Post new topic Reply to topic  [ 7 posts ]
 Post subject: Spada hubs.........
PostPosted: Thu Nov 06, 2003 10:30 pm
Emailed Spada yesterday and this was his response......
The campy version weight 65 gr + 184 gr rear .
The website will be in english version one of this days.
Remember that at the moment is only availlable 10 speed as compatible
cassette ( tiso , marchisio etc )
NO CAMPY CASSETTE can used on Our hubs .
The reason is tecnical , at this weight campy design leave some rolliing
resistance on the road .
Anybody know what this means with the Cassette? Does it mean the hub is actually a shimano hub body and I would have to use an AC Shimano to Campy cassette, or is there something about the Campy cassetts I don't know about. I have a Tiso cassette and I don't remember seeing any real difference between it and the Campy cassetts I have other than the ramping. No spacing differences anyway.
 Post subject:
PostPosted: Thu Nov 06, 2003 10:35 pm
PM Ye Olde Balde One he has them, he can fill you in with detail, also look at his previous post we have discused these hubs.
 Post subject: Campy version
PostPosted: Thu Nov 06, 2003 10:45 pm
It has a body with the same dimensions as the MM10 body. Marchisio and Tiso both make MM10 compatible cassettes. I see no reason why an AC Shimano/Campy cassette wouldn't work, you would need a spacer on the body before sliding on the cassette to allow for proper securing of the lockring.
When I asked, I was told 16, 18, 20, 24 and 28h front, 24 and 28h rear only.
I use my Spada hubs with a Tiso MM10 cassette. It works perfectly in a Record 10 system.
Ride lightly!
 Post subject:
PostPosted: Fri Nov 07, 2003 4:25 am
I have a Tiso cassette already, but it fits on a Campy hub. I assume the MM10 cassette fits on to a shimano hub (i.e. has the shimano hub pattern not the Campy pattern)?
 Post subject:
PostPosted: Fri Nov 07, 2003 5:57 am
Hey JTC what do you think of that tiso Rear Der. over a campy Record?
 Post subject:
PostPosted: Fri Nov 07, 2003 4:50 pm
They have different patterns.
 Post subject:
PostPosted: Fri Nov 07, 2003 5:36 pm
As far as the Tiso cassette goes I will waite and see. I have a new one coming. The first one I received didn't contain ramps so shifting was a little sketchy. The new one will have ramps.
Users browsing this forum: addictR1, Bing [Bot], bruno2000 and 48 guests
There are no new unread posts for this topic. DT Hubs
bikedoc
Sun Aug 26, 2012 12:30 am
bikedoc View the latest post
There are no new unread posts for this topic. Stans 3.3 Hubs
ultimobici
Sat Feb 16, 2013 6:55 am
There are no new unread posts for this topic. Coda hubs?
skiezo
Wed Jan 16, 2013 1:04 pm
boolinwall View the latest post
There are no new unread posts for this topic. eBay hubs
quaman26
Fri Jun 15, 2012 3:48 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Attachment(s) Changing hubs.
jeza
11
637
Tue Feb 05, 2013 11:57 pm
jeza View the latest post
It is currently Fri May 24, 2013 8:08 am
