It is currently Fri Jan 19, 2018 7:05 am
 Post subject: 28H hub to a 32H rim?
PostPosted: Fri Apr 08, 2005 5:20 pm
What are your thoughts, is it possible... can the wheel be properly balanced?
BILL NIKO, YOU WILL NOT EVER BE FORGOTTEN.
 Post subject:
PostPosted: Fri Apr 08, 2005 5:34 pm
No way to do this properly the rims are not designed for this. Just get a 28 hole rim or 32 hole hub.
 Post subject:
 Post subject:
PostPosted: Fri Apr 08, 2005 5:47 pm
The thing is that I've got a spare Tune 28H hub that I want to couple with a 05 Mavic Open Pro Ceramic Rim, but I think they are only made in 32 and 36 holes...
 Post subject:
PostPosted: Fri Apr 08, 2005 6:30 pm
28 and 36 would be ok, wouldn't it?
 Post subject:
PostPosted: Fri Apr 08, 2005 6:33 pm
i think its only possible with numbers like 12&24 16&32 18&36 so you can leave every other hole blank
 Post subject:
PostPosted: Fri Apr 08, 2005 10:37 pm
Every 8th hole would be empty.
It would look pants.
And the spoke length differentiation would be something to consider. It depends on how you'd want to build the wheel.
The wheel balance would be fine. But it wouldn't be easy to true with blank spots like that, and you'd be giving up the Ceramic "advantage." You should either buy a hub with 32 holes, or a non-ceramic Open Pro, which come in 28h.
 Post subject: Cannondale
PostPosted: Sat Apr 09, 2005 7:51 pm
Ive seen a front wheel with a 32 hole hub and a 28 hole rim it was radial laced and two holes were left out on each side!
I think that way it could work out!
PostPosted: Tue Apr 12, 2005 1:27 am
I am not a fan of this because there's something I just don't trust about open spoke or rim holes. Anyway here is a link:
http://www.sheldonbrown.com/mismatch/index.htm
Users browsing this forum: Baidu [Spider], Bing [Bot], jlok, TLN, Voyager [Bot] and 55 guests
