Post new topic Reply to topic  [ 10 posts ]
 Post subject: Light Weight Bolts
PostPosted: Fri Nov 14, 2003 5:30 pm
Anyone know of any place I can get lightweight screw and bolts. I am not familiar with what all the sizes are that I currently need, but I would like to just send all of the screw and bolts I have to someone and have them make the equivalent in Ti or aluminum. Does Bike Tune Services do this (there link is in the links section, but its not in english)?
 Post subject: Tasty Nuts
PostPosted: Fri Nov 14, 2003 5:39 pm
It doesn't say in your profile where you are from but if you're in the UK check out www.tastynuts.com , they mainly do stuff for motor sport but stock all the common sizes needed for bikes (M5, M6) in several different head types and lengths.
Bolts are available in aluminium or titanium, anodised in different colours even the ti ones are available in gold or blue.
They also do custom stuff if you can provide them with samples or technical drawings.
 Post subject:
PostPosted: Fri Nov 14, 2003 5:51 pm
Racebolts LLC -- http://www.racebolts.com
Ti Kinetics (Ti only) -- http://www.tikinetics.com
Redmist -- http://titaniumfasteners.com/shop/
Mettec (Ti only) -- http://www.mettec.com/
TekBolt (Ti only) -- http://www.tekbolt.com/
Bike Tuning Service (Germany) -- http://home.t-online.de/home/bts.renz/homepage.htm
Titan Concept (Germany) (Ti only) -- http://www.titan-concept.com/
BSR (UK) -- http://www.bsr-aerotek.com
Pro-Bolt http://www.tastynuts.com/
SRP -- www.srp-usa.com
B-T-P -- http://www.b-t-p.de
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Fri Nov 14, 2003 6:08 pm
I'd go with SRP-usa.com . There the easiest to get bolts from and they have everything.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Fri Nov 14, 2003 7:30 pm
If you want to hve a really light bike you should be prepared to learn some things. I know it be frustrating sometimes but if you put some time and energy into it you'll get it.
One thing that has helped me with nuts and bolts is a caliper. Here's a pic of one. be sure to get one that is in metric. They're not that expensive and they will tell you what size things are. Here is a site you can buy one at. They come in different qualities. www.woodcraft.com
 Post subject:
PostPosted: Fri Nov 14, 2003 8:14 pm
Thanks for all the info guys! It all helps.
 Post subject:
PostPosted: Fri Nov 14, 2003 8:32 pm
One more question. Looks like I have plenty of places to choose from. Are they all going to be about the same weight and quality. Also, alunimum vs. Ti. Pros and Cons?
 Post subject:
PostPosted: Fri Nov 14, 2003 9:03 pm
http://weightweenies.starbike.com/articles.php?ID=16
Good article from Nino, you'll learn something!
 Post subject:
PostPosted: Fri Nov 14, 2003 9:13 pm
I have a Pinarello Prince with full Record and I want to make him lighter
Can ou gain the most weight with bolts than with buying other components for the same price, in general?
 Post subject:
PostPosted: Fri Nov 14, 2003 9:15 pm
http://www.ingenieurtec.de/ :P
Users browsing this forum: Bing [Bot], Bobaslim, caballero, Google Adsense [Bot] and 50 guests
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2609
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. Light weight alu tubulars?
cerro
23
1519
Thu Sep 13, 2012 1:32 am
bluhorizan View the latest post
There are no new unread posts for this topic. Light weight Triple Crankset
pow216
25
1633
Fri Nov 02, 2012 3:45 pm
AdsH View the latest post
There are no new unread posts for this topic. Light weight brakes that really work!
[ Go to page: 1, 2, 3, 4, 5 ]
rockdude
71
4401
Sun May 12, 2013 3:43 am
pawnii View the latest post
There are no new unread posts for this topic. light weight FD shimano clamp?
Bianchi10
15
557
Wed Sep 19, 2012 4:28 pm
ecguevara View the latest post
It is currently Mon May 20, 2013 3:22 am
