It is currently Mon Jan 22, 2018 7:43 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Convert lbs/in to NM/0
PostPosted: Mon Apr 11, 2005 1:34 am
I'm trying to convert 745 lbs/in to the more common NM/Degree, how does one do this what does it equal, thanks.
 Post subject:
PostPosted: Mon Apr 11, 2005 1:59 am
http://www.onlineconversion.com/torque.htm
"Gimondi รจ un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Mon Apr 11, 2005 2:02 am
:google: convert lbs/inch to N/m
You get:
1 pounds force / inch = 175.126835 Newtons / meter
 Post subject:
PostPosted: Mon Apr 11, 2005 3:13 am
I got the 745 lbs/in fromt the Specialized Website as the BB stiffness for the S-Works Tarmac. I'm trying to convert it the the measurement which Tour Mag uses NM per degree, any help?
 Post subject:
PostPosted: Mon Apr 11, 2005 11:23 pm
It's 83.608 NM.
 Post subject:
 Post subject: Not sure its possible
PostPosted: Tue Apr 12, 2005 1:23 pm
I'm not sure its possible, without knowing the distance at which the measurement is taken.
At the moment you are trying to convert a force to deflect a linier displacement to a force to deflect a angular displacement.
With the distance to displacement measured the then a angular displacement can be calculated and then its just the force that needs its units converted.
Success is how far you you bounce back up after being knocked down
There are no new unread posts for this topic. SRAM etap convert to wifli
Pschnei3
Tue Sep 05, 2017 2:31 am
Pschnei3 View the latest post
There are no new unread posts for this topic. Convert Rotor QXL to single front ring
hanzypanzy
Wed Feb 08, 2017 10:50 am
hanzypanzy View the latest post
Users browsing this forum: Baidu [Spider], darnellrm, IrrelevantD, JScycle, nobuseri, prebsy, simnorm, snowdevlin, wheelbuilder and 46 guests
