Can a use a shimano casette on a Campa body?
Pieter1987
by Pieter1987
Hello,
I can buy some wheels , but it have a campa body. I just ride with Shimano , does a Shimano casette fit on a campa body? Or does a campa castte fit on a Shimano group?
Thanks ,
Pieter!
Superlite
by Superlite
Hello,
Shimano will only fit shimano, as campy will only fit campy.
www.amclassic.com
They sell conversion cassettes, give that a shot.
Pieter1987
by Pieter1987
So , I have to change the body? or buy a universal cassette?
Thnx
zakeen
Resident Pro
by zakeen
If you match the numbers it will work.
Eg Campy 10speed hub with 10speed campy cassette with 10speed DA(everything else) Works!!
I have seen it work, and in a race when I get campy spare wheel(due to race support) it worked fine for me.
dlight
by dlight
So it will work if i run Campy shifters and everything else shimano, RD, FD, cassette and chain?
the Repeater
by the Repeater
dlight wrote:So it will work if i run Campy shifters and everything else shimano, RD, FD, cassette and chain?
You'd need a Campy to Shimano conversion cassette, or swap freehub bodies. The spacing and splines are different. Won't fit, won't shift right.
You'd need a JTek shiftmate to correct the different shift throw length for Campy versus Shimano.
I'd use a Campy chain too... Shimano chains suck. Don't last long.
