It is currently Mon Jan 22, 2018 9:33 am
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3
 Post subject:
PostPosted: Sun Jun 12, 2005 8:24 am
I read somewhere on the internet that Richard Sachs and Serotta uses like a 8 cm bottom bracket drop that gives a lower center of gravity and gives that handling quality.
Does anyone have an idea of the weight of Aermet frame? Or a link to a manufacturer? TIA
PostPosted: Sun Jun 12, 2005 2:01 pm
Miranda wrote:
Hello,
With all the talk about lightweight premium steel road frames what about Waterford's flagship R33? Does anyone have one? Do they have a good balance regarding racing performance and putting in those long training miles? Durability?
Regarding classic steel how about one made by Chris Kvale in Minneapolis?
I havent heard anything bad about Waterford but only praises. That goes same with Chris's work.
 Post subject:
PostPosted: Sun Jun 12, 2005 3:16 pm
Nobody has built with aermet for years from what I gather. This stuff is super strong and hard. It can not be drawn for that reason. You can only make seamed straight gauge tubing. A .5 straight gauge tube is slightly heavier than a .7/.4/.7 butted tube. In other words, this material will not yield the lightest road frame possible. Weights are comparable to the lightest straight gauge ti frames: 1350 to 1450g for an aermet frame is reasonable.
It is still a very interesting frame material. It could make very nice trials frames for instance. Would any weight weenies be interested in an aermet 310 frame? If there is a demand for this stuff, I could get a custom order from Cartech.
The aermet frames from the past were the aermet 100 alloy. Aermet 310 is 15% stronger and harder!
 Post subject:
PostPosted: Sun Jun 12, 2005 3:21 pm
All well and good, but with this tubing, don't you give up some of the great steel ride? Seems like if it's that stiff, you might as well go Al.
A little compliance in a frame is not a bad thing.
 Post subject:
PostPosted: Sun Jun 12, 2005 3:28 pm
All steel has about the same stiffness, from mild steel to this stuff. Aermet has a young's modulus of about 28ksi just like every other steel I know of. You certainly would not be giving up the great steel ride
Al??? This stuff is 6 times stronger than most Al used in bike frames.
 Post subject:
PostPosted: Sun Jun 12, 2005 3:34 pm
De Rosa has also a very nice steel bike! Beautifull!
 Post subject:
PostPosted: Mon Jun 13, 2005 11:11 pm
Location: somewere floating between here and the other side
NEO PRIAMTO,
verry stylische indeed !
 Post subject:
PostPosted: Tue Jun 14, 2005 2:24 am
All else being equal, yes. But with the stuff you're talking about, it may be different because of the tube thickness?
 Post subject:
PostPosted: Tue Jun 14, 2005 2:46 am
The strength to weight of aermet is till atleast twice as high as most aluminum. Atleast any aluminum I know of that is readily weldable.
A 0.5mm thick aermet tube is much beefier than a 1.5mm thick Al tube or even a 0.75mm think Ti tube.
 Post subject:
PostPosted: Tue Jun 14, 2005 2:52 am
I'll have to take your word for it, because I know very little about aermet. All's I DO know is: steel is good!
There are no new unread posts for this topic. Steel, Stainless steel or Titanium ?
stormur
18
2090
Sun Dec 31, 2017 10:07 am
stormur View the latest post
There are no new unread posts for this topic. Is carbon lugged dead? Have modern monocoque frames usurped carbon lugged frames outside of just weight?
tranzformer
Sat Jul 22, 2017 4:14 pm
spartacus View the latest post
There are no new unread posts for this topic. Colnago steel - From 10s to 11s .. what to watch out for ?
Kupepe
Wed Mar 29, 2017 8:24 pm
shimmeD View the latest post
There are no new unread posts for this topic. 1980~ Steel classic.
Littlemad
Tue Nov 21, 2017 11:50 am
Littlemad View the latest post
There are no new unread posts for this topic. Steel OR Carbon / Calipers or Disc
stevenak
16
1433
Mon May 22, 2017 11:46 am
Fixie82 View the latest post
Users browsing this forum: AdsBot [Google], Alex2012, Attermann, Bing [Bot], ewwhite, Google Adsense [Bot], Hastur, vladi78 and 35 guests
