Post new topic Reply to topic  [ 4256 posts ]
Go to page Previous  1 ... 221, 222, 223, 224, 225, 226, 227 ... 284  Next
PostPosted: Tue Oct 16, 2012 6:43 pm
@Simon- Dropping to a 24/28 hole count should be just fine for your weight. I like the idea of 2x front/rear nds, 3x ds as well.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Tue Oct 16, 2012 9:08 pm
@Simonhi
I will add my few cents.
3 days ago I built the set using the same rims, I'm slightly heavier than you.
After over 200m I can say 24/28 is more than enough. These rims hold very nice, dead straight.
Front radial (my choice), rear 3x (as advised by Zen..thx!)
You will be surprised how amazing these rims are.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Wed Oct 17, 2012 12:41 am
Hypothetical questions about a future rear wheel for myself...
With the new Off centre A23 coming out, I'm wondering how much strength advantage would the OC give (assume same hub and spokes)? Would it, say, likely be as strong as the H Plus sons archetype rim, which is ~20g heavier and with a deeper profile? Or would the reduced spoke length of the latter and deeper rim make up for it?
Also, I was thinking of a couple of other potential options...
1. Alchemy Orc laced 32 with A23 OC rim, say, DT Swiss Alpine III 3x DS, 2x Revolutions NDS.
vs.
2. Alchemy Orc laced 32 with BHS 472 rim, lazers (prob 3x).
The BHS has maybe a rim strength advantage, but weaker spokes esp DS. The A23 OC has an advantage with spoke tension and length equality, as well as spoke strength (DS). Both would come out with a similar weight, but the A23 option has less rotating weight at the rim where it has most effect.
I'm just guessing here, but, based on the above I'd possibly be better off with the latter combo, or would the extra rim strength really be more important than the spokes?
EDIT: Oh yeah, I weigh about 185lbs (85kg), will use it mostly road and bike paths. Will be towing a baby trailer too with it in the near future, though that wouldn't add too much stress to the wheel as they are well balanced (Burley). I also run 28mm tyres and happy to run slightly fatter with the trailer if I need to (got the brake/frame clearance).
PostPosted: Wed Oct 17, 2012 3:28 am
Looking for some advice. I am building a whelset using velocity escape tubular rims. I have an extra 32 hole rim and am thinking of using it as a front 16 hole wheel for pretty much smooth roads, meaning no dirt, no cross, no pave. For a 160 pound rider.
Any idea if this is workable? I'm still pretty old school and think of 24 holes as pretty dicey but I do have a cheap set performance brand clinchers that have held up to quite a bit of abuse with 16F20R, of course those rims likely weigh quite a bit more.
PostPosted: Wed Oct 17, 2012 10:14 am
@ oysters The A23 OC will be a nice rim to use but will simply allow lower drive side tensions to be used for Campay 11 speed compatible hubs and new shimano 11 speed hubs. That will help the rim but not stiffness so much.
The rim selection does not increase or decrease the strength of the spokes. Spoke strength is determined by the spoke itself. A spoke durability depends on many factors such as guage, diameter at elbow, how even the tension is, count count... the rim is not a big factor here unless you choice a flexy rim and too a low spoke count for your weight.
A 20g rim wieght difference does not make too much difference to the moment of interia of the wheel. The tyre choice has a bigger effect on that.
I would not consider closer spoke length difference an advantage when using an A23 OC and advantage or disadvantage.
the shorter spokes in the archtype wheel set will result in a slightly stiffer wheel anyway.
So the Archetype rim will be still be a stiffer rim and build a stiffer wheelset compared to an A23/A23 OC on the same hubs with the same gaugue spokes, same spoke count and lacing pattern. But if you are using a 11 speed hub the A23 OC could be a better choice.
With the Alchemy hubs the better tension balance given by the OC rim is not really needed or the Archetype rim will be fine with a 50% tension balance.
Goi with the archetype it has the same width as the A23 doesn't it.
Styurll A 16 spoke front wheel really need a deeper V rim for lateral and radial stiffness. You may find even with your low weight a bit too much front wheel flex and short spoke life. I personally would not built a 16 spoke wheel. I think 20 spokes is low enough. Lower needs a heavy rim V rim.
www.thecycleclinic.co.uk
PostPosted: Wed Oct 17, 2012 11:43 am
Cheers for the advice guys, re: lesser spoke count on Archetype rims.
Decided in the end to go 28 hole front and rear (3x all round)
Mainly due to the fact that the grey anodized rims are only available to me in 28 hole drillings. Was going to go 2x on front and rear NDS but decided to keep things classic afterall as the wheels will be on a modern classic lugged steel bike.
Will post pictures once wheels are built (ASAP) and frame arrives (Jan 2013)
Thanks again,
Si :-)
Enigma Echo
PostPosted: Wed Oct 17, 2012 12:00 pm
I have to say I like that colour you have choosen. Very classy rims.
PostPosted: Wed Oct 17, 2012 2:08 pm
I really like the all grey of my Ambrosio Nemesis rims and wanted a similar looking wheelset, plus Royce Hubs with the Royce QR Skewers !!!
Building with silver CX-Ray spoke should fit my new modern classic bike they are planned for but will also not look out of place on my Enigma.
Enigma Echo
PostPosted: Wed Oct 17, 2012 7:26 pm
Hey guys :D I'm new here and have been contemplating building a new wheel set. Right now I'm using a pair of rs10s that came with my CAAD 9 and was planning on attempting to build a lighter wheelset. I'm kind of been fluctuating between 175 and 180 pounds lately and I'm curious if any of my options would work for me. Since this would be my first build I'm kind of on a budget and if the build goes well then I'd be willing to start building more expensive quality wheels. So far I've been thinking of:
1) Kinlin 270 Rims (24h/28h or maybe 20h/28h), Circus Monkey or Dati Hubs, with either laser or cx ray spokes
2) Kinlin xr19w Rims(still thinking of spoke counts for this one since its the lightest wheel), Circus Monkey or Dati Hubs, with either laser or cx ray spokes
3) Velocity Aerohead and Aerohead Oc Rims(24h/28h), Circus Monkey or Dati Hubs, with laser or cx ray spokes
4)Stans A340 Rims, Circus Monkey or Dati Hubs, with laser or cs ray spokes
I think these combinations would range close to the 1350-1400g range and was hoping they would work out for somebody my weight.
Any suggestions on hole count or maybe other combinations that would work are greatly appreciated.
PostPosted: Wed Oct 17, 2012 8:35 pm
There is one component on your list I would advise you to stay away from:
viewtopic.php?f=3&t=79202&start=30#p921981"
Just for clarification: Dati hubs :!:
PostPosted: Wed Oct 17, 2012 8:40 pm
@visionz-
I am somewhat of a skeptic of the XR19w. The fact that is has a lower max tension rating than the rest of the Kinlin lineup makes me question the rigidity and durability of the build, particularly on the rear non drive side. I would think that spokes would be prone to going slack under load (causing early breakage) simply because of the low tension on both the DS and NDS.
I think that the most sensible option would be the XR270 or the new A23 OC. Both of those (the 270 in particular) would be much more rigid than the XR19w. The 340 could be a good option as well, but when it comes down to it, I would pick the A23 over the 340 almost every time simply because I think it is a more well made hoop.
Which rim is going to be ideal for you depends completely on the terrain that you ride. If your climbing all day long, the 340 would probably be the best option. If you ride pancake flat every day, the 270 would be your best bet. For a do it all hoop, its going to be hard to beat that A23.
PostPosted: Wed Oct 17, 2012 9:25 pm
Well that cuts it down for me quite well then. Sounds like the 270 or the a23 rim with dati hubs instead of the circus monkey. What would be the best hole set up for somebody weight? The wheel I've been using Were doing good for quite some time and were 20f/24r but then again it is a heavier wheel. Btw the roads I usually rode are moderate rolling hills. Im pretty weak at climbing wheels but i'd like a set that could help me improve at climbing
PostPosted: Wed Oct 17, 2012 9:50 pm
Well I haven't worked with the hubs your choosing, so I can't speak for those. But if this were one of my builds, I would recommend a 24/28 for your weight. You could even get away with a 20/28 seeing as front wheels are usually much more rigid than rears.
PostPosted: Wed Oct 17, 2012 10:12 pm
that sounds perfect to me :D thanks a lot for the suggestions. I'd really like to be able to use better hubs but since its my first build I figured I probably shouldn't spend too much in the case that it doesn't go as planned. Although if the build goes well I can see myself building myself an extra set of wheels with much better parts.
PostPosted: Wed Oct 17, 2012 10:15 pm
I would also build with the A23's or the XR-270 rims. You will probably be fine ona 24F/28R with the A23's. I can say this as I have a RR415 wheelset 28F and 28R and the rear give no issues and I am 176lbs. The RR415 is another good rim but is eyeleted light weight and is not as stiff as the A23. The rear wheel even seems fine and stable while respecting the 1100N tension limit with a Miche hub (11 speed compatible). You can only have 28 or 32H drillings though.
The Kinlin XR-270 will be more than fine with 24F/28R spoking. You could try the XR-300 as well.
To give you an idea on weight a pair of wheels using XR-300 20F/24R with Novatec A291SB/F482SB hubs were 1484g in weight with CX-ray spokes. I doubt the XR-270 wheelset will below 1400g in weight unless the hubs are crazy light. The A23 wheelset will not be much lighter as the rims are a similar weight. The ones I have in at moment are about 440g.
Post new topic Reply to topic  [ 4256 posts ]  Go to page Previous  1 ... 221, 222, 223, 224, 225, 226, 227 ... 284  Next
Users browsing this forum: Orfitinho and 4 guests
There are no new unread posts for this topic. Wheelbuilding tool - Nipple Starter
runner999
Sun Mar 10, 2013 10:13 am
MajorMantra View the latest post
This topic is locked, you cannot edit posts or make further replies. Sale Thread...?
kevinkalis
Thu Jul 19, 2012 8:13 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Another which frame for me thread..
Colin
Sat Jan 05, 2013 10:30 pm
Colin View the latest post
It is currently Tue May 21, 2013 8:45 pm
starbike.com wheel building service
