It is currently Tue Jan 23, 2018 11:11 am
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Which tubular tire?
PostPosted: Sun Mar 23, 2014 11:49 pm
I commute on Gators, with 60ml of Revo sealant in them- every now and again I have to pump them up a bit but other than that they're great.
I'd not use them on the fast bike, but they're not without a use-case in which they perform very well.
PostPosted: Sun Mar 23, 2014 11:57 pm
In that case, gatorskin works great for commuting; I just cringe every time I see gatorskins glued to race day only wheels because someone is afraid of flatting out of a race... Even if a 2min flat change would leave them irrevocably dropped.
How do the gators feel with the revo injected?
PostPosted: Mon Mar 24, 2014 12:03 am
I can't tell the difference personally- no downsides apart from a very marginal weight gain.
I was running Veloflex Roubaix on this bike (Serotta CSi) and killed four in 300 miles, the Gators have knocked out 1,200 now- and have had punctures, but they've sealed themselves with a minor drop in pressure.
PostPosted: Mon Mar 24, 2014 2:20 am
Tubbie Guru
Hi,
No idea how that happened but that's a lot of expensive tubs for 300 miles. I easily get at least 2K km out of a Veloflex Carbon without flatting.
Ciao, ;)
PostPosted: Mon Mar 24, 2014 2:53 am
Same here, around 2k miles each before I have ridden the lines off. So far three veloflex Arenberg/Roubaix tires with no flats. Fairly crappy new england roads with tons of roots, debris and potholes. I do add about an ounce of Stan's to each tire once glued on. They seem really durable. I am kind of itching to try the pair of FMB Comp cx tires I have sitting in wait, but these Veloflex won't die.
PostPosted: Mon Mar 24, 2014 8:30 am
They don't like flint.
PostPosted: Mon Mar 24, 2014 7:59 pm
We have 4 Veloflex Records. Never flatted one in about 600K racing. 3 pin hole flats in the FMB Competition cx 25s, one pin all the way through the tyre and will send out to get tube replaced and the only one that happened during the race. The 3 were patched with Pit Stop. Maybe unlucky. Hard to tell. I'm going lighter on the FMBs. Still wish the Veloflex Records were wider.
PostPosted: Mon Mar 24, 2014 8:48 pm
Tubbie Guru
Hi,
Ironically the main reason why I actually use these and not most other top tiers is because they do not tend to pick up flint shards or cut up very easily.
Said it a hundred times before but why not buy tubs in the off-season and age them for at least a couple of months. IME it makes all the difference between premature punctures and no punctures at all.
It doesn't cost a dime so, why not try?
@Zoro: Record is what its name suggests: a tyre designed for timed record setting events. Have you tried Sprinter/Extreme? They're about the same tyre and weigh just a bit more than what Record would weigh in that size, give or take a bit.
Record/Servizio Corse need some getting used to as they're very narrow at 20mm. Feels like running on ice-skates.
Love them for high speed straight line riding though. (high speed is relative at my age :oops: )
Ciao, ;)
PostPosted: Mon Mar 24, 2014 9:28 pm
These were aged a couple of months, in a cool dry place etc etc.
The issue is not that they cut up, but that they lack anything that keeps the cut from going right through the carcass- so the flint slices the inner tube rather than putting a pin-prick hole in it which sealant can (and generally will) take care of.
To be fair to them riding them through a British winter was never going to be a happy time for them, and they're now waiting for summer when the roads are not awash with flints ready to kill them.
PostPosted: Mon Mar 24, 2014 10:09 pm
Tubbie Guru
Hi,
Fair enough. There's flints and bare flints, right? :mrgreen:
That time of the year I dig up the good old Neutrons and mount something less costly. After all, Veloflex are Italian tubs....
Cheers, ;)
PostPosted: Tue Mar 25, 2014 11:53 am
In Hungary,many-many rider use Tufo Tyres :)
http://www.tufo.com/tubulars/
PostPosted: Tue Mar 25, 2014 1:21 pm
Dammit - I ride in Surrey and Kent a lot so have similar flint problems and I had a lot of luck with Pave's this winter. I did eventually flat but that was a winter series crit at Hillingdon and was one of those races where you spent the entire thing listening to the ping of stones bouncing off downtubes (no idea how Hillingdon got covered in gravel).
PostPosted: Tue Mar 25, 2014 1:23 pm
yes, Vittorias seem to be very old fashioned, as in no protection layer. I used to ride a Vitttoria tubular &flatted every other ride. This version had a "kevlar" belt (which I could cut with a scissor.
PostPosted: Tue Mar 25, 2014 3:20 pm
I like Tufo tubulars.
PostPosted: Fri Mar 28, 2014 9:01 am
I've just bought a Conti Force Comp and it seems tighter than ever ; maybe it's because this one's 'fatter' (24mm) than the GP4000 I've been riding before ...
I'm gonna let it stretch on an old rim for at least one week
GT7100 >> Tapatalk
Road: Cervélo SLC '08 = 6977g
MTB: Merida Matts FLX Team '07 = 10430g
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
22
1629
Mon Oct 23, 2017 9:19 am
themidge View the latest post
There are no new unread posts for this topic. Schwalbe One tire weights?
2lo8
Sun Jun 25, 2017 12:28 am
gewichtweenie View the latest post
There are no new unread posts for this topic. Pinarello F10: tire clearance?
TonyM
7
1261
Wed Dec 13, 2017 6:45 am
phm8147 View the latest post
There are no new unread posts for this topic. Attachment(s) How much clearance have to need between wheel and tire?
Chans1ee
9
565
Sat Jan 06, 2018 3:58 pm
dim View the latest post
There are no new unread posts for this topic. Colnago C60 tire compatability
mnmasotto
Fri Sep 22, 2017 11:49 pm
Johnnysmooth View the latest post
Users browsing this forum: BdaGhisallo, bobones, Google Adsense [Bot], joejack951, Kaboom, wobbly and 35 guests
