It is currently Tue Jan 23, 2018 11:12 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page 1 2 3 Next
 Post subject: Steel frames
PostPosted: Fri Jun 10, 2005 2:05 pm
Hi
Is it possible to build a ww bike around a steel frameset?
Any reccomendations for a steel frameset?
What do guys think of Pegoretti frames?
Cheers
Vinny
My '05 Rockhopper... http://photo.pinkbike.com/photo/415/pbpic415284.jpg
My '95 Giant CFR... http://photo.pinkbike.com/photo/488/pbpic488002.jpg
 Post subject:
PostPosted: Fri Jun 10, 2005 3:15 pm
I think Pegoretti's look very good. The finish is superb! Close up, they allways look better than on a picture, I think.
Pretty solid too and very light for a steel frame. A friend of mine, who is quite tall and strong, broke every frame he ever had, but his Marcelo is still in one piece.
 Post subject:
 Post subject:
PostPosted: Fri Jun 10, 2005 6:13 pm
Check out Don Walker's stuff. Nice. www.donwalkercycles.com He just put one together that was 15lbs. and some change.
 Post subject: Landshark
PostPosted: Fri Jun 10, 2005 7:39 pm
While you may not be able to achieve hyper-light weights with steel, you will have that magic ride. You should check out www.landsharkbicycles.com. The build is completely custom, you can work with John Slawta to put together tube combinations that meet your requirements and they have some of the finest custom paint jobs out there. For stock frames the DeRosa Corum is a beautifully balanced frameset.
 Post subject:
PostPosted: Fri Jun 10, 2005 8:29 pm
Check Vanilla bikes.
In general: get a frame made out of SAT 16.5 EOM, lightest, strongest steeltubing. Pegoretti is very nice and custom available!
Specialized S-Works Allez (the shiny one :) )
Turner Czar
 Post subject:
PostPosted: Fri Jun 10, 2005 9:04 pm
I'm a framebuilder and I know eom is very sketchy stuff. There are much better alternatives for ww steel. Eom is pretty brittle, it has low elongation. It is just a heat treated version of deda's sat/zero uno steel and the joints anneal during welding. The butts are also weird. They're just tapered. The more you cut them down, the thinner they get. They spec 0.6 0.4 0.6mm butts on they're website but you end up with 0.5mm ends once it's cut. You can do much better than this stuff.
I definatly would not go for a complete eom tubeset but I do like the downtube shapes.
 Post subject:
PostPosted: Fri Jun 10, 2005 9:07 pm
 Post subject:
PostPosted: Fri Jun 10, 2005 9:39 pm
My Pegoretti Marcelo is over 4 years old, has been crashed a couple of times and is still as true as the day Dario built it. Sub 17lbs, only carbon parts are forks, pin and saddle rails. Bullet proof build and rides like an alloy frame can only dream about! :D
Out of interest do you build for a living or for a hobby?
 Post subject:
PostPosted: Fri Jun 10, 2005 9:43 pm
This is a respectable forum, please refrain from pedalling PORN :wink:
Without doubt the prettiest finishing I have ever seen, but I couldn't bring myself to take one out on the road and get it dirty or god forbid scratched!!
 Post subject:
PostPosted: Fri Jun 10, 2005 9:49 pm
Right now I build a little on the side. This isn't my bread and butter. I used to work with a local framebuilder: http://www.fixedgeargallery.com/2005/feb/pendon.htm
I am not saying eom is bad. It's still much better than most Al stuff. I just think that for the money you can do better.
 Post subject: WW steel
PostPosted: Fri Jun 10, 2005 10:25 pm
I have heard a number of great things about using True Temper's S3 steel. We looked into it as a possability for our company, but chose to stick with Ti rather than branch out.
If you can find it AerMet (think that's the right spelling) makes a fantastic steel bike. And there are a few people who have some of it lying around in tube form. It's rare, difficult to work with and expensive - but if you can get ahold of it chances are you'll think it's worth it.
The key is to find a great builder and then trust them. Anyone can take a superlight tubeset and make a superlight bike. A great builder will make a WW steel bike that's worth its weight in gold, where a poorly-built one won't be worth a bucket of yak spit.
And don't buy a frame for the finishing quality, buy it for the build quality, precision and workmanship. There are plenty of great custom builders who will be happy to have the painter of your choice finish the frame for you if you want something special.
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
 Post subject:
PostPosted: Sat Jun 11, 2005 1:16 am
Aermet is very nice. It has a higher strength to weight ratio than 6/4 Ti. It was only available in 0.5mm straight gauge and the only source I know of it now is asking 100$/foot!. Cartech is not producing any bike frame tubing anymore.
I don't think the absolute lightest tubes will necessarily make the best frame. Find a good builder and make smart choices. Sub 1300g steel frames are cool but they're not the best route for everybody.
I would rather have a little extra weight on my frame than really heavy parts.
 Post subject:
PostPosted: Sat Jun 11, 2005 1:51 am
Columbus Spirit or Life, guys. Zona Megatube if you're on the heavy side.
 Post subject:
PostPosted: Sat Jun 11, 2005 2:57 am
Location: somewere floating between here and the other side
with out anny form of doubt i can tell you there is no better bike than a marcelo ........
well at least for me i had a whole heap of bikes as iam a mechanic working in a bikeshop, but the marcelo i have makes me smile all day, i know understand the older customers we have that walk in with their 20 year old vitus frames, they bought it and bought the best !!
the bike is in the what do you ride topic i belive somewere in the 20-25 pages
if u chose something else i would liketo advise you to stay away from aero tubing an that crap..
btw whats youre body height and weight ?
on the serotta forum their is a lot of pegoretti talk aswell.
 Post subject:
PostPosted: Sat Jun 11, 2005 3:30 am
Tubbie Guru
Hi,
Funny you'd mention Vitus....
In the region where I live there used to be a Vitus dealer and old Vitus bikes can be bought for peanuts over here.
So, I wonder, what magical properties do these bikes posess that other more earthly two wheelers do not?
I hear names such as Pegoretti, Marcello and now Vitus dropped with such respect for the old masters that I'm tempted to get my hands on one but would like to know what to expect....
What is it I should look for or is it rather obvious?
Ciao and TIA, :wink:
 Post subject:
There are no new unread posts for this topic. Steel, Stainless steel or Titanium ?
stormur
18
2093
Sun Dec 31, 2017 10:07 am
stormur View the latest post
There are no new unread posts for this topic. Is carbon lugged dead? Have modern monocoque frames usurped carbon lugged frames outside of just weight?
tranzformer
Sat Jul 22, 2017 4:14 pm
spartacus View the latest post
There are no new unread posts for this topic. Colnago steel - From 10s to 11s .. what to watch out for ?
Kupepe
Wed Mar 29, 2017 8:24 pm
shimmeD View the latest post
There are no new unread posts for this topic. 1980~ Steel classic.
Littlemad
Tue Nov 21, 2017 11:50 am
Littlemad View the latest post
There are no new unread posts for this topic. Steel OR Carbon / Calipers or Disc
stevenak
16
1440
Mon May 22, 2017 11:46 am
Fixie82 View the latest post
Users browsing this forum: AJS914, bfno, Bing [Bot], Google Adsense [Bot], jimtbaker, themidge, wedgie, Wookski, wrenegade and 32 guests
