Post new topic Reply to topic  [ 12 posts ]
 Post subject: Crankset q factors
PostPosted: Mon Nov 24, 2003 5:57 am
Does anyone know the q-factor of fsa carbon superlight, or other fsa cranks, dura ace cranks, power arms, and cannondal Si cranks?
I'm trying to see which has the lowest, my feet rub on the FSA Superlights, so I need something narrower. Any suggestions and q-factors appreciated.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject: rubbing cranks
PostPosted: Mon Nov 24, 2003 3:45 pm
Is it the finish rubbing off that is bothering you? If it is I have stopped my shoes from rubbing by turning my cleats so the shoe can't rub. It takes some playing around but it works. I do it with my speedplays. I think that is what your riding. You do have to rotate your shoe further out to unclip but I haven't found that to be a problem.
 Post subject: What about Q factor
PostPosted: Tue Nov 25, 2003 10:21 am
Can somebody explain me the Q factor?
And what is the advantage of a small Q factor?
 Post subject:
PostPosted: Tue Nov 25, 2003 11:10 am
Administrator
This is the space between the cranck and the rear fork. The lower it is, the closer is the cranck to the rear fork. The cranck has to be real close to the rear fork that is the fastest setup.
The picture attached is showing a way to big q factor. 2 fingers! So its WRONG
Follow me on twitter. I try to be interesting ;)
On Facebook!
 Post subject:
PostPosted: Tue Nov 25, 2003 3:31 pm
why dont you try the Look CX-7 pedals you can adjust how far the pedals are from the crank :wink:
 Post subject:
PostPosted: Tue Nov 25, 2003 3:48 pm
I've heard that having a low Q-factor is not as important as it was thought.
Not for the bike but for the rider. I'm not sure but it makes sense to me that your foot should be in line below the knee and hip. Otherwise for some people you could get into knee or foot problems.
For me it's like old school snow skiing. Skiing with your skis close together was considered good form. Now having your skis shoulder width is the way to go. I don't ski anymore but if I went I'd have my skis close together. Old habits die hard. I worked sooo hard to get them close together!
 Post subject:
PostPosted: Tue Nov 25, 2003 4:02 pm
Administrator
I think that when you have a high q factor you bring you bike in a disbalance while pedaling. And thats why we are all here for, a low q factor saves weight!
On Facebook!
 Post subject:
PostPosted: Tue Nov 25, 2003 10:35 pm
What? I'm not looking at low q-factor to save weight, thats stupid! It's for performance. With my old FSA cranks the q factor was to damned big so my feet hit the crank arms. Save weight? Oh boy. :roll:
 Post subject:
PostPosted: Wed Nov 26, 2003 1:53 pm
Like i said if you want to adjust q-factor you can so with the look CX-7 pedals: Adjustability: Q Factor, Seat Angle, Spring Tension
http://www.lookcyclesusa.com/pp-cx-7.htm
check them out. They are not that lite, but they will do the job.
 Post subject:
PostPosted: Wed Nov 26, 2003 5:57 pm
No thanks, I use speedplay.
It doesn't matter anymore anyhow, I just ordered my frame with SI cranks, it has the lowest q-factor available. The best thing about these cranks is they only weigh around 30g more then a power arms, and a very light weight bottom bracket set up. Plus these bad boys are wayyyyyyyy stiffer.
 Post subject:
PostPosted: Wed Nov 26, 2003 8:02 pm
Administrator
Superlite i think you got me wrong. What i meant is that when you are getting your q factor down your performance goes up! :D The weight saving is just an added extra! :!:
On Facebook!
 Post subject:
PostPosted: Wed Nov 26, 2003 8:48 pm
Ah, very good. :lol:
Users browsing this forum: Bing [Bot], Exabot [Bot], xis, Yahoo [Bot] and 44 guests
This topic is locked, you cannot edit posts or make further replies. New RED crankset is ordered, which bb should I get ?
Wadl
Sun Sep 09, 2012 9:38 pm
Frankie - B View the latest post
This topic is locked, you cannot edit posts or make further replies. Crankset recommendation
deepakvrao
Fri Apr 19, 2013 9:16 am
deepakvrao View the latest post
There are no new unread posts for this topic. s works crankset
cymans
9
1071
Thu Apr 04, 2013 3:25 am
Gearhead65 View the latest post
There are no new unread posts for this topic. Crankset or wheelset?
Bianchi10
11
858
Sat Jan 26, 2013 8:04 pm
kgt View the latest post
There are no new unread posts for this topic. which crankset and does it come with a bottoom bracket
downings
Fri Jun 15, 2012 12:27 pm
Stolichnaya View the latest post
It is currently Sun May 26, 2013 6:06 am
