It is currently Sun Jan 22, 2017 6:56 am
Post new topic  Reply to topic  [ 84 posts ]  Go to page Previous 1 2 3 4 5 6 Next
 Post subject:
PostPosted: Fri Apr 08, 2005 10:04 am
Hi guys'
both are top's performer , but concerning the shimano the anti corrosion protection isn't the best . it's fact living in thailand a lot off the riders have some issue with the shifters and cranks , it's only the look, the campy it's carbon no problems , I leave in thailand humidity very high .
In asia the shimano groupo much cheaper compare to campy and more avaibility :wink:
 Post subject:
 Post subject:
PostPosted: Fri Apr 08, 2005 10:06 am
would it be possible for one time to explain why the rd from one brand is better then the other ? why it makes sens [except for looking interresting] to use a one brand rd and a different brand fd. And now not like always, mm i heard so, uhm i read it somewhere..
this is such a non-sens discussion, nobody can really on a mechanical level, nor on a technical level tell why campa shifts better or worst then shima. I see that a lott here on the forum, no offence but there are even people that say one day a and the next day b, and then other people say what the first says etc...Its fairly easy to find out what works fine for you and what not. Why would u ask people that change their minds on the average every day trust and buy what they tell you to buy..Iam not saying this happens always, but excuse me, i see it happen a lott..thats the danger of forums, newspapers, television, people believe everything you tell them...without knowing..have fun, cheers
 Post subject:
PostPosted: Fri Apr 08, 2005 10:43 am
Personally, I can't think of a good reason to mix the two component groups. It's just borrowing trouble and not worth the hassle.
For me the best argument to go with Campagnolo are the hoods. My hands simply can't rest on the upward curved Shimano hoods. They either have to be seated before the curve or way up past. Just not as comfortable for my hands as the Ergo levers.
On a sort of technical level Campagnolo is faster than the other and can shift multiple gears up and down. It's very convenient for instance when you shift from the big ring to the small one, and are able to shift down the cassette two or more gears at once. That's one of the things I also like about the XTR rapid rise on my MTB.
Shimano on the other hand shifts the best in the front, because they've got their ramping designed better. The shifters feel more sophisticated as well. The internals consist of a series of gears and a pawl and ratchet system that you tension and release. With Campagnolo you basically directly push the indexing up or down over a spring loaded star wheel. There's only a spring assist to make things lighter. Not a true gear ratio system or whatever you call it to make things work with less effort or fine tune the lever throw.
 Post subject:
PostPosted: Fri Apr 08, 2005 11:53 am
thanks and that i know, but still it doesnt mean one is better shifting, or its better to use fd shima and rd campa or the otherway around..this is the ww forum, campa is lighter so in this forum better :shock:
 Post subject:
PostPosted: Fri Apr 08, 2005 1:11 pm
[quote="divve"]Personally, I can't think of a good reason to mix the two component groups. It's just borrowing trouble and not worth the hassle. quote]
I know what you mean, but have heard good things from those using 7800 BBs and cranks with Campag....
rico
 Post subject:
PostPosted: Fri Apr 08, 2005 2:21 pm
what are those good things then Rico ? That it works, that dura ace is stiffer ? Could you or anybody else post some figures concerning crank stiffness ?? Havent seen them yet but iam very curious though...
 Post subject:
PostPosted: Fri Apr 08, 2005 4:02 pm
I don't think mixing the groups is asking for trouble... it can be set to work just fine...
Like Divve, I don't like the feel of DA shifters in terms of ergonomics. So I'm going to use the Campy Ergoshifters, with a DA RD7800 + JTek shiftmate, and a Campy FD...
So please tell me, where is the hassle in this and what trouble am I looking at.
And yes, I have tried the above set up... for a couple long rides, shifting was nice and my hands were comfortable. And it makes for a nice light setup, the lightest I believe... with some tuning.
BILL NIKO, YOU WILL NOT EVER BE FORGOTTEN.
 Post subject:
PostPosted: Fri Apr 08, 2005 4:14 pm
Is it possible to change the hoods on DA7800 shifters to shorter ones, with a different shape... are any options available.
 Post subject:
PostPosted: Fri Apr 08, 2005 5:43 pm
I doubt it, because Shimano shifters cannot be disassembled or repaired beyond that plastic top cap.
 Post subject:
PostPosted: Fri Apr 08, 2005 5:52 pm
rico
Exactly, after I finish modding the rest of my bike, I'm planning on switching my chorus cranks to DA.
 Post subject:
PostPosted: Fri Apr 08, 2005 5:55 pm
I run a Record 10 drivetrain on one of my bikes but with a Shimano hub bodied rear wheel, and Dura-Ace 10 speed cassette. I like the ratios that Shimano offers and the cost of Campy cassettes is EXPENSIVE!
 Post subject:
PostPosted: Fri Apr 08, 2005 6:49 pm
the da crank is just cool end of story :D
 Post subject:
PostPosted: Fri Apr 08, 2005 10:00 pm
Me and 4 other guys from my club, is driving a full set Campy Record but with DA 10 Cranks. It works perfect, and is my idea of "best of both worlds".
 Post subject:
PostPosted: Sat Apr 09, 2005 12:55 am
While some have complained about Shimano price setting, Campy is guilty of similar. Campy makes it cheaper to buy their group and much more expensive to maintain (chains and cassettes are the bulk of expenditure on bike maintenance).
 Post subject:
PostPosted: Sat Apr 09, 2005 2:02 am
How is it cheaper to buy a campy group? I don't understand, maybe you mean campy doesn't fix their prices on components like shimano does?
 Post subject:
There are no new unread posts for this topic. Is 11 speed Dura Ace chain compatible with Dura Ace 7900 gruppo?
wootenlakeguy
Thu Oct 13, 2016 7:07 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Campy SR DP brakes vs campy skeleton DP
JDEves
Tue Oct 11, 2016 8:39 pm
JDEves View the latest post
There are no new unread posts for this topic. Attachment(s) New dura-ace R9100
[ Go to page: 182 83 84 85 86 ]
Ritxis
1289
193208
Sun Jan 22, 2017 3:39 am
WonderSausage View the latest post
There are no new unread posts for this topic. help needed on Dura Ace BB for Pina F8
fh8425
11
584
Fri Jul 08, 2016 12:04 pm
fh8425 View the latest post
There are no new unread posts for this topic. Dura ace Hub - Ultegra freehub?
damond
Tue Sep 20, 2016 2:31 pm
damond View the latest post
Users browsing this forum: 4151zero, csteeds, RonnieGardocki, wootenlakeguy, Yahoo [Bot] and 22 guests
