It is currently Tue Jan 17, 2017 12:33 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Sun Apr 10, 2005 8:24 pm
I have a set of wheels that has a 9-speed DA cassette, what is the best way to convert it to work with 10 speed Campy dietarian. I assume it will not work as is. Has anyone used a Wheels Manufacturing cassette? How did it work? What other options do I have.
 Post subject:
PostPosted: Sun Apr 10, 2005 8:56 pm
Resident Pro
best things:
1)buy a 10speed campy hub body(if its replacable!) But you will have to buy a cassette also! BEST WAY!
2)Buy a 10speed DA cassette, will work. BANDAID FIX!
3)Buy a 9speed STI(not the best way!) DOWN GRADING!
Problem you have is, the difference from 9speed and 10speed is not just an extra gear on the end. Its an extra gear pushed in the middle! meaning the distance from each sproket is different.
I have seen a 9speed cassette working with a 10 speed BUT! at the end it didnt shift well. It can work pretty slopply but you dont want to do that.
you have to spend some money!
PostPosted: Sun Apr 10, 2005 10:05 pm
worked for years for converting from shimano cassette body to campi
http://www.amclassic.com
 Post subject:
PostPosted: Sun Apr 10, 2005 10:24 pm
Wheels Mfg is a good solution. They basically put corrected spacers in an ultegra (or DA) cassette and provide spacers for you to tune where the cassette comes up agains the hub body on the inside. Works well, i have one.
With a little more money you can get a Ti Cycle dynamics. Lighter and more custom choices on gearing.
http://www.bigtwincycling.com/cycle_dyn.htm
 Post subject:
PostPosted: Sun Apr 10, 2005 11:24 pm
Hm, i only see Campy->Shimano conversion sets there, not the other way around. Am i blind?
I, too, like my Wheels Mfg 10-speed Casette, btw. Lighter than the AM Classic
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Mon Apr 11, 2005 1:57 am
I think they mean campy spacing on a shimano hub ..Well, more specifically:
http://www.bigtwincycling.com/titanium_ ... g_sets.htm
I've never heard of anyone doing shimano spacing on a campy hub. Is there even an interest in that, now that DA has 10-speed, maybe?
 Post subject:
There are no new unread posts for this topic. Campy 10 Speed left shifter with 11 Speed everything else?
toronto-rider
Tue Sep 06, 2016 1:20 am
Cheetahmk7 View the latest post
There are no new unread posts for this topic. 404 tubular 10 speed conversion
martfarg39
Thu Jan 12, 2017 3:13 am
GonaSovereign View the latest post
There are no new unread posts for this topic. DT Swiss RRC 445F/555R & Conversion Kit to Shimano 11-speed?
tomyboy123
Thu May 05, 2016 9:18 am
junchen View the latest post
There are no new unread posts for this topic. Brake squeal slowing down from higher speed, but works fine with slower speed.
stockae92
Mon Jun 27, 2016 5:40 pm
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed crank w/ 9 speed chain Compatability
rgamble
Fri Oct 28, 2016 9:09 am
icenutter View the latest post
Users browsing this forum: Baidu [Spider], Miller, Vermu and 34 guests
