Post new topic Reply to topic  [ 18 posts ]
Go to page 1, 2  Next
 Post subject: Hollow Pin Chain
PostPosted: Thu Oct 31, 2002 7:01 pm
I have had a number of hollow pin chains on my timetrial bike over the years, but can't remember who made them or if they are still available. (I think they were Regina or Rohloff? I'm assuming they are no longer manufactured, but....does anyone know for sure?
 Post subject:
PostPosted: Fri Nov 01, 2002 10:58 am
SRAM do a new version of the PC89R the chain with the cutouts in the connecting plates, the new version has got hollow pins and comes in at 270 for 114 link. Connex had a chain at Interbike, not sure how much it weighed or if it will go into production, but the connecting plates was made out of Titanium with cutouts (even more so that SRAM) and the pins were hollow, they named it the Connex TR Titanium
 Post subject: Hollow Pinned Chain
PostPosted: Sat Nov 02, 2002 1:07 am
Thanks, Francois,
I'll check them out. I know Viking makes a titanium that weighs in around 225 grams, but it doesn't work for 9 speed (I believe only six or seven)
 Post subject:
PostPosted: Mon Nov 04, 2002 3:06 pm
Hi Mate
Yes it is only for 7 & 8 speed setups, but the problem withthe viking chain is that it is nearly $300 :shock: no way would anyone pay that
PostPosted: Fri Nov 08, 2002 1:31 am
Connex TR Titanium won't be available until March or April per Wipperman. The weight will be 225 grams for 110 links, but the cost will be $225.
 Post subject:
PostPosted: Sat Dec 28, 2002 11:09 pm
What about 10sp. I'm getting my Campy components ready right now and would like to know about a 10 sp. chain. Just got done with the front derrialeur. Haven't weighted it yet, but it seems light to the hand. there's only two steel parts on it now. The cage and the spring. I'll weigh it soon and post it.
 Post subject: 10sp is available
PostPosted: Fri Jan 03, 2003 10:49 am
... from a Company in Frankfurt/Germany 325
Advance Bike Technology
Niederurseler Ldstr.54
60439 Frankfurt am Main
tiultralite@aol.com
advance-bike.com
 Post subject:
PostPosted: Fri Jan 17, 2003 6:22 pm
I haven't bought a 10 sp. chain yet. What 10 sp. chain is the lightest without going to the expense of a titainium chain. I've heard of guys running the 9 sp. chains on 10 sp. systems with no problems. If so I could run the Sram hollow pin. Is that going to be lighter than a narrower 10 sp. chain. It seems what you would loose in the hollow pin you make up in width.
 Post subject: hollow pin chain
PostPosted: Wed Apr 09, 2003 1:40 am
reginna made the sl50 hollow pin chain, I still have mine unused in the box I ame looking forward to getting a sram hollew pin chain,but does it work on 8 speeds?[/b]
 Post subject: Hollow pin chain
PostPosted: Sun May 11, 2003 5:02 pm
I have taken a Regina SL50 chain, done the calculations and machined the rollers and pins after dissassembly and reassembled afterward. This yeilds a chain that will shift 9 speeds and probably 10. The best part : for 110 links it weighs 237 grams.
 Post subject: Way to gg
PostPosted: Mon May 12, 2003 12:29 am
Well done Wally. Will you be posting the calculations, and photos in the Articles section of this site?
 Post subject:
PostPosted: Tue May 13, 2003 12:51 am
I think Wally is in the lead for the biggest weight weenie. That's incredible.
PostPosted: Wed May 14, 2003 5:49 pm
CYCO thanks for the compliment. I will post the info, but not right away. I don't own a dig. cam. but might be able to arrange something and am busy with some projects that need to be finished. POPAWHEELIE I'll take that as a compliment also, thanks. But I'm only 5'7" and 145 lbs.
 Post subject:
PostPosted: Thu May 29, 2003 9:18 pm
Just an FYI for one of the questions further up this post. The SRAM PC-89R Hollow pin is narrower than the regular PC-89R. It is narrow enough to work fine on Campy 10 spd BUT SRAM does not make a master link (yet, they are working on it) that is narrow enough to work with 10 spd. For right now they are including their regular 9 spd masterlink (powerlink, they call it) with their PC-89R hollow pin. If you can make a connection that you trust without using the powerlink then you can use the PC-89R hollow pin chain with 10 spd. The PC-99 Hollow pin is also narrower than its non-hollow pin counterpart but it is a little wider than the 89R hollow pin. not sure if it works with 10 speed or not.
-jer
 Post subject:
PostPosted: Fri May 30, 2003 2:37 am
Jer, Is ther a way to conect the PC-89R with a permanent link pressed in. I don't need to break my chain to clean it. Thanks!
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Users browsing this forum: alexalecu, Dennis, Exabot [Bot], gleason, Miller, nagge, rijndael, Routier, shimmeD, xcnick and 69 guests
There are no new unread posts for this topic. chain drop on SRAM chain catcher
PoorCyclist
Fri May 10, 2013 4:38 am
timzcat View the latest post
There are no new unread posts for this topic. Yaw shifting with KMC chain vs 1091R chain
rijndael
Fri May 10, 2013 2:49 am
DaleRider View the latest post
There are no new unread posts for this topic. KMC 10-Speed Chain
LLL
Tue May 29, 2012 11:17 am
kman View the latest post
There are no new unread posts for this topic. Chain catcher - Is it necessary?
G6612
39
2529
Sat Aug 18, 2012 10:02 am
daj View the latest post
There are no new unread posts for this topic. Dropping chain on DA Di2!!!
phil3202
11
954
Tue Oct 30, 2012 11:53 am
phil3202 View the latest post
It is currently Thu May 23, 2013 10:05 pm
