It is currently Sat Jan 20, 2018 2:57 am
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: veloce crank stiffness ?
PostPosted: Thu Jun 09, 2005 9:32 pm
when standing on the pedals the chainrings flex and tuch the FD.
when i looked very good at the problem, i notice that its the bb area that is flexing (mybe the frame) or the bb connection to the crank.
is a chorus bb can fix the problem ?
or its better to go fro full combo like ultegra 10,and if so, Is ultegra 10 will work with my campy 9 groupe ?
 Post subject:
PostPosted: Thu Jun 09, 2005 9:57 pm
Veloce crank won't work on standard chorus or record BB. Chorus and Record BB use shorter spindles and don't allow enough clearance for the Veloce crank. You would need to use Chorus triple BB (111mm spindle) to work, even then it may not be long enough.
 Post subject:
 Post subject:
PostPosted: Fri Jun 10, 2005 5:44 am
This is the same problem I had with the Record cranks. The Campy bottom bracket and crank interface is not the stiffest design available- hense why everyone changed to the octalink, isis drive etc. The best option if you want stiffness at the bottom bracket is to go for the three-piece style crank, either FSA or Shimano.
 Post subject:
PostPosted: Fri Jun 10, 2005 9:53 am
The Record BB is practically as stiff as the DA9 Octalink. Now, that's suddenly not enough :?:
 Post subject:
PostPosted: Fri Jun 10, 2005 10:05 am
WWotY 2007
In my opinion, your frame should be too much flexy. The crankset are usually very stiff, anyway really stiff enough for non pro riders!
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Fri Jun 10, 2005 12:34 pm
Tubbie Guru
Hi,
LOL....
In case you haven't noticed yet, it can never be stiff enough nor light enough. :?
The Chorus and Record BBs are more than stiff enough for any normal athlete, i.e. if you don't resemble an overblown bull you'd be just fine.....
There's no point whatsoever to go overboard on BBs when the surrounding elements can flex. Think holistic.
Another possible advantage of the Campa's 102mm BBs is a better Q-factor if they're used with the better cranks.
That, to me at least, would be a far more important factor than just absolute stiffness alone.....
Ciao, :wink:
 Post subject:
Indeed. For decades the square tapered interface has been stiff enough, but nowadays it isn't anymore :lol:
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Fri Jun 10, 2005 1:56 pm
track sprinters ride the campag pista or shimano dura-ace cranksets which seem to be same as the older alu road cranks but with only 1 chainring. These guys put out about 1500-2000W at times. i haven't seen a mass changeover to octalink /external bearings / oversized cranks on the track yet...
Doozer
Dance you cares away, worries for another day, dance your cares away, down at fragglerock.
 Post subject:
PostPosted: Fri Jun 10, 2005 4:58 pm
so, if the veloce bb stiffnes is enough (as u say)
the problem is from the FRAME's BB AREA ????
 Post subject:
PostPosted: Fri Jun 10, 2005 8:13 pm
Yes, if you're riding an older steel frame that may be the case.
I have veloce cranks on an old steel bianchi, and it flexes when i sprint on it.
I have chorus on a stiff alu frame, i get no deflection whatsoever. There's nothing wrong with square taper IMO.
 Post subject:
PostPosted: Fri Jun 10, 2005 8:26 pm
its an Pinarello surprise !! ALU frame - Deda 7005 T6
 Post subject:
Tubbie Guru
Hi,
Incidentally I have an old steel Bianchi Rekord 748 with a Shimano RX100 group.
It always flexes somewhat, scraping the FD cage when I climbed.
I temporarily had the same group transferred to a much newer aluminium Bianchi EV2 with addmitteldly a shorter spindle (107mm as opposed to 113mm Shimano BB Campa style square taper) BB and there's no flexing whatsoever.
So I assume at least some of the flex must be due to the BB shell construction and frame build.
Ciao, :wink:
 Post subject:
There are no new unread posts for this topic. Campagnolo compatibility 10s veloce rd - 11s athena shifters
silvalis
11
1049
Tue Jun 06, 2017 5:11 am
silvalis View the latest post
There are no new unread posts for this topic. Recently upgraded "well serviced" campy veloce bike showing symptoms
alcatraz
Mon May 22, 2017 5:16 am
vejnemojnen View the latest post
There are no new unread posts for this topic. Attachment(s) does stiffness matter (w/numbers)
wwnick
24
2106
Thu Jul 06, 2017 8:50 am
Marin View the latest post
There are no new unread posts for this topic. Bars and stem - stiffness versus weight.
BennyC
Sun May 28, 2017 8:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1310
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
Users browsing this forum: Google Adsense [Bot], Samklee15 and 23 guests
