It is currently Sun Jan 21, 2018 4:01 pm
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: My latest wheel build.
PostPosted: Wed May 11, 2005 6:02 am
WWotY 2007
Hey!
I've built a very interesting rear wheel composed of an Ambrosio Crono f20 rim and Dura ace 7800 hubs with 28 Cx-ray spokes.
Check the link
Of course it's in french but you don't need obligatory to read in order to see the pictures :)
Adrien.Regards.
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Wed May 11, 2005 7:48 am
Nice, love the classic-look!
I have been wondering about the crono f20 rim, is it easy to build stiff? The Mavic reflex rim has a tendency to give if it is pushed too hard..
where can one buy the rim?
 Post subject:
PostPosted: Wed May 11, 2005 10:27 am
Mavic Reflex and Ambrosio Chrono are about on par stability wise. Besides my Heliums I run a set of tune/DT aerolite/Reflex at around 1350 grams as a great performer in crits where a bit of flex over rough surfaces and in turns is a very good thing. No excessive truing required though (rider is ~ 72 kg/159 lbs).
 Post subject:
PostPosted: Wed May 11, 2005 3:37 pm
i'm getting mine tomorrow. Ive got the same wheels build, but i have a 32 hole version. hoping it will be stiff.
The waranty is gone on the hubs because i build the front wheel radial.
Will this give any problems???
 Post subject:
PostPosted: Wed May 11, 2005 4:36 pm
Nice weight on the rim!
You could have built them up with a Tune MAG190 rear hub and saved about 70g but the DA7800 is a good durable hub also from what I understand.
Did you use brass or alloy nipples (or some combination of both)?
 Post subject:
PostPosted: Wed May 11, 2005 9:21 pm
WWotY 2007
The TUNE mag 190 are much more expensive than the DA 7800, so I chose the shimano one.
The nipples are alloy ones. (those ones which comes with the spokes).
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Wed May 11, 2005 10:43 pm
You can do radial on new DA front hub, they say it in their literature. They make one all they way down to an 18 hole drill too. Not sure what it says in the warrantee, but assume it would be covered.
 Post subject:
PostPosted: Wed May 11, 2005 10:48 pm
Very cool rear wheel. I am also building a wheelset with the Ambrosio Crono f20 rims but theirs is not standing Ambrosio with the same large words as yours. Have you made it your self or is my rim new/older version??
Sine Pondus - Without weight
www.velosport.dk
 Post subject:
 Post subject:
PostPosted: Thu May 12, 2005 5:57 am
WWotY 2007
Yes this is the latest decals. I also have one rim like you with the small words. I keep this one for the front.
RAR wheels
Roues Artisanales
There are no new unread posts for this topic. Jockey Wheel Help!
JScycle
Mon Jun 26, 2017 5:32 pm
2lo8 View the latest post
There are no new unread posts for this topic. Wheel choice.
blueturtle
Thu Jan 26, 2017 1:36 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Attachment(s) How much clearance have to need between wheel and tire?
Chans1ee
9
564
Sat Jan 06, 2018 3:58 pm
dim View the latest post
There are no new unread posts for this topic. How far are your bars behind your front wheel axle?
rothwem
44
2515
Thu Nov 16, 2017 4:19 pm
evan326 View the latest post
There are no new unread posts for this topic. Attachment(s) RD-R9150 wheel removal issue
beanbiken
29
2448
Tue Mar 28, 2017 1:05 pm
ms6073 View the latest post
Users browsing this forum: Baidu [Spider], Butcher, csteeds, glepore, ride1970 and 44 guests
cron
