It is currently Thu Oct 19, 2017 3:09 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Jan 08, 2010 9:46 am
What is the # I should look for with the park tension meter for my wheelset. I have a 32 hole 2x build velocity aerohead, aerolites, and chris kings...... Not sure what ND side, drive side, and front tensions should be at..... (just the # on the tension meter, 7,9,10,15, etc). Thanks in advance.
PostPosted: Fri Jan 08, 2010 9:56 am
Depends on your rider weight really but around 100 kgf would be good for the average rider.
For an Aerolite that would be 13 on the Park scale.
For my weight (around 80 kgf) I'd go with 12 on the front and 13 on the DSR, the NDSR will be about 50-60% of the DS but it's not really relevant anyway as you just get whatever is reflected from the DS anyway depending on the hub dimensions.
Cheers, Rob.
Pedalling Law Student.
PostPosted: Fri Jan 08, 2010 10:05 am
Cheers, Rob.
I'm 140-145 lbs..... (65.77 kg)... should have stated that before. :wink:
PostPosted: Fri Jan 08, 2010 12:07 pm
You may want to go a little less then, unless you like your wheels very stiff?
Knock a number off that scale down to 11 for the front and 12 for the DSR.
Cheers, Rob. :)
PostPosted: Fri Jan 08, 2010 8:07 pm
Awesome! Thank you so much! Time to go tighten these up! (God I hate truing/tensioning wheels)
PostPosted: Fri Jan 08, 2010 8:58 pm
13 on the Park tool (if it's correctly calibrated) will be 1000Kgf
I wouldn't go any lower than that or your NDS spokes will not have sufficient tension to stay tight, especially with the King hub which has quite wide flange spacing.
Wheelworks.co.nz
New Zealand handbuilt wheels
PostPosted: Fri Jan 08, 2010 10:09 pm
I have a Park TM-1 meter conversion table here in front of me and it shows 13* = 100Kgf (*2.1/2.3x.9mm bladed steel)
When I recently built myself some 32h, 3x, Nemesis and Record wheels the DS spokes had to be tensioned to 130Kgf in order to correctly dish the wheel and achieve 60Kgf on the NDS spokes.
PostPosted: Thu Aug 09, 2012 10:34 pm
If you want it, you can download a copy of the Park tension meter figures from their website.
PostPosted: Fri Aug 10, 2012 2:01 am
100kg is near 1000N...
higher spoke tensions does not equal a stiffer wheel. to a point, it equals greater resistance to detensioning due to spokes going slack when hitting a bump. with aerolites (and similarly cx-rays), 130kg is an often-quoted number to aim for. it's a non-eyeletted, relatively light rim, so a little lower than that may be better, someone that builds that exact rim a lot can chime in on that aspect.
the figure is for the right rear. left rear is whatever it needs to be. front, i build to the same as the right rear, i just err a little lower.
There are no new unread posts for this topic. Park Stand - PRS-20
p3dalfaster
Thu Apr 20, 2017 8:22 pm
goodboyr View the latest post
There are no new unread posts for this topic. Park Tool DS-1 Digital scale discrepancies...
octave
9
784
Sat Jan 21, 2017 12:33 am
2old4this View the latest post
There are no new unread posts for this topic. Tools Required to File Down an ISP
hogehoge
Tue Jun 13, 2017 10:02 pm
2lo8 View the latest post
This topic is locked, you cannot edit posts or make further replies. Lightweight Multi Tools / Pumps - What are you carrying thread?
vneilv
12
925
Wed May 24, 2017 2:46 pm
Hawkwood View the latest post
There are no new unread posts for this topic. Campagnolo TOOLS UT-FC220 - Over-Torque crankset assembly and disassembly tool
moccacaffee
Fri Mar 10, 2017 4:44 am
ferrarista View the latest post
Users browsing this forum: bikerjulio, Drpoomanchu, Google Adsense [Bot], jcjordan, JeffK and 37 guests
