It is currently Sat Feb 25, 2017 1:07 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Fri Apr 08, 2005 5:11 am
how'd you build your bike assuming you are riding in the Paris-Roubaix
:lol: :lol: :lol: :lol: :lol: share your ideas!
PostPosted: Fri Apr 08, 2005 5:17 am
Heavy.
John979
 Post subject:
PostPosted: Fri Apr 08, 2005 6:03 am
the first thing that would go would be the SLR saddle, assuming of course that I would like to be able to urinate and have children in the future
a gooooood padded seat! :wink:
 Post subject:
PostPosted: Fri Apr 08, 2005 6:29 am
I would put some different wheels (maybe 32x CXP or Open Pros w 25mm tires), change my bars to my TTT Prima 199, put my olds Rolls saddle back on, put on a Record 53/39 instead of compact, and go for a nice, long ride... :scared: :scared: :scared: :)
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Fri Apr 08, 2005 7:05 am
cyclo-cross frame (longer rear end )
fizik pogio or rolls classic.
hugi 240 hubs older one (not the s version) cx-ray spokes mavic paris roubaix tublar rim (24 mm) , vitoria pave 24 mm tube
campa record
itm millenium steer and stem 140mm inst. of 130mm
 Post subject:
PostPosted: Fri Apr 08, 2005 7:43 am
I'd train a bit more and gain some muscle weight...
In a race the strongest rider wins, although WW lamers might think the bike really makes a difference.
 Post subject:
PostPosted: Fri Apr 08, 2005 8:19 am
frame: longer wheel base and comfortable, more upright. Maybe even carbon..
Wheels: 25mm Tubs!! Alu rims with a good higher spoke count. Not pumped up too hard.
Bars and stem. NOT carbon.
Saddle Fizik Arione. and carbon seatpost.
chainset. Dura ace. Very workmanlike.
Gell bar tape. Gel mits and well padded backside.
 Post subject:
PostPosted: Fri Apr 08, 2005 9:23 am
who you calling a lamer?
 Post subject:
PostPosted: Fri Apr 08, 2005 1:33 pm
fight! :lol:
 Post subject: My P-R build
PostPosted: Fri Apr 08, 2005 1:40 pm
I would look for a Ti frame with my normal position, but longer wheelbase
36h 3(4?)x Mavic SSC rims on 240s(CK?) hubs with DT Revs with Dugast Paris/Roubaix silks
Swap my Std Flite saddle for a Max Flite
Swap the WCS stem for a Thomson
Replace the 42t inner ring for a 47
Pretty much as standard otherwise
Success is how far you you bounce back up after being knocked down
 Post subject:
PostPosted: Fri Apr 08, 2005 1:49 pm
why the bigger rings? wouldn't the compact and smaller rings work better since you can keep spinning but not torque out the rear wheel. it's the same in MTB, my coach tells me to keep a steady cadence over the slow technical section and keeping grip is more important. like when someone goes down in front of you which plenty do in the hell of the north.
 Post subject: Bigger rings
PostPosted: Fri Apr 08, 2005 2:01 pm
On a really rough road bumpiness will affect a higher rpm more than a lower rpm.
If you are riding at the higher rpm then the bumps are closer in frequency to the cadance, and with the bike bouncing around the pedal stroke typically ends up very choppy. As opposed to the MtB situation, the grip on a slipery road is generally greater than that which will cause wheelspin.
Also there is a much greater speed than on a MtB especailly on a techy climb, and the road is flat.
 Post subject:
PostPosted: Fri Apr 08, 2005 2:05 pm
thanks cyco, that makes sense.
how much climbing is there in the race?
 Post subject:
PostPosted: Fri Apr 08, 2005 2:06 pm
On rough stutter bump sections I also like to push a relatively heavier gear with an MTB. As mentioned by Cyco it's more stable and gives better overall speed average using less effort.
 Post subject:
 Post subject:
PostPosted: Fri Apr 08, 2005 2:10 pm
the kasseien are not that bad, i would use my normal bike, maybe some wider tubes, one can always use the sand next to the stones..
There are no new unread posts for this topic. Attachment(s) Movistar rider injured by disc brake in Paris-Roubaix
[ Go to page: 131 32 33 34 35 ]
krtassoc
522
30273
Mon Jan 09, 2017 12:05 pm
ergott View the latest post
There are no new unread posts for this topic. New Specialized Headshok (Roubaix)
[ Go to page: 13 4 5 6 7 ]
Broady
92
7582
Sun Sep 18, 2016 11:40 am
euan View the latest post
There are no new unread posts for this topic. 2007 Pinarello Paris Headset
imcsherry
Thu Sep 15, 2016 5:00 pm
badger4561 View the latest post
There are no new unread posts for this topic. Typical beginner's question (Roubaix 2016)
zalle
30
2408
Fri Nov 11, 2016 5:43 pm
zalle View the latest post
There are no new unread posts for this topic. Roubaix SL4 Comp UDi2 battery and wheels
altereddezignz
Tue Apr 12, 2016 3:04 pm
altereddezignz View the latest post
Users browsing this forum: Bing [Bot], ColnagoJohn, Flasher, hamd, latsride and 18 guests
