Post new topic Reply to topic  [ 13 posts ]
PostPosted: Thu Apr 08, 2010 2:40 pm
Part 1).
Any one knows of something lighter than the standard Veloplugs to cover rim-bed holes for clinchers?
PostPosted: Thu Apr 08, 2010 2:55 pm
3m strapping tape cut to size
PostPosted: Thu Apr 08, 2010 2:56 pm
Clingwrap.
(you didn't specify if it would work or notImage)
Vertebrae. Precision braking and shifting.
PostPosted: Thu Apr 08, 2010 2:59 pm
synchronicity wrote:
Clingwrap.
Well it sort of has to work :D
PostPosted: Thu Apr 08, 2010 7:31 pm
Which one?
http://solutions.3m.com/wps/portal/3M/en_US/Manufacturing/Industry/Product-Catalog/Online-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQGLE0_nid=37Q2HZ60G9beTRGGC52N4Mgl
PostPosted: Thu Apr 08, 2010 10:39 pm
While as an industry person lawyers will keep us from making any recommendation to use something in a manner for which it is not approved. I will however say that I've seen quite a few people use two layers of 865 with no complaints. In my opinion 2 layers of Rox is a better choice, though not as inexpensive. Several people like to mix the two as well. They'll cut the 865 into 1" pieces and put one over each hole and then use one layer of Rox on top of them. Me, I like the C4 tape. Heavier than veloplugs or Rox, but lighter than Velox and one of the most durable we've found.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Fri Apr 09, 2010 5:21 am
madcow made the summation, 865, two strips perpendicular with some of course beyond the spoke hole circumference. I've also tried the veloplugs with a 3m strip across. Both setups worked well, I would however check on the setup now and again.
PostPosted: Fri Apr 09, 2010 6:50 am
how much lighter would the 3M setup be compared to veloplugs?
2012 Scott Foil Premium
PostPosted: Mon Apr 12, 2010 3:10 pm
Part 2:
yes there's something lighter-non standard Veloplugs :-).
I recently had a wheelset built with Edge 45 clincher rims. I wanted to keep the weight quite low so I wasn't really pleased with the solution of putting Edge rim tape on to cover the spoke holes. I knew that Edge rims have rather big holes so the yellow Veloplugs wouldn't snap into place unless some glue would be applied-as some ww-members did, but I didn't like the idea of the glue so I tried this:
I took my soldering iron and put three holes in each of the plugs.
File comment: Close look of a plug with 3 melted holes
File comment: Front 18 rear 24-so 42 plugs equal 7 grams. 40 Standard plugs would be 8 Grams so saving a bit over one gram or around 15% :-).
File comment: 20 Veloplus weigh exactly 4 grams
(on the picture are 24).
I saved a total of 29 grams over a already pretty light rim tape.
File comment: 2X 18 grams equal 36 grams for the wheelset
It's not really about the weight saving, but about the fact that that way the yellow Veloplugs work with the Edge clinchers.
And of course the weightsaving happens at a importand place-at the periphery of the rims which is the best place to save weight and hey,after all it's weightweenies :-).
PostPosted: Mon Apr 12, 2010 6:59 pm
:twisted:
Weight Weenie Approved!
Exp001
PostPosted: Mon Apr 12, 2010 10:28 pm
Very nice! I have red Veloplugs in my American Classic Sprint 350's :beerchug:
PostPosted: Wed Apr 14, 2010 6:57 am
el condor,
Fantastic idea :thumbup: I also have Edge 1.45 clinchers and i didn't like the idea of using glue either.
I used a big phillips head screw driver to flair out the yellow Veloplugs and that worked perfectly.
I'll be doing some soldering tonight :)
PostPosted: Wed Apr 14, 2010 5:29 pm
pawnii wrote:
el condor,
Hi Pawnii,
it works well, have some hundred km's so far without any issues. Make sure that the tip of the soldering iron is quite pointy, leave about 1mm of distance to the plug head so it can be put flush with the rim surface since the thickness of the carbon is about 1mm.
You may have to snap some of the plastic around the melted hole away so it want get stuck between the plug head and the rim.
After I put all of the plugs in, I checked if they were all flush, some may not-(in my case only 2), take em out and snap the jammed plastic away.
Let me know how it went.
Cheers
Pascal
Users browsing this forum: Dodger747, Google [Bot] and 45 guests
There are no new unread posts for this topic. Veloplugs
Naturel
12
800
Sun Mar 31, 2013 2:06 am
Wingnut View the latest post
There are no new unread posts for this topic. Quick question probably alot of you can answer!!!
Putricaina
14
658
Fri Mar 15, 2013 4:42 pm
Wolfgang View the latest post
There are no new unread posts for this topic. Zipp 11 speed wheels and the strange answer from their CS
goodboyr
7
1088
Sat May 11, 2013 4:11 pm
goodboyr View the latest post
There are no new unread posts for this topic. veloplugs with boyd wheels?
Bianchi10
Mon Jan 14, 2013 1:42 pm
robertg View the latest post
There are no new unread posts for this topic. Veloplugs or Stan's on Shimano RS80's
btompkins0112
19
958
Thu Sep 06, 2012 12:10 pm
btompkins0112 View the latest post
It is currently Tue May 21, 2013 11:47 pm
