It is currently Tue Aug 22, 2017 8:03 pm
Post new topic  Reply to topic  [ 61 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Ceramic Bearings
PostPosted: Tue Nov 04, 2003 8:17 pm
where would i get ceramic bearings, lets say i have mavic ksyriums sl, and i want to change all the bearings to ceramic, where would i buy them, has anyone done this to their hubs?
 Post subject:
PostPosted: Tue Nov 04, 2003 8:20 pm
No idea where you'd begin but these guys sell them:
http://www.bocabearings.com/ceramic/grade_5.cfm
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Tue Nov 04, 2003 8:32 pm
thanx. i just called them up. they said i need to get the size of the bearings, does anyone know the size of mavic ksyrium sl 2004 bearings? the ceramic bearings start at about 7 bucks and go all the way up to 50 bucks each.
does anyone else know who else makes ceramic bearings, or if the bocabearings have great quality, or do you know of anyone that makes better bearings.
 Post subject:
PostPosted: Tue Nov 04, 2003 8:34 pm
If you check Damond Rinards links page (which can be found on the links section on this website) he had a link to a ceramic bearings dealer.
It's a big list so good luck.
 Post subject:
PostPosted: Tue Nov 04, 2003 8:44 pm
Not that its going to be much help but they list a popular bicycle sizes:
http://www.bocabearings.com/bicycle/bike_bearings.cfm
 Post subject:
PostPosted: Tue Nov 04, 2003 8:48 pm
i found some more sites, if anyone is intrested
http://www.cerbec.com/main/home.asp
http://www.bearingworks.com/
check out this article
http://www.mmsonline.com/articles/0901td.html
 Post subject:
No wonder Z series hubs costs so much, the bearings alone are several hundred dollars! Spytech, don't be silly trying to replace all you bearings, it will cost a grip, and the performance will be unoticeable.
 Post subject:
PostPosted: Tue Nov 04, 2003 8:51 pm
Found that link http://www.ntnamerica.com/
 Post subject:
PostPosted: Tue Nov 04, 2003 8:55 pm
we tested ceramic bearings a few years back, and unless they have come a long long way.... you are gonna find they just dont work on those loads.
they crumbled like a cookie after a few dozen miles on the front wheel with a 175lb rider
www.crumptoncycles.com
 Post subject:
PostPosted: Tue Nov 04, 2003 8:57 pm
Tune are using them :?
 Post subject:
PostPosted: Tue Nov 04, 2003 9:07 pm
i would doubt they would crumble, its what they use in formula 1 and other cart car axle bearings.
if they are not to expensive, i think i might do it for the heck of it, IF THEY DONT COST AN ARM AND A LEG.
 Post subject:
Actually if you look at the 'lightbike' world record, the BB has ceramic bearings.
Bottom bracket:
Tune full ceramic bearings, modified J.U. spindle 124,6 g
I wonder :?:
 Post subject:
PostPosted: Tue Nov 04, 2003 9:08 pm
You got me thinking about replacing the bearings in my King headset :shock: :cry:
 Post subject:
PostPosted: Tue Nov 04, 2003 9:09 pm
Yup, i think they can take large loads. i am only 184 lbs.
now to find who make the best ones. does anyone know anything about ABEC rating, i hear ABEC 9 has the best tolorance. are tighter and smoother.
 Post subject:
 Post subject:
So are Zipp, and other non bike manufactures. Ceramic bearings are far superior to steel. Crushed bearings? Ok. Ceramic bearings have a steel core, there not pure ceramic, they are stronger then steel, harder then steel, and resist deformation better then steet. They also have a much higher operating velocity due to lower mass and roundness, and can operate at much higher temperatures, 160 vs. 800. Sure you were using cermic? maybe you had plastic ones. :wink:
There are no new unread posts for this topic. Ordering Ceramic Speed Paulley and Bottom Bracket, need help
Noctiluxx
15
1244
Thu Jun 01, 2017 7:41 am
Shrike View the latest post
There are no new unread posts for this topic. PF30 Get the bearings out (intact)
alcatraz
Tue Oct 04, 2016 8:37 am
Marin View the latest post
There are no new unread posts for this topic. Attachment(s) Ultegra 8000 pulleys - both bearings?
evren
7
999
Sat Aug 05, 2017 7:06 pm
ooo View the latest post
There are no new unread posts for this topic. Light replacement bearings for FSA Orbit c-33 44E?
octave
Tue Aug 15, 2017 10:47 pm
octave View the latest post
There are no new unread posts for this topic. Loctite and Bearings in Carbon Shell BB
Mr.Gib
37
2438
Sat Mar 25, 2017 8:26 pm
nickf View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Delorre, kvrt, neil56, stormur and 65 guests
