Post new topic Reply to topic  [ 2688 posts ]
Go to page Previous  1 ... 159, 160, 161, 162, 163, 164, 165 ... 180  Next
PostPosted: Sun Oct 14, 2012 3:13 pm
I would retire it, period. I wouldn't use it for training/easier rides or as a spare. But that's me.
PostPosted: Sun Oct 14, 2012 6:44 pm
Tubbie Guru
Hi,
+1
Better think of it as a spare latex inner tube from now onwards..... :P
Ciao, ;)
PostPosted: Mon Oct 15, 2012 12:54 pm
thanks chaps
now i just need to soothe my blistered thumb, had a struggle getting the tyre off - it was the first one i glued using the instructions here, seems the glue worked very well
PostPosted: Mon Oct 15, 2012 1:10 pm
sungod wrote:
thanks chaps
Even thinner layers next time :thumbup:
PostPosted: Mon Oct 15, 2012 5:15 pm
I had been on my clinchers for quite a few rides, as i was getting ready to clean the whole drivetrain. They are Fulcrum Racing 3s, tyres are Pro3 Race, with latex inners. For a clincher setup i think it is right up there...but fark me did my jaw drop for the 34th time when i swapped back the tubular set ( Ambrosio Nemesis/Record/DT Aerolite + Veloflex Criterium )...It just can't be that much better...It's just ridiculous, the difference..in every aspect.
How can anyone be without some sweet riding tubulars??
Not to mention I'm always a bit anxious when on clinchers..whereas when on tubbies i just don't give a fuk, and can really enjoy the ride..
I just had to share... :mrgreen:
PostPosted: Wed Oct 17, 2012 1:12 pm
Is Veloflex the only tire that stamps a manufacture date on the base tape. I recently purchased a set of Carbons that are dated March 2012. Do tubs need to be mounted to age or inflated or just placed in a dark place?
PostPosted: Wed Oct 17, 2012 1:39 pm
Tubbie Guru
Hi,
You can mount them on a spare rim/wheel and slightly inflate them or you can just as well lay them on a large shelf, floor, in big cardboard box, whatever.
For as long as: the area is dry, there are no UV rays (not even from artificial lightsources), tubulars are in no way constrained (to avoid knicks in the sidewalls) and you're not going to keep them there for decades ( :mrgreen: ), you'll be fine.
AFAIK they are the only one but maybe FMB or Dugast do so as well. It would be nice if more manufacturers followed suit though.
Ciao, ;)
PostPosted: Wed Oct 17, 2012 7:03 pm
^^I acquired three Challenge Strada tubbies a while ago. Each of them had a date stamped on the base tape. It is useful, I have to agree.
PostPosted: Sat Oct 20, 2012 5:50 am
I need to get rid of the valve hump on my Vittoria tubular rally set. They are going on mavic reflex rims. What's a good way to make that hump less noticeable. How to trim around the valve.
No I will not modify the valve hole on the rim.
PostPosted: Sat Oct 20, 2012 8:59 am
Challenge grifos here with date stamps, glued yesterday.
Sent from my EVO using Tapatalk 2
PostPosted: Mon Oct 29, 2012 10:02 pm
FMBs are date stamped too.
PostPosted: Wed Oct 31, 2012 9:51 pm
Here is a peice on Francois Marie that I thought you guys might find interesting: http://www.bikeradar.com/gear/article/i ... hop-35668/
PostPosted: Fri Nov 02, 2012 4:40 am
CarlTroy wrote:
sungod wrote:
thanks chaps
That's what makes it stick so well. A thick layer of glue would not dry as well would easily come off.
Mavic makes some plastic tire levers to help you un-stick the tire from the rim.
These tire levers are not the same as the clincher ones.
PostPosted: Fri Nov 02, 2012 11:56 am
Hello everybody. I have read good things about veloflex tubular tyres and are now going to be my next tub purchase.
However, has anybody tried their clincher tyres? Looking for a clincher that has average puncture resistance (luckily rarely suffer from punctures), good in the wet and suitable for decending in the Pyrenees. I currently ride scwalble ultramo ZX without any problems.
Many thanks.
PostPosted: Fri Nov 02, 2012 1:33 pm
Tubbie Guru
Hi,
Hmmmm....Interesting. You wouldn't have a pic or a link for these?
Technically they are the same as the tubular versions. If you're looking for decent puncture resistance make sure cto age the tyres for at least a couple of mionths prior to use.
Ciao, ;)
Post new topic Reply to topic  [ 2688 posts ]  Go to page Previous  1 ... 159, 160, 161, 162, 163, 164, 165 ... 180  Next
Users browsing this forum: No registered users and 0 guests
There are no new unread posts for this topic. Another which frame for me thread..
Colin
Sat Jan 05, 2013 10:30 pm
Colin View the latest post
This topic is locked, you cannot edit posts or make further replies. Sale Thread...?
kevinkalis
Thu Jul 19, 2012 8:13 am
Tinea Pedis View the latest post
It is currently Sun May 19, 2013 12:02 pm
