Post new topic Reply to topic  [ 63 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: brakes to get
PostPosted: Mon Apr 05, 2010 8:47 pm
The eebrakes are definitely not cheap. But, they work really well (and are really light).
PostPosted: Tue Apr 06, 2010 1:49 pm
Shamless plug. I am selling my beloved M5 brakes and will part with them cheap to a good home. Xtra ZG brake pad holders too. Madcow reviews them over at Fairwheel in his best brakes review
WW Velocipedist Gargantuan
PostPosted: Tue Apr 06, 2010 2:41 pm
Go for the KCNC C7...almost the same weight as the CB1 but much more stiff. The C6 is the same design but heavier at around 210 grams....and on one of the posts above, KCNC is not the same as Token.
www.royalbicycles.com
PostPosted: Tue Apr 06, 2010 2:48 pm
SL58 wrote:
I am happy with Token Accura (same as KCNC) - 200g for around $200,
all Ti harware, working fine for more than 2 years, 1/2 the price
and pain of Zero Grav. and Shimano pad compatable.
Token Accura are NOT the same as KCNC CB1.. My KCNC CB1 brakes weigh 153g including pads!
Token Accura are the same as a bunch of generic "CNC brakes", like the Planet-x brakes.
To OP: I can only recommend the KCNC CB1. They do what they are suppoesed to and weigh incredible little. Make sure to use proper brakepads, like swissstop.
.::. Taking the hobbits to Isengard since 2001 .::.
My bikes:
Parlee Z3SL: DI2,THM, EDGE, Gravitas and loads more (5,79kg)
S-Works Transition: Sram Red, Xentis and more
Pinarello F4:13: Campagnolo SR11 and Racing Speeds and more (SOLD)
PostPosted: Wed Apr 07, 2010 9:08 am
Shop Owner / Manufacturer
I really like the TRP R920 brakes. I was just admiring them the other day. After the rim and the pads "bedded in", the stopping power is awesome. They almost felt like cable pull disc brakes...on alloy rims in dry weather.
V.
Velocite Bikes
Cycle Taiwan
PostPosted: Wed Apr 07, 2010 11:33 am
I still think the CB1 is awesome :mrgreen:
145g with pads!
My bikes:
PostPosted: Wed Apr 07, 2010 2:18 pm
The KCNC CB1 is probably the best bang-for-your-buck brake set...I'm sure other shops/distributors can chime in with similar feedback. Jason from FWB did a very good review of different brakes and the CB1 is a great all around brak: Excellent weight, good braking power, very good price, etc. It balance a lot of attributes very well. Now, the new C6 & C7 take the CB1 performance to a whole new level. The C7 is practically the same weight as the CB1 but uses a whole new design that eliminates flex and improves braking power. C6 is the same design but uses a different type of alloy and SS hardware to drop the price but weight goes up at around 210 grams per set. Price for the C7 went up very little and they still come in all the colors. C6 come int he same colors + Blue and green and no carbon pads. Besides KCNC other good brakes that fall in this category are the EE and the TRP (depending on model).
PostPosted: Wed Apr 07, 2010 3:20 pm
Formerly known as PezTech
We have different games going...
Price weight and stopping power...
EE, Negative GSL, M5 are all significantly stronger braking than KCNC and standard Zero G...
KCNC are a great price point and work well (I have no problem with KCNC or Zero G, in fact I like em both) but some might not find them acceptable. Ciamilo lowered all of their pricing, so some might look hader and standard Negative G.
TRP 960 stop with strength competitive to EE, Negative G and Better than KCNC/standard Zero G and cost some place in the middle but add weight...
The THM stop well but I don't think as well as EE and the cost is what most would consider high. Gravitas stop very well too and cost less than THM but more than most others.
Performance and weight are fixed with these brakes. The performance range goes from acceptable to great.
Value is a personal thing and I'm not knowledgable enough to claim a bang for the buck winner when performance is a lot different through the variable models.
charles@pezcyclingnews.com
PostPosted: Wed Apr 07, 2010 5:50 pm
In contradiction to the stated CNC label that KCNC puts on their brakes, judging the photo's i've seen so far, they appear to be moulded instead of being CNC machined as advertised. (allthough some parts will be CNC machined, but the largest part isn't)
The rough surface is either from the cheap moulding process or a sandblasting process. and to be honest, i don't believe they are sandblasted. there are several grades of moulding, and this rough surface isn't the most expensive one. Tumbling would give an different finish..
I am a bit worried about the overall quality of these brakes, considering their relative cheap mass-production method.
Their weight is awesome, but i read several posters reporting noticeable less stopping power. (even with different pads)
PostPosted: Wed Apr 07, 2010 6:00 pm
I've got some of the new generation of EE brakes, they are by far the best stopppers I've used but are indeed pricey.
The issue I have with the KCNC brakes is the new logo! :shock:
Pegoretti Responsorium
Parlee Z5i
Donhou Commuter
PostPosted: Thu Apr 08, 2010 2:24 am
I'm looking at breaking up my DA7900 group on a bike that should be back from paint soon. The thought is to use a Rotor 3D crankset and I'm trying to decide between the TRP 970SL calipers and the EE brakes. I ride carbon wheels and use cork pads, so the brake has to have plenty of gumption on it's own, I'm not going to use Yellow King pads to compensate and then deal with melting pads and the inevitable grabbiness... Which would you choose? I love 7900 brakes, but think it wouldn't hurt to build one bike up differently if I can do it without risking life and limb...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
PostPosted: Thu Apr 08, 2010 3:15 am
I still prefer the Shimano or Campagnolo calipers...
PostPosted: Thu Apr 08, 2010 12:12 pm
Lance, I have been using the EE brakes on both Edge and Bora carbon wheels with Zipps tangent cork brake pads............. :thumbup: :thumbup:
Make sure you get the new version EE brakes as they have been altered to perform better with the DA brake levers
PostPosted: Thu Apr 08, 2010 12:50 pm
buikpijn....do you based this on photos, other peoples opinions or have you taken a closer look at the brakes? We have C6 and C7 on stock and just took a look at the machine work on the brake arms and you can clearly see the marks typical of CNC machining. The surface finish is definetly a treatment KCNC is doing with its new brakes.
Of all the KCNC part available the CB1 has performed flawlessly so far and we expect the C6 & C7 to follow the same route as they addresses the flexing problem of the CB1 that some people are not going to deal with.
PostPosted: Thu Apr 08, 2010 4:30 pm
As stated, by looking at several pictures; I've seen different finishes for sure, never touched one in person. Different finishes, going from from smooth to rough. Like the red ones on the scale earlier in this thread, who remind me of cheap chinese molded parts. Perhaps there are knock-offs available, since China is the uncrowned king of copies. (not considered a compliment : )
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: 1415chris, Antoine, Bing [Bot], lechat, octav, verycreativeusername and 41 guests
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
There are no new unread posts for this topic. Attachment(s) New THM matte brakes
coppercook62
14
2031
Mon Jul 30, 2012 3:17 am
thatdkid View the latest post
There are no new unread posts for this topic. AX Lightness Brakes
DamoRider
13
767
Tue Mar 12, 2013 3:14 am
sedluk View the latest post
This topic is locked, you cannot edit posts or make further replies. Lightweight CNC brakes
wpccrunner
Mon Jan 21, 2013 1:48 am
wpccrunner View the latest post
There are no new unread posts for this topic. TRP brakes binding
shoemakerpom2010
Tue Dec 11, 2012 12:45 pm
wiRIDEfast View the latest post
It is currently Tue May 21, 2013 9:52 am
