights and basic addition. Just threw out a range from rough estimation, really. I like the idea of a 200 front/270 rear; in fact I think that settles it and I'll do that. Best of both worlds kind of thing.
I'm definitely not a power station, just run my brakes tight and hate hate hate rub. Thanks for all the input, now it's time to buy everything and put it together.
PostPosted: Sun Dec 30, 2012 11:23 pm
Can't seem to get them readily?
Maybe a bit on the light side for what I want as well, I am a 85kg sprinter and these will be all purpose wheels although that includes those wet and windy races where my race carbons are not the best (Reynolds 46mm)
@teleguy Montreal maybe a good balance, especially with 32 spokes to keep it all together
PostPosted: Mon Dec 31, 2012 2:25 pm
Long time lurker needing advice.
My Easton EA90 SL's have died. Nipples on the front cracking after trying to true them.
Is it worth rebuilding the Easton R4 hubs (2009 version) with an Alloy Kinlin / HED rim?
Looked at Tune, Alchemy hubs but then realised I'm no Wiggins and probably a Novatec A291SB-SL front & F482 SB-SL rear would do with the right rims. I know little about the Novotec hubs, will they build a strong and rigid wheel for a 80kg rider (similar/same as a Tune or Alchemy hub)?
Alloy rims, probably a Kinlin 200 F 270 R, laced with cx-ray 24/28 2 cross all round? Or a HED C2 - H+ Sun rim.
I'm open to opinions on the R4 hubs and basic good/bad options on the new build. Once I've done more research I'll post what I think I'll go with.
Cheers.
PostPosted: Mon Dec 31, 2012 3:31 pm
Cheers.
It depends on the condition of the Easton R4 hubs. You could mail in the hubs to Prowheelbuilder.com and have them build a wheel around it using HED C2 rims with spokes of your choice.
But, I just ordered a HED signature wheelset from Prowheelbuilder.com with HED C2 rims, White Industries T-11 hubs, and Sapim CX-Ray spokes for $570.
Mark
2011 Cannondale Quick CX-1
2012 Lynskey Helix OS with SRAM Red
2013 Lynskey R330 with SRAM Red Quarq
2013 Parlee Z1 with DA 9070
PostPosted: Mon Dec 31, 2012 3:54 pm
If the R4 hub has the spokes that thread into the hub it's not worth using them in another build. You can get spokes from Easton but they are not cheap.
In any case if the hub and rim are still good you could just replace the nipples while leaving the spokes in the same position. The wheel might not be quite as reliable as a new build using new parts but if the spokes are left in the same position it's no worse than removing tension and re-tensioning the wheel. Not like reusing spokes in a new pattern.
That'd be cheap and would leave you money to buy parts to build another set of wheels.
PostPosted: Mon Dec 31, 2012 11:15 pm
Online
Hi Eric, need some advice ... for a 90kg rider, using a BHS SL218 Rear Hub and Velocity A23 rims, would you recommend a 2:1 hub/spoke pattern or a more traditional hub/spoke pattern. If you recommend a traditional hub/spoke pattern, what would you recommend, eg. 1ds2nds, 2ds2nds, 3ds2nds, etc ... thanks :-)
PostPosted: Mon Dec 31, 2012 11:52 pm
I haven't tried a 2:1 wheel yet. The BHS hub has the NDS flange spaced farther out than many normal hubs but not as far out as a hub specifically designed for 2:1. Given that, lacing it 2:1 would result in a wheel that has less lateral stiffness than 1:1 lacing. It depends on your riding style as to whether that's a problem for you. It is for me and I weigh a lot less.
I'd only do 1x if you're lacing the DS all heads in. Otherwise 2x at least. The NDS flange on these hubs is pretty small and I don't know if you can do 3x @ 28h without bending the spokes. All mine have been 1x heads in or 2x. Brandon @ BHS would know if 3x will work.
1x heads in increases lateral stiffness. But depending on your derailleur and frame there can be clearance problems. My experiment wheel (BHS 218 hub) worked with no issues with a Shimano 7900 derailleur but when I changed to Sram Red the clearance between the derailleur and spokes was tight and the spokes would ting on the cage as the wheel flexed when I was out of the saddle. I ended up putting a second 1mm spacer under the cassette which took care of it. Interestingly that also made the cassette line up with my race wheels (White Ind hubs) so I could swap wheels without adjusting the derailleur.
PostPosted: Tue Jan 01, 2013 7:36 am
Online
Do you think a 2.1 pattern could be done with a 40H Hub/Rim. ie 20dDS/2x 10NDS/Radial. If so, what hub would you use ...
Post new topic Reply to topic  [ 4257 posts ]  Go to page Previous  1 ... 241, 242, 243, 244, 245, 246, 247 ... 284  Next
Users browsing this forum: 573, Imaking20, KLabs and 2 guests
There are no new unread posts for this topic. Wheelbuilding tool - Nipple Starter
runner999
Sun Mar 10, 2013 10:13 am
MajorMantra View the latest post
This topic is locked, you cannot edit posts or make further replies. Sale Thread...?
kevinkalis
Thu Jul 19, 2012 8:13 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Another which frame for me thread..
Colin
Sat Jan 05, 2013 10:30 pm
Colin View the latest post
It is currently Thu May 23, 2013 2:17 pm
starbike.com wheel building service
