Post new topic Reply to topic  [ 306 posts ]
Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 21  Next
 Post subject: Re: Tubular Repair
PostPosted: Tue Dec 13, 2011 6:46 pm
Tubbie Guru
Hi,
This may prove helpful for later:
http://sheldonbrown.com/brandt/tubular-repair.html
Ciao, ;)
PostPosted: Sun Jan 15, 2012 9:00 pm
Just got around to repairing a tub for the first time; a conti comp with about 100 miles on it :-/
thanks for all the valuable tips and info
:beerchug:
Official cafe stop tester
PostPosted: Fri Jan 27, 2012 6:43 pm
fdegrove wrote:
Hi,
Ciao, ;)
-"With the beads of the tire pressed against each other so that the old holes are exactly aligned, sew using a loop stitch pulling each stitch tight, going forward two holes then back one, forward two, back one, until the seam is closed. This is a balanced stitch that uses one thread and can stretch longitudinally. "
Can someone please post a drawing of what this should look like ? :oops: Just can't picture it...
Louis :)
http://www.ccsalma.com
PostPosted: Fri Jan 27, 2012 7:54 pm
Tubbie Guru
Hi,
It will look like this: xxxxxxxxxxxx
Ciao, ;)
PostPosted: Fri Feb 10, 2012 8:05 pm
Great resource about tubular repair, now it's time to go for my tubulars and make some practice :D
Born in lust turn to dust, born in sin come on in!
PostPosted: Mon Apr 09, 2012 8:57 pm
2000+ posts to my name so pots and kettles and all that, but I must say this thread still makes the mind boggle at the amount of time people have to fiddle about on this stuff :shock: Just binning three almost new tubs today if any of you seamsters are interested?
PostPosted: Mon Apr 09, 2012 9:12 pm
Heard that! The last time I repaired a tubular myself was when I was 19! Save 'em up and send them to TireAlert...
PostPosted: Mon Apr 09, 2012 10:59 pm
Tubbie Guru
Hi,
sawyer wrote:
2000+ posts to my name so pots and kettles and all that, but I must say this thread still makes the mind boggle at the amount of time people to have fiddle about on this stuff :shock: Just binning three almost new tubs today if any of you seamsters are interested?
How much time do you think it takes?
The only tubular I ever binned was one that was torn apart by a piece of rock. Still recovered the latex inner tube and the valve core though. Cheap, huh? :P
Ciao, ;)
PostPosted: Tue Apr 10, 2012 9:07 am
fdegrove wrote:
Hi,
Ciao, ;)
Judging by the tales of woe and re-works on this thread it takes many people quite a bit of time.
More time than throwing the tub away even for the most proficient I'm guessing. :wink:
PostPosted: Fri Apr 13, 2012 2:26 pm
I repaired and glued first tubular when I was 12. Old USSR tubulars. I remember, only one tub blew due to repair.
PostPosted: Sun Apr 15, 2012 5:18 pm
anybody tried tirealert.com he does repair on any tubular tire.
PostPosted: Sun Apr 22, 2012 6:48 pm
I managed to repair a tubular, but it doesn't hold air for many hours. I figured I'd put some Stan's sealant in it.
But I'd like to use it as a spare. Is it possible to put sealant in the tube, inflate the tire, and then deflate and fold it to use as a spare ?
Sorry if it's been discussed elsewhere...
EDIT: Found some litterature obn the subject. Guess it's a big no,no.... :oops:
Louis :)
PostPosted: Wed May 16, 2012 8:45 pm
If anyone of you guys have punctured tubulars that still have life in it, instead of trashing them you can always send them to me. I punctured 3 tubs in 3 weeks and at that rate I will run out of my budget and time repairing them. I punctured almost new EVO CX in todays race first 200 meters. Pissed.
PostPosted: Tue May 29, 2012 2:37 pm
Punctured a new Corsa Evo SC after less than 100km on it, a bit of glass got stuck in the type. Not happy is an understatment. Anyway I used a can of pit stop to get me home, do you think I can still get it repaired?
PostPosted: Thu May 31, 2012 3:55 pm
I share your paint. I have had the exact same experience 2 weeks ago : punctured a veloflex criterium after 150 km. So angry :twisted:
Post new topic Reply to topic  [ 306 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 21  Next
Users browsing this forum: Burgunder and 2 guests
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
716
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. Attachment(s) Show us your UL WW flat repair kit! (pics please)
THUNDERHORSE
16
2410
Thu Aug 23, 2012 7:23 am
ilvwhtgrls View the latest post
There are no new unread posts for this topic. Aluminum frame modification/repair - is it possible?
prendrefeu
15
505
Fri Mar 01, 2013 5:45 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Helicoil repair for crank pedal thread?
Tinea Pedis
22
742
Mon Dec 31, 2012 11:49 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Tubular bag
mxdclt
19
1320
Mon Nov 05, 2012 3:02 pm
fdegrove View the latest post
It is currently Tue May 21, 2013 12:42 pm
