Misc bolt list
by Leon
+1 for the figures from SRAM.
Thank you!
Edit: make it stick!!
Klein: handbuild science!
by mrowkoob
Any changes for campy 11 speed?
The unbearable wallet lightness of being a weightweenie
by mitre_tester
Boonen wrote:It's not much but it's something:
2007 SRAM Force rear derailleur:
Limit screws: 2 times M4x14 Buttonhead
Tension screw: M4x20 Buttonhead
Pulleywheel bolt upper: M4x14 Countersunk
Pulleywheel bolt lower: M5x14 Countersunk
Pinch bolt: M5x8
All these bolts are steel and IMO can be replaced by aluminium bolts saving around 5.5 grams. The pivoting bolt is already aluminium.
Sizes are good for Rival too. I used Ti grub screws for the limit and b-tension, Ti for the upper pulley bolt and Al for the cable clamp, saving approx 6g total. The lower pulley bolt has a smaller head than a standard M5 countersunk screw, looks like the KCNC one would fit but they're way too expensive at £10/pr
by Timo
madcow wrote:Ergo Shifter
Pivot fixing bolt M4x22 (Socket head)
Ergo Mount M6x10-12mm(Brake mount nut)
Are these made of steel or titanium in standard 10 sp Record Ergo shifters?
And if I ever meet an aardvark, I'm going to step on its damn protruding nasal implement until it couldn't suck up an insect if its life depended on it.
