Any feedback on Vittoria ultra speed?
rustychain
by rustychain
Saw these Vittoria ultra speed clinchers in my LBS. Claimed weight 145 grams. Any coments on how they perform. I am thinking of a race tire so wear is not a big issue but I would hope not to get flats. I am currently using open corsa evo cx tires. at claimed 230 grams. Thats a lot of weight of weight off of the wheel. The other option was to just run the ultra speed in the front. Any feedback?
brian
by brian
rustychain
by rustychain
Thanks for the link. I should have mentioned that the ultra speed was a 23. As I have not used the Veloflex record as well, does it have any advantage/disadvantage over ultraspeed? I used 20's some years back with no problems but I read something about 23's being more areo. Would you recommend the Veloflex record for crits with lots of sharp turns? Thanks for you input
brian
by brian
rustychain wrote:Thanks for the link. I should have mentioned that the ultra speed was a 23. As I have not used the Veloflex record as well, does it have any advantage/disadvantage over ultraspeed? I used 20's some years back with no problems but I read something about 23's being more areo. Would you recommend the Veloflex record for crits with lots of sharp turns? Thanks for you input
http://www.vittoria.com/prodotto.asp?id=19
Superlite
by Superlite
I used them last year, bad ass tires. You can pump them up to 165 PSI and they are STICKEY!
What really surprised me is how long they take to wear, for such a light tire, ( both of my 700 X 23c were under 140g!) they last very long ( 1000+ miles). But they cut easily! The secret is to repair the cuts every so often. Examine the tires before every ride, find the cuts then super glue them shut. Doing this I had mine last a long time.
brianwchan
by brianwchan
Wait, SL, are you talking about the veloflex or vittorias?
Superlite
by Superlite
Vittoria Ultra Speeds, thats what the topic is about. :wink:
