It is currently Sun Dec 17, 2017 11:32 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: Ditching the inner ring
PostPosted: Thu Jun 09, 2005 1:47 pm
The post about overshoes brought this to my mind. I think its well established that there is an aero advantage in a TT from ditching the inner chainring. However, I've been reluctant to do it for fear that it might compromise the stiffness of the chainset. Has anyone any experience of riding with just the big ring in this context?
 Post subject:
PostPosted: Thu Jun 09, 2005 2:38 pm
In TT you're riding smoothly. So I think stifness isn't very important.
But if you take of your little chainring I don't think that you'll win. A good cyclist can win even with simple bike with aerobars ;)
 Post subject:
PostPosted: Thu Jun 09, 2005 2:44 pm
you can easily skip the inner ring, no problems here, just use either spacers or smaller chainringscrews. (Theoretically there isn't a difference in stifness weather you use one or two rings)
I would advise you to keep your front derailleur though, just in case something would go wrong.
 Post subject:
PostPosted: Thu Jun 09, 2005 3:07 pm
David Millar would similarly advise you to keep your front derailleur ... remember the TDF prologue in 03, which he nearly won? he had a single ring and no front derailleur. his chain came off just before the finish. he threw a fit, said his DS made poor equipment choices. certainly the now ex-DS may have, but after riding bikes that long as a pro he should have known these things.
 Post subject:
Yes keep the FD or you won't finish :lol:
 Post subject:
PostPosted: Thu Jun 09, 2005 3:15 pm
You can get special chainrings with larger teeth when using a single chainring setup. Supposedly to allow you to remove the FD, but I wouldn't
 Post subject: Stiffness?
PostPosted: Thu Jun 09, 2005 5:58 pm
Thanks for the advice. On Irish roads there would be no question of removing the derailleur as the chain would definitely come off.
As regards AED's point - I'm already capable of winning TTs - but optimising every aspect of performance is what TTs are all about - especially if you are 1m70 and 55 kilos.
Regarding stiffness - I would have thought that the inner ring plays some role in stiffening the spider. However, thinking about it more I suppose there really are only radial loads on the chain ring and all the axial loads are on on the cranks themselves.
I'll take the inner ring off for the next TT in a couple of weeks time and see what happens.
 Post subject:
PostPosted: Thu Jun 09, 2005 7:13 pm
I think the stiffness issue is why FSA and Shimano started producing the TT specific rings. They're pretty beefy.
 Post subject:
 Post subject: I missed
PostPosted: Fri Jun 10, 2005 3:50 pm
I missed the local national chamionships due to not having FD
the cain comes off if the chainline is not straight!!!!
do not loose the fd!!!
its not worth the weight saving.
also check www.tisobike.it for their triathlon chainrings - they are reinforced in the rear and do not flex in the large sized 55-56 :-)
There are no new unread posts for this topic. SRM ditching Shimano?
avispa
21
2091
Thu Nov 16, 2017 8:44 pm
fogman View the latest post
There are no new unread posts for this topic. New chain ring recommendations
bpe
Fri May 12, 2017 7:38 pm
jrobart View the latest post
There are no new unread posts for this topic. Chain fall off the inner ring while standing
Basrij
9
377
Mon Dec 11, 2017 7:37 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. removing logo from chain ring
Timujin
Fri Mar 10, 2017 8:23 am
marynoland View the latest post
There are no new unread posts for this topic. Convert Rotor QXL to single front ring
hanzypanzy
Wed Feb 08, 2017 10:50 am
hanzypanzy View the latest post
Users browsing this forum: Bing [Bot] and 43 guests
