SRAM Red Rear Derailleur Tuning
What's the comparative weight of the Red pulleys, KCNC pulleys, and your pulleys?
Ideally you could reserve those pulleys only for hillclimbs. But swapping pulleys is an obvious hassle.
- coloclimber
- Moderator
Nice work.
3 spoke pulleys is a but too risky for me.
You could shave even more weight with nylon screws for the adjuster bolts.
Word from GoldKnight is that the Lightweight RD is 106 grams with different pulleys and backplate.
-Deacon Doctor Colorado Slim
coloclimber wrote:Nice work.
even better, 97g! (found on a french board, this isn't mine!)
- Gold Knight
man that LWRD makes mine look like a larda$$ at 106g as Coloclimber mentioned. So i need to shave another 9 grams for alloy bolts that i have no idea where to get and i don't know french or i would ask the person!
DO NOT RIDE AN AX-LIGHTNESS FORK
Could we perhaps get a parts list and where to buy. It is WW after all I would really like to tune my Red RD like that.
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
I checked my spreadsheet and my stock Red is 145 g. Not too bad for stock.
- Frankie - B
- Admin - In the industry
Wow! I need red as well!
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
I think we all do with weights like that. The only thing that puts me off is the graphics, although Force is a little bit more understated; and slightly heavier. If I had known that Shimano cassettes run better than SRAM, I would have maybe pulled the trigger.Frankie - B wrote:Wow! I need red as well!
- Frankie - B
KB, sandpaper and a rattlecan do the job
- prendrefeu
- Contact:
Hmmm...
I do believe that this was already covered in a thread here, but I'm too lazy to search for it right now (maybe in a few minutes, I will...)
Anyway, basically some guy took a stock SRAM Red RD, then applied this bolt kit, some KCNC pulleys, and brought it down to 127g or something. Then some other dude wrote about is 122g RED RD after adding the carbon back plate...
blah blah blah, yackety-schmakety...
Yeah, it's been covered before. Now if only I could have the energy to find that thread to refresh your collective memories...
- prendrefeu
- Contact:
Okay,
Here: Already Covered in topic.
viewtopic.php?f=3&t=51165&hilit=sram+red+122g
That didn't take that much work to find. But I'm still feeling lazy tonight.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
this is what i'm looking for my campa record. i guess this persons have parts for sram, shimano ... aswell
Here is my 126gr sram rd.
-carbon pulleys
-custom carbon backplate
-All bolts tuned to alloy (Except for ti pinch bolt. but this is mostly cosmetic as all red RD bolts are already alloy)
Tuning barrel adjuster and spring may drop the weight below 120gr.
-carbon pulleys
