It is currently Sun Feb 26, 2017 2:17 am
 Post subject: thm carbones scapula sp
PostPosted: Sun May 08, 2005 11:03 am
Does anyone have any ride time feedback on these beauties?
 Post subject:
PostPosted: Sun May 08, 2005 5:47 pm
Obviously not then. So any opinions on these versus the Stork Stilleto Light. I know the Stork's carbon steerer is wrapped in kevlar to prevent damage between the stem and steerer, is there a similar method used on the thms.
 Post subject:
 Post subject:
PostPosted: Sun May 08, 2005 5:59 pm
I have only 3 rides on a Scapula SP tuned, cut to 175mm 229 grams. The steerer did have kevlar in it. The fork was very stiff and rode great, of course I'm only 122lbs. The nicest fork I've ridden in the sub 300gram category.
But just like their site says the oval inside diameter of the steerer does make things a little different.
" Some creativity required when adjusting the head set is the only trade-off for this record-breaking fork. A common method is to carefully preload stem and fork using a long screw clamp until the stem is securely fastened to the steerer. However, average hand strength usually suffices as well to get enough preload on the headset until the stem has been fastened."
So if absolute lightest doesn't matter to you, I'd go with the standard SP.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
 Post subject:
PostPosted: Sun May 08, 2005 6:24 pm
Wow, a 229 gram fork? How'd you get it in the states?
 Post subject:
PostPosted: Sun May 08, 2005 6:55 pm
It was delivered to a friend of mine in Germany, then rerouted back.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
 Post subject:
PostPosted: Sun May 08, 2005 7:24 pm
You can also order through our host starbike. Mine shipped last week.
 Post subject:
PostPosted: Sun May 08, 2005 10:16 pm
AKA "The Nils"!
Hi happydazzze,
I can report you in about 1/2 a week.
My fork (Scapula SP) is said to come tomorrow (well already was said to come last week and has already been paid - but that's another story :-)) and is to replace my Storck Stiletto Light (299g/195mm w/ the alu steerer), which has served me for some 40k kms, so I will be able to give you first hand news next week.
Cheers pk0r
| http://www.ax-lightness.de |
| pk0r.com | "I respect the work in coloring parts but the result is stupid-monkey in silk clothes is still monkey." |
 Post subject:
PostPosted: Tue May 10, 2005 12:08 pm
well I bit the bullet and ordered a Scapula SP from poshbikes yesterday and will add feedback in a couple of weeks time, when I get my frame. The steerer is wrapped in kevlar, as is the storck, to prevent damage between the stem and carbon. It will be half the weight of my previous fork and much stiffer I hope.
 Post subject:
There are no new unread posts for this topic. Chris king Inset 7 with THM SCAPULA CT
elfuinha
18
909
Tue Jun 07, 2016 7:34 am
elfuinha View the latest post
Users browsing this forum: AZR3, Baidu [Spider], Bing [Bot], djbowen99, Donic, hamd, latsride, Yahoo [Bot] and 13 guests
