Post new topic Reply to topic  [ 158 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
 Post subject: Re: Ritchey Stubby
PostPosted: Wed Sep 16, 2009 8:40 am
bcheung wrote:
Shame it doesn't come in a setback version!
Indeed. The absence of setback on that Tune Capp renders it completely useless for me. If only that front clamp could be 5mm further back...
PostPosted: Wed Sep 23, 2009 11:59 am
Can anyone tell me if theFSA Stubby is valid for an Scott Addict frame?
I want to make the seatpost longer and I see I can do it with this Stubby...
Thanks
PostPosted: Wed Sep 23, 2009 12:28 pm
BERNARDO wrote:
if the FSA Stubby is valid for an Scott Addict frame?
Yes.
Neo Cycles
PostPosted: Sun Jan 24, 2010 2:43 pm
Anyone knows who sells this? It is a WR compositi alternative supposed to be 88gr :D
I am not sure if it is good for carbon rails though...
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Sun Jan 24, 2010 9:18 pm
So what is the measured I.D. of the ISP?
Could you take a regular seatpost like a Thompson cut the post domn to 50mm or so, and stick that in the top of isp with a regular seatpost clamp?
PostPosted: Sun Jan 24, 2010 9:44 pm
That is an interesting question.
Wilier Cento Uno
Wilier 18carati
PostPosted: Sun Jan 24, 2010 11:22 pm
With my Pedal Force CG1, you can use a 31.6mm seatpost if desired.
PostPosted: Mon Jan 25, 2010 2:10 am
Wow.....
for a weight weenie the idea of ISP does not really pay off for weight savings.
So far the only real solution that I see is the stubby from Oliver @ Nordischer Rahmenbau.
Btw....the 170gr FSA aero stubby will also be used for the Litespeed C series.
Alex
PostPosted: Mon Jan 25, 2010 3:50 pm
Gearjunkie wrote:
Awesome.
But, not being a German speaker, where is the buy it now button?
Or do I need to ring them?
Thanks!
USE GOOGLE TRANSATE - which can translate the complete page and you do not need anyone.
http://translate.google.com/#
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Mon Jan 25, 2010 7:59 pm
Update: I now have one of the Norah Stubby replacements. Very light, mmmm beautiful and work great (no slipping or any other problems so far (about 2,000km)).
Only problem is fitting. I had to cut down my frame about 20mm to get the same seat height as the Ritchey. Not ideal since it makes it harder to go back to the Ritchey if I need to, but bit the bullet and very happy so far.
:thumbup:
PostPosted: Tue Jan 26, 2010 12:25 am
NoRa weight: http://weightweenies.starbike.com/forum/viewtopic.php?p=560567#p560567
pk0r wrote:
The GS-Carbonparts Stubby is finally done. Weight is 75.8g (with the original Ritchey stubby being 120.0g). The seat collar is from BTP, the yokes from KCNC. I have already mounted it onto my brother's Addict - so as of now only 8 of 9 available.. :mrgreen:
Image Image
Image Image
A little gallery to be found here: http://www.pk0r.com/Parts/GS-Carbonparts.Addict.stubby/index.htm
PostPosted: Tue Jan 26, 2010 12:28 am
A couple of Ritchey Stubby alternatives similar to the NoRa and Tune posted earlier in this topic:
Mcfk http://www.mcfk.de/ISP.html
Image Image
Image Image Image
New Ultimate http://newultimate.com
Quote:
// NEW ULTIMATE CARBON ISP //
This is truly a sensation. At only 79 grams this is one of the lightest ISP head's of the world including the clamp. Made of High Module carbon, CNC alloy and titanium bolts. 30 mm.
PostPosted: Tue Jan 26, 2010 1:42 am
Oooh. I like the WR Compositi version with the setback. I can't see it in their website though. Any further news?
PostPosted: Tue Jan 26, 2010 1:52 am
Then you haven't looked hard enough, it's here under "Road -> Reggisella -> TC": http://www.wrcompositi.it/catalogo.php?prodotto=42
Quote:
Il nuovo TC, completamento della ns. già ampia gamma di reggisella, é un piccolo – e leggerissimo – gioiello di tecnologia dei materiali compositi. La qualità assoluta dei materiali usati ed in particolare la stratificazione della fibra di carbonio ne fanno un prodotto impareggiabile per rapporto resistenza/peso e smorzamento delle vibrazioni.
SPECIFICHE TECNICHE
peso
Da 88 g (±5%)
diametro
35 mm
compatibilita
per telai con tubo piantone integrato ø 35,00mm.
arretramento
20 mm
Italian to English Google translation: http://translate.google.com/translate?u=http%3A%2F%2Fwww.wrcompositi.it%2Fcatalogo.php%3Fprodotto%3D42%23&sl=it&tl=en
Quote:
The new TC, completion of the ns. already wide range of seatpost, and a small - and very light - a jewel of technology of composite materials. The absolute quality of materials used and in particular the layering of carbon fiber make it an unrivaled product for strength / weight and vibration damping.
SPECIFICATIONS
weight
From 88 g (± 5%)
diameter
35mm
compatibility
for frames with seat tube integrated ø 35.00 mm.
setback
20mm
PostPosted: Tue Jan 26, 2010 6:55 am
Sorry, I meant to purchase it from them...
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
Users browsing this forum: Bing [Bot], Google [Bot], ipaul, maquisard, Martin.F, traveller78, verycreativeusername, wassertreter and 49 guests
There are no new unread posts for this topic. Any alternatives to a Six evo?
welkman
27
2950
Sat Oct 20, 2012 5:59 pm
oreoboreo View the latest post
There are no new unread posts for this topic. Giro LX Gloves alternatives
digitalnorbs
Wed Sep 05, 2012 8:13 pm
yeagermeister View the latest post
There are no new unread posts for this topic. FSA Wing Pro Compact Handlebar alternatives?
CBJ
Sun Mar 31, 2013 3:31 am
Jmeloy View the latest post
There are no new unread posts for this topic. Power2max bb30 crank (alternatives?)
tri
Mon Jul 23, 2012 10:45 pm
Beancouter View the latest post
There are no new unread posts for this topic. Paragon Machine Works barrel adjusters/Alternatives-UK?
iamalex
Mon Nov 26, 2012 3:47 pm
iamalex View the latest post
It is currently Thu Jun 20, 2013 9:16 am
