Post new topic Reply to topic  [ 306 posts ]
Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 21  Next
 Post subject: Re: Tubular Repair
PostPosted: Sat Jun 25, 2011 11:58 pm
Tubbie Guru
Hi,
I hear the new range of Vitto is notoriously hard to repair by hand. Any feedback?
TIA, ;)
PostPosted: Tue Aug 02, 2011 6:15 pm
Zigmeister wrote:
Tug Boat wrote:
http://www.tirealert.com/
TB
FYI...I tried emailing these guys about repairing Vittoria Corsa CX 3210 TPI with the removable valves...never got a response...maybe they aren't in business although the website is still up.
I just called them to make sure that they are still around..."very much so" I was told. They answered the phone very quickly, my two popped tubulars are off for repairs and one is a Vittoria Corsa CX. I will let you know how that looks when it gets back. You may want to check your spam folder to make sure any e-mails from them did not get stuck there.
Christian.
PostPosted: Fri Aug 05, 2011 5:41 pm
lucifer 1306217 - Had same experience with base tape when I removed a Tire Alert repaired tire. No big deal really, but I'm using hexane which makes all this stuff easy peasy anyway. Didn't notice base tape took more glue than usual. Second your opinion on Tire Alert—Ron does fine work at a very reasonable cost.
PostPosted: Mon Aug 08, 2011 12:23 pm
I know tubular repair info: Change it with now one :beerchug:
PostPosted: Mon Aug 15, 2011 3:35 pm
Had a good experience w tire alert too. But that cotton base tape does soak up the glue!
PostPosted: Thu Aug 18, 2011 9:54 am
I might be a bit off topic there, but is there a shop in Europe that is willing to ship a Vittoria Pit Stop via ground to a fellow Europe country?
PostPosted: Sat Aug 27, 2011 5:52 pm
Try wiggle?
PostPosted: Mon Aug 29, 2011 6:59 pm
TO TUBULAR DOCTORS:
I'm trying to locate a leak on my Vittoria Corsa CX 320 tpi (23mm) tire. Almost new (50 miles), hit a huge pothole in a crit. The thread and sidewall show absolutely no marks or cuts. I guess there is a cut, or a pair of cuts in the tube from the shock. The wheel is fine.
I just can't put air inside , because it pours out almost instantly. I know it's around the valve area. I eliminated a leak inside the valve, I blew air with my mouth inside the valve, and the air leaks from somewhere around the base of the valve.
So I pulled part of the basetape off, and un-sew the string ( around 12-14cm). Can't see anything on the tube. Bad part is, with the tube exposed, when I try to pump air in, the thinner latex tube bulges outside, and I can't put enough air again to locate the leak.
What do you advise ?
- Un-do the whole tub, and swap the tube for a new one ? I have a latex Vittoria tube, but it looks thicker (red) than the tubular (green, with removable valve core) one.
- A good way to locate leaks in a "sugically semi opened" tubular ?
- Can the base of the valve be cracked from the hit ?
Louis :)
http://www.ccsalma.com
PostPosted: Mon Aug 29, 2011 10:47 pm
Tubbie Guru
Hi,
Some tubulars move in mysterious ways.... :lol:
So it does hold air now? :shock:
What I don't understand is that air fled out almost instantly before the casing was opened and now that you did, it doe's no longer...
I suppose when the tyre was reinflated, the punctured area didn't receive any air, hence the bulging. Try to reinflate with the tubular mounted on a spare rim/wheel while keeping an eye on the bulging area. Put in 10 to 15 psi, no need for more.
For a tubular to not hold air at all you'd need a big hole in the inner tube so check the obvious suspects as well: valve core tight enough, extender or stub damaged? That kind of thing.
Keep us posted, ;)
PostPosted: Tue Aug 30, 2011 6:14 pm
ElDuderino wrote:
Hey fellow tub peoples...
Liquid latex: where to get it stateside?
Every hardware store or art supply place I walk into just looks at me strangely when I ask about it. Is it known by any other name perhaps?
I got some tires with plenty of tread but tired sidewalls that could use some love...
I found "Latex Seam Sealer" at my local Southern Cal Lowes in the carpet section, look where they have installation/repair supplies for carpeting.
PostPosted: Thu Sep 01, 2011 12:54 am
Keep us posted, ;)
I located the hole. Pretty big, almost opposite the valve. For the "bulge", I suspect the tube is weaker/thinner on that area because it still bulges instantly when the pressure goes more than a few PSI's. What would you do ? I can change the tube completely, and put a standard latex Vittoria (without removable valve though), or repair this one.
Louis :)
PostPosted: Mon Sep 05, 2011 11:19 pm
Tubbie Guru
Hi,
Sorry about the late reply, lost track somehow.
You can do either of your suggestions I guess. I just hope you haven't removed 3/4 of the seam already to get to the punctured area?
Any chance of a pic of the puncture or the tub as it is now?
Ciao, ;)
PostPosted: Tue Sep 06, 2011 5:03 pm
Ciao, ;)
More like 4/5 removed to find it... :cry: I'll try to post a picture or two, once I grab the wife's Iphone.
The "substance" under the basetape is pretty tough to pull off. Feels more like an urethane based rubber :noidea: . I took about 25% of the old string with tonsils, bit by bit, thru the "coating/baseglue"...
For the moment, I'm leaving it on the casing (don't tell me I have to remove it all before gluing the basetape back on !!!). Just removing the old seam, repairing the puncture, and sewing everything back in.
I still have to order some liquid latex to glue the basetape back on the tire...
...Lots of fun in perspective for the off season :)
Louis :)
PostPosted: Thu Sep 08, 2011 9:44 am
http://www.heino-cykler.dk/Komponenter/ ... acing.html
Had trouble finding one too.
My Intro, TT bike and Aero/WW Upgrade plan
"A forum post should be like a skirt - long enough to cover the subject material, but short enough to keep things interesting."
PostPosted: Mon Sep 12, 2011 2:04 am
fdegrove wrote:
Hi,
Ciao, ;)
Here pictures of the punctured tube:
Pretty big task to come (almost 80% of the seam was cut to find the puncture):
Parts where the base-material was removed, exposing the string:
I pulled the base-"rubber like material" to see if it was removable...:
Louis :)
Post new topic Reply to topic  [ 306 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 21  Next
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
715
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. Attachment(s) Show us your UL WW flat repair kit! (pics please)
THUNDERHORSE
16
2409
Thu Aug 23, 2012 7:23 am
ilvwhtgrls View the latest post
There are no new unread posts for this topic. Aluminum frame modification/repair - is it possible?
prendrefeu
15
502
Fri Mar 01, 2013 5:45 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Helicoil repair for crank pedal thread?
Tinea Pedis
22
741
Mon Dec 31, 2012 11:49 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Tubular bag
mxdclt
19
1311
Mon Nov 05, 2012 3:02 pm
fdegrove View the latest post
It is currently Mon May 20, 2013 3:04 pm
