It is currently Mon Dec 18, 2017 12:53 am
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3 Next
 Post subject:
PostPosted: Sun Apr 10, 2005 6:07 pm
Dennis wrote:
Quote:
7kg without wheels
He told today on Belgian television that his bike weighs 7 kg with wheels.
I know what he said. Doesn't mean it's true.
 Post subject:
PostPosted: Mon Apr 11, 2005 12:34 am
asphaltdude wrote:
Remember the old Trek STP frames? They don't have any pivots as well. The carbon fibre is enough flexible.
The Gary Fisher Sugar / Trek Fuel use flexible carbon too, instead of pivots. Cannondale Scalpel too.
Trek has just lost any image of their OLCV frames being stiff in my mind.
 Post subject:
 Post subject: Its not just Treks
PostPosted: Mon Apr 11, 2005 2:28 am
Carbon, even though it is strong as hell, is also very flexible, but not so much to cause a problem. The suspension mod they use in that photo is a similar idea to Specialized's Zertz inserts,on their Roubaix and Tarmac frames. By cutting the carbon and replacing it with some sort of elastomer, you create a flex point in the frame, which is then supported by said elastomer. It is basically a passive suspension. So it doesnt mean the Treks are flexy frames. All carbon would work the same way if they were modified like that.
I ride a Roubaix, and its plenty stiff, and the inserts work like a charm.
 Post subject:
PostPosted: Mon Apr 11, 2005 2:33 am
I've riden a cromo softtail which relied on the flex of the metal to make use of the 25mm of elstomer travel.
Arn't stiff and flexible directly opposing concepts?
 Post subject: Making a softail .
PostPosted: Mon Apr 11, 2005 3:22 am
10 years ago I worked at the local Lbs. I had seen softails and wanted to have one on the road . So around 5 years ago I cut into my steel road frame and brazed in a telescoping tube , just above the rear brake tube . I just cut two inches out of the seat stays. I brazed pivots in with brass bushings and used stainless hardware . I used an elastomer stack with adjustable preload, and a threadedrod running through the center length wise. This way I could keep it all tied together and tighten the rod with more elastomer in the telescoping enclosure to firm up the ride . I gave the bike to somone who needed it and he rode it locally for years. It did have more flex than I would have liked which made the rear wheel track not as well , but very comfy for riding around town . It had around an inch of travel.
I dont think I will do this to my Roubaix Comp though.
 Post subject:
PostPosted: Mon Apr 11, 2005 6:25 am
A triangle doesn't retain it's strength or stiffness when you sever a corner.
I wouldn't be so much concerned w/ flex as a rigid setup, I'd be worried about torsional flex with the suspension installed. And flex and stiffness aren't really opposite properties for carbon fiber. I think this is most obvious in handlebars.
 Post subject: Re: Its not just Treks
PostPosted: Mon Apr 11, 2005 6:31 am
Trek just lifted their suspension mod from their Klein and Trek comfort bikes.... :)
 Post subject:
PostPosted: Mon Apr 11, 2005 6:36 am
the key concept is the direction of the flex. If you lay out more fibers at a higher density in one direction - you strengthen the structure in the parallel direction. Imagine a bamboo grown to adult size. You can tie it down by bending it on its horionztal axis perpendicular to the fibres (which orientated upwards mostly) - release it and it'll spring back. (FLEX)
Try doing the same from the vertical? *PUSH IT DOWN* - It won't budge. It is why in East Asia, we use bamboo to build the high raftings when building medium tall buildings. It is lighter, stronger and cheaper than say metal. It flexes in the wind (like a modern skyscrapper) - but won't break under reasonable load that a human with tools would place on it).
 Post subject:
PostPosted: Mon Apr 11, 2005 6:40 am
I don't know about the other riders, but Hincapie wasn't using it.
 Post subject:
PostPosted: Mon Apr 11, 2005 6:45 am
http://www.cyclingnews.com/photos/2005/ ... e/L1000213
they had it in that foto with his name on it? Were you able to watch the back of frame during the coverage? The rest of the frame looks exactly like a 5000/5200/5500
 Post subject:
PostPosted: Mon Apr 11, 2005 6:47 am
Yes, you could see his back a million times on TV :)
 Post subject:
PostPosted: Mon Apr 11, 2005 7:10 am
Roger Hammond and Roberto Petito seems to have used them... hmmm looking at the pictures of Hincapie's bike... it looks like a 5000/5200/5500 design and the seatstays ... it looks like he did use them... (the actual unit is hidden in the pictures I'm looking at) - but the seatstays can be clearly seen to be curved (and it also turns out that the new modifications utilize curved seatstays not generally found on the madone or 5500 series...)
*shrug* ah well - whether he used him or not doesn't matter ;) I'm never gona buy one. *have a section of 500 meters of cobbles in town - and that'll shake your components apart because they're not even filled in properly so I'm not going to go ride 20mph through them.
 Post subject:
PostPosted: Mon Apr 11, 2005 8:34 am
I should have taped it so I could check it again.
 Post subject:
PostPosted: Mon Apr 11, 2005 9:10 am
Hincapie DID use a frame with rear suspension.
Whow! That's a pretty damn nice garage door!
 Post subject:
 Post subject:
PostPosted: Mon Apr 11, 2005 9:44 am
Administrator
BTW, very funny pic...
Quote:
There are no new unread posts for this topic. Paris Roubaix
mattCSUK
Sat Apr 01, 2017 9:20 pm
mattCSUK View the latest post
There are no new unread posts for this topic. Does anyone have turn by turn directions of Paris-Roubaix?
excel11
9
696
Tue Apr 04, 2017 4:44 pm
tabmaster View the latest post
There are no new unread posts for this topic. Help with 2018 Specialized S-Works Roubaix build
Vandit
Fri Nov 10, 2017 7:50 pm
Vandit View the latest post
There are no new unread posts for this topic. Boonens #and Sagans# Roubaix without disc and Cobra seat post:
Beaver
42
3881
Tue Apr 11, 2017 4:10 pm
Calnago View the latest post
There are no new unread posts for this topic. Attachment(s) Putting aerobars on Roubaix? Cool or not cool?
DCcyclist
21
1484
Sun Dec 10, 2017 2:11 am
Lewn777 View the latest post
Users browsing this forum: alcatraz, Bing [Bot], Google Adsense [Bot], Yahoo [Bot] and 20 guests
