It is currently Tue Jan 16, 2018 5:00 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject:
PostPosted: Fri Apr 08, 2005 5:33 pm
{USERNAME} wrote:
Hmmm I am in the weight weenies Forum . Oh yeah I should get Dura Ace when there are crank sets 200 grams lighter
Oh yeah, I guess we didn't know that. :lol:
There are lighter crank/BB combos, but don't be fooled. There is nothing better. The DA cranks are bombproof. If you get any cranks with ISIS you will be riding an inferior product. The bearings are horribly small and wear very fast, all you will have is problems. DA you put it on and forget its there.
AS for weight savings, the most you can save on a good set of cranks would be 180g by using THM cranks, but you better have $900. AFter that your back to ISIS and the max weight savings is about 140g with Pulsions and AM Classic BB. BTW, my weight savings are just cranks and BB, not chainrings.
Remember, lighter isn't always better. Unless, maybe you get the THM cranks. 8)
 Post subject:
 Post subject:
PostPosted: Fri Apr 08, 2005 6:12 pm
:goodpost:
My DA10 BB/Crankset is about 100g heavier then the Record Carbon and Phil Wood BB I used to use but noticably stiffer and truly confidence inspiring. I wouldn't trade back for any reason.
If all you care about is weight then by all means, get the propellers. :lol: They'll work fine as long as you only weigh 100 lbs. and walk your bike up hills. You'll have a very fine bike that can be hung on the wall and displayed for all to see.
PostPosted: Sat Apr 09, 2005 1:37 am
The Thm looks like it is an awesome crank and bottom bracket combo . It is so lite I am worried about snapping it in two ... Has anyone here bought one and reviewed it yet? I now am going to need to source some lite weight chainrings. I like a non compact crank with 53 and a 36 , Any ideas ?
Thanks everyone for turning me on to the Thm Clavicula ... Before I order I have to save for another week and read up on them and see if any have failed. There a little out of my price range for immediate purchase.
 Post subject:
PostPosted: Sat Apr 09, 2005 3:58 am
TA rings are good.
But 53-36? Why? That is a heck of a spread, and 17 is beyond must derailleur limits...not a good ratio I think. I don't even know if you can get a 53 and a 36 on the same crankarm bcd, I don't think so.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Sun Apr 10, 2005 4:30 pm
cadence90 wrote:
TA rings are good.
38 is the lowest on a 130bcd crank. But I have seen up to 56T for 110bcd compact cranks.
I still think compacts would be the best choice. Just get an 11-25 cassette, either an aftermarket or mix an 11-23 and 12-25 cassette.
 Post subject:
PostPosted: Mon Apr 11, 2005 12:04 am
Hello again you cant mount a 53-36 on a standard size (130) you have to go compact (110). The lightest compactcranks are pulsion, k-force and maybe the new extralite. Go and buy the new stronglight CT2 chainrings and you have a nice setup. the Q-Factor for the k-force is 146mm and you have to mount it on a 108mm isis bb. the Q-Factor of the extralite is 160mm for the pulsion i dont know. For a roubaix i would choose a carbon crankset and please post a pic of your bike sounds nice.
There are no new unread posts for this topic. What bottom bracket do I need
JScycle
Tue Oct 31, 2017 7:56 am
JScycle View the latest post
There are no new unread posts for this topic. Bottom Bracket Drag
Ltoddokc
10
1615
Wed Oct 18, 2017 12:32 am
youngs_modulus View the latest post
There are no new unread posts for this topic. Attachment(s) Bottom bracket 386 for Cipollini
MiddMan
11
1026
Sat Jun 24, 2017 3:03 pm
Calnago View the latest post
There are no new unread posts for this topic. GXP Bottom Bracket Assistance.
Y26
13
1070
Tue Jul 25, 2017 6:09 pm
Y26 View the latest post
There are no new unread posts for this topic. Campy Bottom bracket for ITA
TonyM
Fri Nov 10, 2017 7:32 pm
tommasini View the latest post
Users browsing this forum: Asteroid, Bing [Bot], wingguy and 44 guests
cron
