Post new topic Reply to topic  [ 306 posts ]
Go to page Previous  1 ... 16, 17, 18, 19, 20, 21  Next
 Post subject: Re: Tubular Repair
PostPosted: Sun Nov 04, 2012 7:42 pm
Yes but spending 200$ on a handmade tubular is ludicrous for one and the benefits returned are rather small in comparison.
PostPosted: Tue Nov 20, 2012 7:02 pm
I wanted to show you how a Continental tubular looks on the inside and that they are very easily repairable. All tyres except the Limited edition (available to PRO teams only) have a butyl inner tube.
So here is a Gatorskin Tubular in detail: http://www.thetallcyclist.com/?p=264" onclick="window.open(this.href);return false;
Enjoy!
Bikes, watts, and weights
PostPosted: Tue Nov 20, 2012 7:54 pm
Tubbie Guru
Hi,
Thx for the link. 8)
Even the LE comes with a butyl inner tube nowadays.
Ciao, ;)
PostPosted: Fri Nov 23, 2012 2:56 pm
God, but that is an ugly tubular. I pity those guys who live in an environment where you need a tire that looks like that! I'm pretty happy that we have bottle recycling here...
PostPosted: Sat Nov 24, 2012 9:06 pm
amen.
i've found the difference in ride quality (subjective, of course) between an "excellent" tubular (e.g., vittoria corsa) and a very high quality tire / artisinal tubular was bigger than expected. it's easy to get spoiled and hard to go back.
PostPosted: Sun Nov 25, 2012 3:12 am
Most people seem to be surprised that they can discern a difference. I think we are habituated to believing that manufactured product is more consistent, therefore better, than truly hand made articles. There is often an intangible 'something' that needs an artisans touch.
PostPosted: Sun Nov 25, 2012 3:57 am
Tubbie Guru
Hi,
Perfect often equates lifeless, no?
Knowing that something's handmade often contributes to our respect for it too.
Quite often I see the same "kind" of people that ride tubulars (birds of a feather, I guess), custom built Ti bikes, listen to music using tube/valve electronics, vinyl records, analogue photography, you catch my drift, sharing quite similar views on life and moral values in general.
Ciao, ;)
P.S. A thread about the economical/ecological benefits of abolishing built-in obsoloscence, products made by people instead of machines, etc., etc. would be a nice page filler for the coming winter months........ :idea:
 Post subject: Vittoria Pave Evo Repair
PostPosted: Sat Dec 01, 2012 11:11 pm
I have in my possession a Vittoria Pave Evo CG 24 Tub to repair
Could I ask please if anyone has any experience in repairing such a Tub
Yes I know there is the tubular repair Sticky but without rereading the whole thread trying to find a reference to this particular tub, I'd thought I ask (that thread was partly to blame for me undertaking such a task anyhow !!! lol)
Anyway the problem is that the tube itself (Latex) seems to be stuck on the outside of the inside of the tyre if you get what I mean, so yes peel back the base tape split open the tyre and get in past the protective sheath but you can't seem to get to the (what I would call )the outside of the tube as it is stuck to the inside of the tyre ?
Would this just be from pressure and it should realize with a bit of careful peeling or is this stuck when the tube is manufactured ?
Is it or are they repairable in the conventional way ? Or a throw in bin job ?
Anyone done one ?
thanks
PostPosted: Mon Dec 03, 2012 6:59 am
i'll raise my hand to vinyl playback and choosing tubes over solid state, thought i've long since given up my nikon fm2n. can't vouch for my moral values. ;-)
PostPosted: Mon Dec 03, 2012 7:24 am
fdegrove wrote:
...listen to music using tube/valve electronics...
guilty as charged
PostPosted: Mon Dec 03, 2012 2:44 pm
Tubbie Guru
Hi,
That can only happen when the tubular has been injected with some latex based anti-puncture liquid.
Ciao, ;)
PostPosted: Mon Dec 03, 2012 4:55 pm
I've been through all 19 pages here and I have a separate post too asking this... :noidea:
First puncture on new Verdestein Fortezza TriComp Pro tubulars after 500km. They have a latex tube and came with my very first tubular wheelset (switching to Conti Competition butyl next). The hole is tiny and I have a 100mL can of Michelin Stop&Go. There are no instructions on how to use it anywhere!
Questions:
1) Do I use the whole can for the single tyre?
2) Do I inject the stuff while the tyre is fully deflated it or partially?
3) How quickly do I fully inflate the tyre and can ride on it?
Thanks!
PostPosted: Mon Dec 03, 2012 5:04 pm
Tubbie Guru
Hi,
Quite often 15 to 25ml of liquid latex suffice to fix a small puncture.
Since the can contains a propulsing gas it is best to use it when the tyre is deflated, usually the case when punctured...
Normally it only takes a few minutes for the product to solidify after which the tyre can be fully inflated to normal pressure and should be ready to use.
Pls. make an effort to at least search the forum for a solution to your problem. There is very little that has not been discussed yet. Thx.
Ciao, ;)
PostPosted: Mon Dec 03, 2012 10:09 pm
fdegrove wrote:
Hi,
Ciao, ;)
Thanks for the response, are you referring to when the tube sticks its self.....to its self ? As this is not the case, if not then are you saying that the liquid has soaked through the Latex tube and then stuck it all together on the inside of the tread ?
thanks
PostPosted: Tue Dec 04, 2012 12:01 am
Tubbie Guru
Hi,
It is not unthinkable that liquid latex finds its way through the puncture, between the inner tube and the casing, solidifies there making the two boundaries inbetween stick together.
Whatever it was I see no reason to actually open up that tubular just to separate the inner tube from its casing.
Ciao, ;)
Post new topic Reply to topic  [ 306 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21  Next
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
716
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. Attachment(s) Show us your UL WW flat repair kit! (pics please)
THUNDERHORSE
16
2409
Thu Aug 23, 2012 7:23 am
ilvwhtgrls View the latest post
There are no new unread posts for this topic. Aluminum frame modification/repair - is it possible?
prendrefeu
15
505
Fri Mar 01, 2013 5:45 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Helicoil repair for crank pedal thread?
Tinea Pedis
22
742
Mon Dec 31, 2012 11:49 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Tubular bag
mxdclt
19
1320
Mon Nov 05, 2012 3:02 pm
fdegrove View the latest post
It is currently Tue May 21, 2013 8:56 am
