Post new topic Reply to topic  [ 124 posts ]
Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Planet X brakes
PostPosted: Tue Dec 11, 2012 4:46 pm
Kayrehn wrote:
Don't think you will find help from them - I asked them for installation manual and they say that they don't have such a thing. Rear brakes are deliberately set off-centered for me right now as one arm pivots a lot more than the other, so if I centered it the wheel will be pushed off quite badly to the left. Not ideal but I can live with it. Happy with the weight savings still...
Make certain that your cable housing length is correct, i.e. not pushing or pulling on the caliper too much. With the correct housing length my brake arms move almost completely symmetrically.
PostPosted: Tue Dec 11, 2012 5:29 pm
That is what I noticed also. Any residual force coming from the cable housing becomes part of the overall balance of forces.
PostPosted: Wed Dec 12, 2012 9:11 am
Has anyone got the blue ones? Is it a close match to Tune blue? Hard to tell from photos.
PostPosted: Wed Dec 12, 2012 11:57 am
I have the blue Cnc ones. Post up pics tomorrow. Match very well to the blue on a Z4Parlee if that helps. No dramas so far with centering. Stopping is also fine with stock pads for me.
PostPosted: Wed Dec 12, 2012 4:24 pm
Yup, am changing cables so got the mechanic to try remedy things; he agreed with this assessment too. Thanks anyway!
PostPosted: Wed Dec 12, 2012 6:19 pm
I hope it works out. These brakes are a little quirky to set up but the performance/weight/cost matrix is amazing. I find the fall between Ciamillo and Sram/Shimano in setup difficulty, fall just below Sram/Shimano in power, and are the cheapest of the three.
PostPosted: Wed Dec 12, 2012 9:48 pm
Just as an FYI, Planet X USA has the black brakes back in stock after not having them for at least a couple months. I just ordered a pair to replace a set of Ultegra 6700 calipers. The Ultegras have been pretty flawless, just looking to drop some weight and I have another bike to put the Ultegras on.
I'm excited to get them and set them up. Will let you all know impressions after I get a few miles on them.
PostPosted: Fri Dec 28, 2012 9:05 pm
prendrefeu wrote:
Yeah, just thread it through the nut, do not use the binding screw, and tie a knot on the other side of the nut (self-knot). That's pretty much it.
Getting it to the right length, however, takes some magic. :lol:
So here's an update:
*DO NOT* use PowerCordz with these brakes... at least for now, until a better solution is found.
tldr version: cable showed fraying upon inspection, a better nut needs to be designed.
Originally I had the PowerCordz working with these brakes. The solution is, on the surface, simple (but, again, don't do this) - simply take out the setting screw in the barel nut (saves .25g), leaving the barrel nut loose on the cordz. Then tie a knot on the cord (simple knot will do, or Ashley's Stopper Knot if you have patience). You'll need a lot of patience and re-do's however as getting the knot in the proper place post-initial stretch from the levers is a long process.
But, anyway, don't do that. Please, please don't.
I was cleaning my bike last night and in my usual OCD fashion inspected everything... lo and behold, a bit of the casing on the Powercordz was somehow damaged and the inner fibers were visible. They weren't frayed, but the fact that the casing was somehow not there (perhaps an internal scratch in the nut?), I'm expecting the fibers are next to be cut.
I used these for weeks, even a wet descent a few days ago... I'm happy that I did not encounter any problems, but I'm back to ptfe coated steel cables again. Weight savings have been denied to me! :evil:
It seems that the barrel nut has a few sharp edges internally which don't help the PowerCordz over time. A better nut needs to be designed/developed.
Exp001
PostPosted: Fri Dec 28, 2012 9:21 pm
I gave this a try too. Never did try pulling the nut out. Could never get the knot to the perfect length and found that after a few re-ties the powercord started to split exposing the fibres below. Straight to the garbage.
On thing I did do was pass a couple cm of liner over the power cord prior to putting the nut on so that the part that went into the arm was wrapped in liner so that it wouldn't fray going in and out of the arm or from the action of the relatively sharp edges of the arm against the powercord. May solve your problem.
Frankly the whole experiment really didn't seem worth the wasted money and time.
PostPosted: Fri Dec 28, 2012 10:26 pm
Have you tried fiddling with the grub screw attached to the return spring?
Located on the right hand side (of the front brake). Loosening or tightening it should adjust the rim clearance of just one arm ...I think.
PostPosted: Sat Dec 29, 2012 10:01 am
Has anyone got experience of running these with DA 7900 levers?
Currently running KCNC CB1s with the 7900s but the feel and performance could be better.
Would swapping to these or 7900 brakes be loads better?
PostPosted: Sat Dec 29, 2012 2:22 pm
Will Planet X brakes work with wide wheels such as the Bontrager Aeolus D3's?
PostPosted: Sat Dec 29, 2012 3:07 pm
Have you got calipers to measure the wheel width?
PostPosted: Mon Dec 31, 2012 1:12 pm
27.5mm wheel width.
PostPosted: Mon Dec 31, 2012 2:03 pm
7900 calipers will be a lot stronger with DA levers. P-X ones will still be considerably better.
Bikes: Raceur, Beateur
Post new topic Reply to topic  [ 124 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
Users browsing this forum: adhumston, bumpkin, capnc, cesemo, Google [Bot], Google Adsense [Bot], konky, Majestic-12 [Bot], timj and 60 guests
There are no new unread posts for this topic. keep the zero gravity og-07 , or planet x cnc brakes
deermatt
19
1011
Fri May 10, 2013 2:18 am
totoboa View the latest post
There are no new unread posts for this topic. Planet-X brakes vs KCNC C7
blantonator
10
1305
Sat Aug 11, 2012 5:14 pm
blantonator View the latest post
There are no new unread posts for this topic. installing planet x ultralight brakes
tinchy
10
812
Mon Apr 08, 2013 9:18 pm
stubob View the latest post
There are no new unread posts for this topic. Attachment(s) Gunmetal Planet X Ultra Light CNC brakes...
Juggler
16
1411
Thu Aug 30, 2012 7:28 pm
JourneyLightly View the latest post
There are no new unread posts for this topic. PLANET X CNC BREAKSET
darnocula
16
2469
Mon Jul 30, 2012 12:14 pm
cybernck View the latest post
It is currently Thu May 23, 2013 4:46 pm
