It is currently Fri Oct 20, 2017 11:10 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
PostPosted: Fri Mar 26, 2010 3:24 am
Hi there,
I've got a custom lugged steel frame being built up (with steel fork), and I'm considering ditching the steel fork for a modern 1" threadless carbon fork. Most of the big fork manufacturers like Easton, Columbus, Ritchey and Deda still seem to sell 1 inch versions of their forks. I'm hoping someone with experience might be able to comment on what the differences are between them, and ultimately which ones are better.
My understanding is that some have aluminium steerers, while the more expensive ones are full carbon, however I am ignorant to the differences in performance.
Of course, one solution might be to retain the steel fork although I would imagine a modern steel fork (lugged) would weigh somewhere in the region of 1kg, is that correct?
Many thanks.
PostPosted: Fri Mar 26, 2010 3:54 am
I just switched out the threaded steel steerer carbon fork of my LOOK KG96 to an Easton EC90 SL Aero (threadless).
It all went smoothly, but I was surprised that my original LOOK fork only weighed in at 490 gms after I had removed it.
The Easton is 385 gms.
I like the easton, but I wouldn't have bothered if I knew it was only going to be 100 gms savings.
I used a cane Creek SOLOS headset. They are on the closeout page of Cane Creeks' webstore for about $40.
If anyone is interested in my LOOK fork, PM me.
Good luck.
PostPosted: Fri Mar 26, 2010 4:36 pm
I use a 1" Easton EC90SL on my bike.
The weight is 320g with steerer cut to 220mm. I used an ITM millenium fork before and that was about 450g. I don't see why a lightweight steel fork would be more than 700g. I am thinking of trying to get one made for my bike as it would look more inkeeping.
edit; Just looked in listings and Colnago Precisa fork is 742g with uncut steerer.
PostPosted: Fri Mar 26, 2010 6:05 pm
Modern choices are Ritchey Carbon (alu steerer), Deda Blackforce 2 (alu steerer), Easton EC90 SL (carbon steerer), Reynolds..
For a classic steel frame I would most likely go with Time, Mizuno or Look, due to the thinner fork legs. Hard to find, check ebay. I once had a Profile design carbon fork which weighed as much as a steel fork! :noidea:
PostPosted: Fri Mar 26, 2010 6:16 pm
Nice bike! :)
This is exactly the sort of setup I'm considering.
How does the Easton EC90SL perform with the steel frame? Apart from the weight issue, would you still recommend?
PostPosted: Fri Mar 26, 2010 6:54 pm
straight version of the Easton EC90 or wound-up (which is excellent imho).
Bianchi EV3, Master Olympic, Pinarello Asolo
PostPosted: Fri Mar 26, 2010 6:56 pm
I find it very good. combined with the 73.5deg head angle of the frame the set up makes for nimble steering and the low fork weight contributes to this.
I agree with roadman about the look of thinner forks. I would have loved a Mizuno Fiandre fork but you just can't find them now. It is partly the reason that I am thinking of a steel fork. This bike has never had a steel fork on so I can't make a comparative assessment for you.
The EC90SL was the most suitable fork I could find, it's been on for about five years now and I would recommend it. There is a curved leg version if you prefer.
PostPosted: Fri Mar 26, 2010 7:01 pm
@ de zwarten
That Wound up looks nice. I will look into that.
PostPosted: Sat Mar 27, 2010 2:44 pm
You can add an Alpha Q CS20 to the mix, which comes in a 1" full carbon. Claimed weight uncut is 390g and the msrp is $299 USD.
In my case, however, I ended up switching back to a steel fork for my lugged steel frame. IMO, aesthetically, a lugged steel frame just goes better with a steel fork. And on high-speed descents, my steel fork handled a lot better.
Alpha Q forks generally get good reviews, so they must work for a lot of folks. Apparently, in this particular case, not for me.
PostPosted: Sat Mar 27, 2010 3:45 pm
That is so true!
My 6536gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Sun Mar 28, 2010 8:28 pm
Although they do not make the Reynolds forks anymore I have a full carbon fork 1" fork on my tandem. Even with as much as 400lbs it holds up well. Yeah, I know it is designed for a single bike it has worked out well for us.
PostPosted: Sun Mar 28, 2010 11:42 pm
The lighter Alpha Q GS10 is also made in a 1'' version.
Alpha Q GS10 1'':
$322 (in stock) http://www.universalcycles.com/shopping ... hp?id=9989
$267.95 (out of stock) http://www.ebikestop.com/alpha_q_gs10_7 ... FK1411.php
Alpha Q CS20 1'':
$350 http://www.glorycycles.com/alqcscafo1.html
$287 (out of stock) http://www.universalcycles.com/shopping ... hp?id=9991
$223.45 (out of stock) http://www.ebikestop.com/alpha_q_cs20_7 ... FK1417.php
Ritchey Comp Carbon Fork Alloy Steerer 1'':
$179.99 (in stock) http://www.treefortbikes.com/product/33 ... -Road.html
$209.86 http://ypsilanticycle.com/product/ritch ... 4-qc63.htm
$229.95 (in stock) http://www.ebikestop.com/ritchey_comp_c ... FK3214.php
$229.95 (in stock) http://ritcheylogic.com/dyn_prodfamily.php?k=98472
Easton EC90 SL Carbon Road Fork 1'' Straight:
$219.93 http://www.bikewagon.com/Forks-Headsets ... 05521.html
Easton EC90 SL Carbon Road Fork 1'' Curved:
$289.24 http://www.slanecycles.com/easton-ec90- ... rrency=USD
$349 http://www.treefortbikes.com/product/33 ... -Road.html
Winwood RT-10 Carbon Fork alloy steerer
$128.95 (in stock) http://www.treefortbikes.com/product/33 ... -Road.html
Winwood Activist carbon fork alloy steerer 1'':
$198 (out of stock) http://www.ebikestop.com/winwood_activi ... FK1245.php
PostPosted: Mon Mar 29, 2010 7:06 pm
Thank you for that great list 2 wheels.
I´m thinking of a curved Easton EC90 SL fork- good price and impressive weight.
Is there an issue in having a very light fork, while the rest of the steel frame is heavier? Also do I need to be aware of changing the rake or geometry of the frame by changing forks?
PostPosted: Mon Mar 29, 2010 8:59 pm
quite often when you change from a steel to a carbon fork your drop out-crown race distance goes up significantly which in turn slackens the seat and head angles and brings up your bb drop. this can be a little off-putting if you don't account for it with your geometry and you really like your current setup. though it's not something that's really difficult to work out and compensate for.
the weight difference shouldn't really do anything beyond making your bike feel more responsive...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
PostPosted: Tue Jul 31, 2012 2:11 am
I'm looking to upgrade my 1" fork at some point in the future. I see that Wiggle are stocking a 1" carbon fork from 'Tifosi' link
At 658 grams it's not going to be much lighter than a steel fork but the advantage is of course that you can use a threadless headset and a modern stem.
Although I image that is another issue altogether. Are there many stems designed for a 1" steerer that have a 31.6 mm bar clamp? I note that in one of the customer reviews of that fork they suggest the use of a Thompson steerer shim.
There are no new unread posts for this topic. Attachment(s) old steel frame conversion to new groupset
slick1
15
2099
Tue Feb 21, 2017 7:48 pm
mattr View the latest post
There are no new unread posts for this topic. Steel OR Carbon / Calipers or Disc
stevenak
16
1086
Mon May 22, 2017 11:46 am
Fixie82 View the latest post
There are no new unread posts for this topic. Look HSC 5SL fork in a CAAD7 frame
hoojammyflip
Sun Mar 19, 2017 10:14 am
hoojammyflip View the latest post
There are no new unread posts for this topic. Single Speed Frame & Fork with Mudgaurd Mounts
SgtRock
Wed Jun 14, 2017 3:37 pm
Ulver View the latest post
There are no new unread posts for this topic. Lightest Version of the Scott Addict Frame / Fork?
basenji29
Thu Aug 31, 2017 10:45 am
basenji29 View the latest post
Users browsing this forum: benjaminm3, Google Adsense [Bot], krogec, mike001100, MrMojo, themidge, Zakalwe and 38 guests
