Post new topic Reply to topic  [ 63 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 08, 2010 3:23 am
tks for clarifying that guys!
seems the chorus is the way to go for value
PostPosted: Fri Jan 08, 2010 4:13 am
I already have mine but while getting some tools online I came across the Park CT-11 (Campagnolo Rivet Peening Chain Tool) from Tree Fort Bikes for just under $36. Quite cheap indeed. Just thought some might want to know...
Seven Axiom Ti, Reynolds UL Fork, Campagnolo Super Record 11
In Progress: Salsa Podio, Alpha Q GS10 Fork, Campagnolo Chorus 11
PostPosted: Fri Jan 08, 2010 4:26 am
@Ari
"Indianapolis, Indiana - Soon to be Denver, Colorado"
Wow, you might need a different Campy 11 speed cassette soon. :wink:
BTW, I grew up in Valparaiso
PostPosted: Fri Jan 08, 2010 4:35 am
What exactly is required to get the pin in and out? Anything special?
As I might look at the Park tool in that case...
PostPosted: Fri Jan 08, 2010 4:40 am
Yah, I'll need a 12-27 but don't know that I can bring myself to do it !!!!
I am from LA (Calabasas). Small world.
occor wrote:
@Ari
PostPosted: Fri Jan 08, 2010 6:30 am
The Colorado Rockies might force you. I shameless use a 12-27 x 53/39 combo which comes in handy in the San Gabriel and Santa Monica Mountains. I don't use the 27 and 25 very often but they definitely come in handy once in a while.
PostPosted: Fri Jan 08, 2010 6:41 am
You need the Park tool CT-4.2 chain tool and the Park CT-11 rivet peening tool. Both are well made and do a great job but perhaps not as classy as the Campag
WW Velocipedist Gargantuan
PostPosted: Fri Jan 08, 2010 7:09 am
I use to do Tuna Canyon in 21 x 39. Then again....I use to weight 135 and don't now.
PostPosted: Fri Jan 08, 2010 7:11 am
Best price from Ribble a week ago on sale extra 20% was still $140 shipped to the US for the Campagnolo 11 speed chain tool whereas you can get the Park CT-4.2 and the CT-11 for under $80 shipped in the US and use the CT-4.2 for other chains besides Campagnolo 11.
Both the Park and the Campagnolo tool have replaceable parts.
PostPosted: Fri Jan 08, 2010 7:31 am
Think I might simply go the Campy tool.
Can't find the Park ones on Ribble :noidea:
PostPosted: Fri Jan 08, 2010 7:40 am
Might be able to get the Park one through your LBS. Might be closer to $50 USD each but that's a lot cheaper and you get the advantage of the CT-4.2 for other chains, including 7900 DA. I have some Campy tools but just couldn't bring myself to pull the trigger when the two from Park give me so much more bang for the buck.
PostPosted: Fri Jan 08, 2010 7:58 am
I'm 42, I can do Tuna Canyon in 21 x 39 and I haven't weighed 135 since well before puberty. :P
PostPosted: Fri Jan 08, 2010 1:31 pm
I use a 12-27. You've got an additional gear over 10-speeds, so why not make life easier!
And don't forget there is also now a 29. You can buy it in a separate 3-cog cluster if you want. Just don't make that chain too short when you first fit it.
Under the Sun - a thriller for weightweenies with bike loving main character on Kindle here
PostPosted: Fri Jan 08, 2010 1:35 pm
At 42 that's great! La Tuna in 21x39 is easy, Tuna in the sane is fantastic.
PostPosted: Fri Jan 08, 2010 2:33 pm
Most late model 10 speed chain tools will work fine with an 11 speed chain. To be sure, look at what part of the chain takes the force of the driving pin. The inner plates should not be taking the force, against the U-shaped center guide. The back of the chain should be taking the force. If the center guide is too thick, file it thinner, but be sure to file down the side nearest the drive pin. I've done this and my old Park CT-3 tool still works.
The only issue with any tool other than Campy's is they do not hold both ends of the chain together. It's critical that there is no chain tension if some other brand of tool is used. Otherwise, the pin will be misaligned and likely bend the guide pin, resulting in a failed attempt at installing the pin.
If a second joining pin is installed, the first one is left in place and the second put far away from the other one. If I install a master link, I remove the original joining pin.
I bought the Campy tool for about $140 in November 2008, since there were no other options at the time.
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: Exabot [Bot], ipaul, Kermithimself, RussellS, thatdkid, TrekUk, ttakata73 and 57 guests
There are no new unread posts for this topic. 11 speed Shimano free hub body with 10 speed DA cassette
WasFab
10
838
Fri Apr 12, 2013 9:31 am
dha View the latest post
There are no new unread posts for this topic. Shimano 10 speed + Campagnolo 10 speed cassette
rhyslewisdavies
Tue Jan 15, 2013 12:10 am
bm0p700f View the latest post
There are no new unread posts for this topic. 11-speed cassette question
darkspeedworks
9
843
Sun Mar 17, 2013 1:55 pm
darkspeedworks View the latest post
There are no new unread posts for this topic. Ultegra Di2 with 9-speed cassette
freeloader
Thu May 16, 2013 1:16 pm
There are no new unread posts for this topic. SRAM XX1 XG1199 11 Speed 10-42T Cassette
KLabs
21
1396
Tue Feb 12, 2013 10:06 am
kudeta View the latest post
It is currently Sat May 25, 2013 8:56 pm
